Technical Who made this scatter shield?
Discussion in 'The Hokey Ass Message Board' started by midnightrider78, Mar 2, 2018.
  1. midnightrider78
    midnightrider78
    DSCN2368.JPG DSCN2369.JPG I have got an old ****ter shield for a Chevy V8 that I am trying to ID further. It appears to have been manufactured as a two piece unit and then someone welded the halves together along the way. I have seen tons of the old cast units that are two pieces. But this one is clearly steel. The block plate has, for some reason, had a thin piece cut out on the outside edge of the starter location. Otherwise it looks just like some of the Ansen ones I have seen pics of.
    Has anybody ever seen a 2 piece steel unit before? Is it an Ansen? Or?
    Also, I really have no use for it at the moment. However, I have a couple 4 speeds that I may be selling and that causes me to wonder... Is the ****ter shield worth more alone or in a package deal with the transmission?
    Thanks all
  2. Austin kays
    Austin kays
  3. Austin kays
    Austin kays
  4. saltflats
    saltflats
    from Missouri
    Looks like a Lakewood to me.
    Montana1 and chryslerfan55 like this.
  5. DDDenny
    Yes it does.
    Maybe they couldn't find offset bushings for 1/16" runout!
  6. Montana1
    Montana1
  7. cracker head
    cracker head
    Got one just like it... no idea who made it but I’d bet money on Lakewood.
  8. shadetreerodder
    shadetreerodder
    Got one behind my big block. Two piece Lakewood. Don't forget to use the engine plate.
    Sent from my SM-G955U using The H.A.M.B. mobile app
  9. bowie
    bowie
    Agree Lakewood without the ‘55-‘57 mount holes.
  10. That is a lot like mine and if it is not a Lakewood it is a close copy. Could be a Schaeffer (SP?) they made hot clutches and unless I am mistaken they also made some tin cans.
    Most of the manufactured steel clutch cans resemble each other. These days Lakewood is pretty common.
    You may post your question here:
    https://www.jalopyjournal.com/forum/threads/vintage-****tershields.1098964/#post-12462692
    Someone looking may recognize it.
    Mine is a little different and is one piece other than the flange. A piece of my flange is missing. LOL
    GlassThamesDoug likes this.
  11. Montana1
    Montana1
    I didn't know they made a 2-piece ****tershield! :eek:
  12. Rich S.
    Rich S.
    I thought the early Lakewood were two piece and painted purple from the factory
    saltflats likes this.
  13. shadetreerodder
    shadetreerodder
    Actually it is a one piece ****tershield with an engine plate. They also make a three piece. You can remove the lower fourth of the shield to inspect or change the clutch.
    Montana1 and henryj1951 like this.
  14. Deuces
    Deuces
    Red er orange.....
  15. midnightrider78
    midnightrider78
    If you look closely at the picture, you can see where someone has welded it. Originally, the bottom portion of the ****tershield did indeed unfasten from the top. That is why I posted. I had never seen a steel one that bolted together like that.
    I just said 2 piece initially because I don't consider the block plate part of the ****tershield, but rather a separate component.
    Also, to clarify. There were 2 reasons I didn't think it was a Lakewood. 1) the 3 small holes in the block plate. The only pics I saw with a plate like that claimed to be Ansen. 2) the block plate seems to only be about 75% of the thickness of my Lakewood block plate in my '56.
  16. shadetreerodder
    shadetreerodder
    The engine plate on mine is about one eighth inch thick. I coudn't see the welds in the pics. They were marketed as a two piece ****tershield. If that is an Ansen there isn't much difference in shape. As far as the engine plate having three holes it's been years since last clutch change.
  17. henryj1951
    henryj1951
    from USA
  18. henryj1951
    henryj1951
    from USA
  19. badgascoupe
    badgascoupe
    Lakewood,Have one hanging on the wall.
  20. midnightrider78
    midnightrider78
    What do you guys think it's worth? Would it be worth the time to cut the welds and clean the joint up again or not?
  21. DDDenny
    NHRA (and others) certify new ****tershields up until some yayhoo takes a torch or welder to them, they frown on modifications.
  22. 56sedandelivery
    56sedandelivery
    2 piece so you could change the clutch/flywheel without removing the entire ****tershield. Yours has the welded on bracket for the Tri-Five clutch linkage, and should have 2 drilled holes at the lower sides to bolt the side mounts to. And like has already been said, cut on them, drill any holes, any welding, and they are no longer legal for racing NHRA/IHRA; the roundy rounders have more liberal rules, such as ******s that has been cut flat on the bottom for ground clearance. I think both Lakewood and McLeod had similar 2 piece ****tershields. Still good for a streeter.
    I am Butch/56sedandelivery.
