Who Knows His Humps- SBC 327 Heads???
Discussion in 'The Hokey Ass Message Board' started by Southfork, Sep 18, 2007.
  1. Southfork
    Southfork
    Over the years I've had six or more 327 engines and probably a couple dozen double-humper heads (castings 461, 462, 186, etc.) Today I got to looking at the 327 engine in the '68 Chevy that I bought from a little old lady who is too old to drive anymore, and after scraping the grease away at the front of the un-drilled head, I found what looked like a power-pak head but instead of having a tent peak centered on top of the reclining rectangle, it has a round hump instead on top of the rectangle --- the hump is about the same size as the humps on a double-humper, but there's only one. I have never seen that particluar head before. Anyone know their vintage SBC heads well enough that they can tell me about this head? By the way, the '68 Chevy is an unmolested car that the old-lady's deceased husband bought new in '68. It still has a nice running 327 and powerglide, but is a 4-door, so the drivetrain is probably going into a Model A coupe project.
  2. TERPU
    TERPU
    Bactrian 194's
    tim
  3. Southfork
    Southfork
    Say, What??? I don't follow. "Bactrian 194", meaning 1.94 inch valve? What about combustion chamber size, etc?
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Any head I've ever seen with the symbol you describe was a small valve style (1.72 intake, 1.50 exhaust) head.
  5. Irish Dan
    Irish Dan
    That's certainly something I've never come across in my travels! My guess, for whatever it's worth, is they're probably 194's. seems like a "standard" smaller valve head. I'm curious to learn more about this set of heads!
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Sounds like the '68 version of a 250hp 327---small valve heads and a quadrajet.
  7. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Take a pic of it. I thought I'd seen everything on older chevy heads but this is a new one on me. Pull the valve cover if you get a chance and get the casting #
  8. Ebbsspeed
    Ebbsspeed
    Likely one of these two versions:
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]"292" – 3917292, or 340292. Both are good performance heads. The 3917292 was found on 1968 327 and 350 engines, had 1.94/1.50" valves, 64CC combustion chambers, straight plug configuration, not sure on the accessory holes, and I do not have any port volume data on these heads. [/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]
    "040"
    – 3947040. A good performance head (I have read). Supposedly these heads came on 1968 327 truck engines. They had 1.94/1.50" valves, 64CC combustion chambers, DO NOT have accessory holes. I do not have any port volume data for these castings. These heads also had a single triangular shaped casting mark (slope on the upper left).[/SIZE][/FONT]
    Might also be these, although it says these DO have the accessory holes:
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]"041" – 3947041, also 3947041X. A good performance head. They were found on 1969-1970 302 and 350 engines. They had either 1.94/1.50" or 2.02/1.60" valves, 64CC combustion chambers, DO have accessory holes, I don't have port volume data for the regular 041, the 041X intake port should be 165CC's, the 041X exhaust port should be 65CC's. These heads have a single somewhat triangular shaped casting mark (slope on the upper left).[/SIZE][/FONT]
  9. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Oh by the way, there were some double hump heads that had the bolt holes cast in the ends. The flat machined surface on these covered up part of the rectangle with the double hump to where only one hump shows. I've had one set of those, very desirable.
  10. Revhead
    Revhead
    from Dallas, TX
    there's a set of '68 327 heads on ebay referred to as "single hump"
  11. FWilliams
    FWilliams
    the 290 casting....standard casting on a lot of stuff in 68
  12. 41woodie
    41woodie
    Ok, Bactrian has to do with Camels. There are two distinct types Bactrian and Dromedary (I think). The reference is to the humps, get it humps -- Camels. Don't blame me it wasn't my post.
    tommyk and Andamo like this.
  13. treb11
    treb11
  14. Southfork
    Southfork
    If there's any daylight left when i get home this evening, I'll try to take a picture of the single-hump 327 head. 'Hope to be picking up a running 425 Nailhead engine and tranny right after work though, so it may not happen tonight.
    I don't want to pull the valve cover (to see the head casting number) and possiblly cause a lot of work in sealing the gasket, so I'll save that until I need to do a rebuild. 'Just not worth the hassle to satisfy my curiosity. In the meantime, think I'll see what the single-humper heads on egay say.
  15. channel cat
    channel cat
    If my memory serves me correctly when the 327 first made it,s appearance in 1962 as a 250 hp engine the markings were a single hump . In 63 a 300hp version was available with double humps but the 250 hp engine was still available until 1965.In 1966/67 the 327 became a 275 hp engine with double humps and then from there it all got too crazy.
  16. 56sedandelivery
    56sedandelivery
    Just another version of the Power Pack heads, with small ports and valves. Pull a valve cover and see if it says "CANADIAN" anywhere. Butch/56sedandelivery.
  17. I Humped Last Night !! >>>>.
  18. titus
    titus
    i had a 65 ish fuelie 327 that had heads like that one it, basically a single hump head if that makes sense, when i got the motor it was freshly rebuilt and had a vette fuelie intake on it.
    JEFF
  19. bowtie40
    bowtie40
    I can remember when I used to be able to double hump!!!
  20. bobscogin
    bobscogin
    Come on man! The single humps are Dromedary, the double humps are Bactrian. :D
  21. propwash
    propwash
    from Las Vegas
    so the Equestrian has NO humps...amazing how that works
  22. teh1955
    teh1955
    from Lyman, SC
    Found a set of Single Hump Heads in South Carolina. It is on a 327.
  23. It means its a dromedary instead of a camel. I think I got that right one only has one hump.
    I think in the case of these heads you are going to have to locate a casting number and go from there.
    What kind of Chebby did you buy from the little old lady?
  24. Russco
    Russco
    from Central IL
    '67-'68 307 327 heads, 3917290 casting number.
  25. 327Eric
    327Eric
    Another back from the dead, but,---.I had a set off a 327 that came out of a 68 El Camino. They were small valve heads.
  26. mgtstumpy
    mgtstumpy
    3917290 327 68-70 1.72/1.50
    3297185 307/327/350 57-67 1.72/1.50
  27. flux capacitor
    flux capacitor
    Not totally related but knew a kid n high school who was a master of fakery on chevy stuff. Used silly putty & molded camel hump shape off real set of heads n filled his silly putty mold with jb weld pasted double humps on a set of small valve no accessory hole heads. Looked real. :eek:. Later on he graduated up to using winters foundry gm intake "snowflakes" & various firing order & block casting numbers & pasting them on all kinds of stuff using vasaline as a release agent between silly putty & jb weld "machinist foil" for raised square number pads & a needle scaler to help blend the fake markings in, needless to say he got real good at it. Now he's into old corvettes ...... Go figure. Ohh & he said advertising an old vette as numbers match & saying original engine numbers match are two different things! Flux
  28. DDDenny
    The picture of the camel hump's is lacking the "461" casting from pre-67, not too much different from the "462"s. I have a pair of NOS "291"s on my Nova l79 engine..
  29. a Domedary has one hump a Bactrian has two humps. so those will be dromedary heads. they will be low horse 172 intake heads. The Hp camel humps all have two humps some have the larger 202 intake valves
  30. The 1962 & later 250 Hp 327 used the 283 Power Pack heads they have a pyramid on them. and the 300 horse 327 with double humps and a carter AFB carb & intake was available in 1962
