Hot Rods Who makes a wheel well with a rolled inside edge?
Discussion in 'The Hokey Ass Message Board' started by Kirk Hanning, Feb 13, 2015.
  1. Kirk Hanning
    Kirk Hanning
    I have a friend who builds some very nice rides and he asked me if there was anyone who builds a wheel tub with a rolled edge on the inside cir***ference? In all the preformed wheel tubs it is just sheet stock joined with a Pittsburgh seam in that edge. I'm thinking he's looking for a generic tub that would have to be stamped to achieve a radius around the cir***ference.
    I included a generic picture of a wheel tub taken off of the interweb to give an idea on what he is after.
    Any help or suggestions on who would produce such piece are appreciated.
  2. 31Apickup
    31Apickup
    My first thought would be to use a trailer type fender and weld the inside panel in.
    lothiandon1940 and turboroadster like this.
  3. Kirk Hanning
    Kirk Hanning
    That's a great idea! Sometimes the simplest things are often overlooked.
    Still going to try to find a generic stamped one but if not available it'd be something to fall back on.
  4. squirrel
  5. Crusty Nut
    Crusty Nut
    I've done several with trailer fenders. Nice heavy gauge stuff too.
  6. Kiwi Tinbender
    Kiwi Tinbender
    Kirk, I`ve made my own for years. Make a Hammerform for the inner half circle, maybe even use a Tank Roll and Shrinker to refine it, then roll the top part of the tub, and do the same work on the inside edge and weld both parts together in the middle of the radius and finish to suit. All the premade tubs seem to be thin for Drag Racing BackHalf jobs, and will Star and Drum. I use 18 Gauge Material so they have strength and don`t Star when hit by Rocks. They also look neat when exposed. I`ve done several sets of these for 53-6 Ford Pickups that are Teardrop Shaped and look neat in the bed. A Shrunk /Stretched Flange for the bottom if you need it, and there it is....(And yes, it`s time consuming and not that easy to do, but you get a really nice result......)
    lothiandon1940 and Kirk Hanning like this.
  7. Unkl Ian
    Unkl Ian
    Hammer form, or round over dies in a bead roller.
  8. Kirk Hanning
    Kirk Hanning
    Thanks for all the help! He & I definitely have the skill & equipment just never really gave it much thought!
  9. https://www.millsupply.com/73-chevy-pickup-rear-wheelhouse-507375.php?p=20419
    These are pretty universal and big.
    I just made my own with 90* 3/4" radius on a hammer form. Helps to have 4 hands putting it together. Could easily do 1-1/2" radius but that's a lot of form sanding.
    Any bigger radius and I'd probably turn 2 at 45 and join them in the radius, but that's more work, less forgiving, and not worthy of a wheel well that's mostly covered. If they will be highly exposed it might be worth it.
  10. captain scarlet
    captain scarlet
    from Detroit
  11. blue 49
    blue 49
    from Iowa
    Here's one of mine going together. Particle board hammer form and HF bead roller work. welding.JPG
  12. millersgarage
    millersgarage
  13. Mr48chev
    Haven't seen those but trailer fenders run about 25.00 each at ranch and home. Still there is that satisfaction of hammering out your own if you have the skills and equipment. I'd be one of the guys at the farm and ranch store buying a fender to cut in two to make two tubs.
  14. gimpyshotrods
    gimpyshotrods
  15. captain scarlet
    captain scarlet
    from Detroit
    Sorry Jeff - slacking wot 'e said /\ /\
    millersgarage likes this.
  16. alanp561
    alanp561
    DSCN2726.JPG DSCN2725.JPG 11" x 36" trailer fender. Going to have to add 4" to the inside to fit up to the trunk sides.
    chop job likes this.
