Technical Who makes a C-4 to Y block adapter
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Apr 25, 2023.
  1. junkyardjeff
    junkyardjeff
    My 55 Sunliner is set up for a C-4 and I think someone makes a adapter to put one behind a Y block but all I have found are ones for. AOD or GM.
  2. jimmy six
    jimmy six
    I believe there are 2 styles. If the C4 you have has a removable bell there is one that replaces it and directly bolts to the Y. If it doesn’t there’s a different one.
  3. Blue One
    Blue One
    from Alberta
    Flat O products. Talk to Gene.
    Mummert also sells the Flat O products kit but why order from him when you can go to the source.
  4. junkyardjeff
    junkyardjeff
    I was going to use a 62 COM with a 67 MX? valve body but why add all that weight and then have to get another driveshaft.
  5. williebill
    williebill
    X2 on Gene. Answered all my questions, and shipped quickly.
    Tow Truck Tom likes this.
  6. junkyardjeff
    junkyardjeff
  7. junkyardjeff
    junkyardjeff
    Just got off the phone and that is where I will be getting the adapter.
    pprather likes this.
  8. pirate
    pirate
    from Alabama
    Don’t know what differential gear you have but my OT Ford with a AOD runs down the interstate at 2200 rpm and 65mph with 3.89 differential. If you already have C-4 never mind.
  9. jimmy six
    jimmy six
    If your rear end is stock it will have a 3.31 if it was a Ford-O. Since the C4 starts out in low you can comfortably go to a higher ratio without any worries and have a lower rpm on highways and interstates. I went with a Ford 8.8 with 2.74’s and for me it’s great. Almost all of them have discs and many a posi. The rear end shop that built mine had a complete drum brake set up from a mid 80’s F150 which are the same 11” with a wider shoe. The stock E brake worked perfect with only enlarging the cable hole a few thousandths from metric to inch size.
  10. junkyardjeff
    junkyardjeff
    It has 3.00 gears and found out about a ready to drop in 292 that I will be looking at saturday,looks like it could have a Y block this winter.
    jimmy six and warhorseracing like this.
