Who makes the flattest muffler?
Discussion in 'The Hokey Ass Message Board' started by garagedoreen, Sep 18, 2011.
  1. garagedoreen
    garagedoreen
    from LA,CA
    Whats up guys. Well Im building my 64 Impala wagon and it lays frame. The fame is a "X type so I dont have much room under there as it lays frame. But I need to make a exhaust system.
    Anyways, Im looking for the flattest muffler I can find. I only got about 4 inches of clearance of were I can put it. Im fine with running a 2.25 exhaust piping or even thinking of 2".
    Magnaflow says theres are 4" thick. Is there something 3" or even less?
    Thanks
  2. junk yard kid
    junk yard kid
  3. Motornoggin1
    Motornoggin1
    SPintech makes some very thin profile mufflers. They use oval section pipe to maintain volume and flow, but reduce thickness. I have no idea how much they cost though.
  4. pimtina
    pimtina
    Check out Spin Tech.
    Quess i don't type as fast as motornoggin!
  5. VOETOM
    VOETOM
    from MO
    GD, the issue is that as the diameter of the pipe running through them approaches the case thickness, the sound reducing or absorbing capability reduces. If you want any sort of sound level control from an absorption muffler, you need at least 0.5" thickness around the center tube. So, with 2.5" through pipes, you need around 3.5" which is darn close to the 4" case thickness you mention.
    Spin Techs are very loud on powerful engine-equipped cars. But, the company makes some cool shapes and they fit very well.
    How long can you use? Seems the old X-frames could hold 18" mufflers or so? You could use really nice sounding 18" straight through mufflers if so.
    I'll look through my old Walker books to see what might fit right on.
    It is fun to make them and I may be able to get you some parts to do so. Ends up costing more than Chinese made ones but you feel good knowing you created them.
    Here is a loud pair I made for a kid's 70 dodge truck.
    Tom Hand
  6. KooDaddy
    KooDaddy
    from Wis.
    Saw one on the freeway today semi ran over it, that was the flatest one I've seen. Sorry couldnt resist!
  7. metal man
    metal man
    Stainless specialties has mufflers 2-1/2" tall total.
  8. Fullblast
    Fullblast
    flowmaster has those hushpower, they might be small enough. If you use a H or X pipe and some rezonators at the end prob give you a nice sound.
