who make a good heater other than spedway?
Discussion in 'The Hokey Ass Message Board' started by oddrod46, Nov 17, 2009.
  1. A lot of the later factory GM ones can be adapted around and are somewhat compatable with one another to adjust where the fan ends up and so on, particularly if you're not looking to add air conditioning. And you can come up with all sorts of vents and things that can be adapted around to give you defrost, vent and heat if you want. I try to save them when I really gut a car to s**** it. Hard to beat, price-wise.
  2. Dirt Dobber
    Dirt Dobber
    Here is what I came up with after a six pack of Keystones, it's a Stewart Warner heater I picked up at a swap meet for $20. I belive it hooked up to the carb and was gas fired. I removed the burner ***embly, rolled up 7 rows of 3/8 copper, and installed in housing. I still have to find a replacement motor or computer fan for the old one. Should make plenty of heat, but will not know for sure until finished.
  3. billygoat67
    billygoat67
    oliver bros is right, i have one of the units like that that i remover from a piece of const equip. they are tough as nails and roast your *** off.
    my friend used a heater out of a ford courier truck in his 47 chrysler, small unit with def option ,heater core replacement avail, and the hoses even lined up with the holes in his firewall from orig heater. can't get any better then that and cheap.
    it all what ever a guy wants to spend i gess.
  4. 50scotbolt
    50scotbolt
    The heater unit from early Austin Minis are popular over here, I've had major problems trying to get someone to re-core my original Chevy heater core.
    I guess I might give the Mini unit a try. They're small,self contained and easy to fit.
    http://toronto.kijiji.ca/c-ViewAdLargeImage?AdId=169930034
    I wondered about availability for you guys over the pond,but this one was in Toronto.
    A buddy of mine had one in his '52 pick-up and it did the job just fine.
    It was easy to hook up and had defrost too.
  5. pecker head
    pecker head
    This is one that I scored at a swapmeet back in the spring . Had the core rebuilt , & put a 12voltdc computer fan from Radio Shack in it . The knob on the bottom door was missing so I whacked another one out of a peice of aluminum .
  6. yekoms
    yekoms
    Hey Von Fink,
    I have the same one as you. I'm planin'' to modify it to stick a Vintage Air into it.
    Smokey
  7. langy
    langy
    I used an old Arvin and put a 12v fan in it, looks right not like some of the one's you buy these days.
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Any idea who's make or year it is?
    im sure there is going to be alot removed from this unit to use it in my A, it looks to be complete, even has the blower ducting and a few other things that make it too deep of a unit to use like it is, (at least thats what it looked like in the pictures)
  9. billy zz
    billy zz
    yep
    i use the one from heatercraft in my willys.
    28000BTU
    under a hunnerd bucks.
    hide it under the dash and be warm.
  10. Stevie Nash
    Stevie Nash
    Wow, that's some awesome work! :cool:
  11. hotrod56cars
    hotrod56cars
    There was one of these on eBay that ended yesterday, $60.00 starting bid and it ended with no bids on it. Your heater looks awesome.
  12. yekoms
    yekoms
    Von,
    I got no idea what it is. I've seen a few of them since I got it. One guy said that he thought maybe a Firestone. No names on any of the parts. For me it looked cool and was 10 bucks without the core at a swap meet.
    Smokey
