who makes a good floor shifter?
Discussion in 'The Hokey Ass Message Board' started by Tim, Jul 30, 2006.
  1. Tim
    Tim
    from KCMO
    hey guys,
    looking around for a simple 14ish inch tall floor shifter for an automatic. something that with a 4 speed nob on it could look like a stick shift shifter. just nice and basic no super duper ratched airshift monster of a ****er.
    just simple.
    i like the ones lokar carries but at a speedway price of 190 bux i figured it was worth asking if anyone else has got a source for a quality product that doesnt cost quite so much.
    thanx
    tim
  2. krooser
    krooser
    I like Gennies...but that's me....
  3. Rot 'n Kustom
    Rot 'n Kustom
    Mr Roadster/Hurst made a nice one, but I haven't seen their ads recently.
    Is Mr Roadster still in business?
  4. Me too:D
  5. BigEd
    BigEd
  6. hotrodladycrusr
    hotrodladycrusr
    Me three.:D
  7. Tim
    Tim
    from KCMO
    seeing as none of those links other then the gennie one have a price on them im asuming there all about the same price wise?
    tim
  8. man-a-fre
    man-a-fre
    call summitt they should have somthing,i remember sparkomatic,mr.gasket and superior,daytona sold cheap shifters but now i suppose you could check jc whitneys also.
  9. Gator
    Gator
    from Statham Ga
    The B&M runs about $160, the Hurst goes for about $225. I think the Lokar's start at about $160 or so at Jegs or Summitt depending on the model.
    B&M and Hurst still make a very simple floor shifter for under $100, but I'm not sure if that's what you're looking for . The B&M is cable operated and the Hurst still uses rods. They're both pretty basic units, although I think the B&M does have a nuetral start switch.
    http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?lang=-1&catalogId=10002&storeId=10001&categoryId=15053
    http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?lang=-1&catalogId=10002&storeId=10001&categoryId=15115
  10. ground_pounder
    ground_pounder
    does the cheap hurst unimatic bolt to the transmission?? i got a b&m universal at a swap meet for 10 bucks, didnt like the cable setup and it bolts to the floor. i chopped the flat shift rod off, ran a few bolts through the stub and welded on a tire iron, kinda a cool little unit, but havent had a use for it yet. i got a lokar in my 55, but it wasnt cheap, but i sure like the positive shifts nice and tight. always hated the column shifter if you had any flex that would keep you guessing. thinking about making my own shift rod for the powerglide out of the 57 for the international. got a old shifter off the international manual with the bottom swivel attached. thats if i use it, thinking about finding a manual for it.
