Technical Who makes valve springs?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Jul 23, 2025.
  1. Budget36
    Budget36
    I recall some threads where a company was recommended for having springs made, but don’t recall the companies name.
    Thanks
    continentaljohn likes this.
  2. Kevin Ardinger
    Kevin Ardinger
    I think Vasco may be one.
    Budget36 likes this.
  3. DDDenny
    No reason the "average" engine build can't use off the shelf springs packaged for application.
    One or two clicks each to Jegs and Summit will bring up all you (may) need.
    Budget36 and Just Gary like this.
  4. drtrcrV-8
    drtrcrV-8
    Competition Products has been a good source.
  5. jimmy six
    jimmy six
    ^^^^^^^^ Absolutely….their catalog is almost a bible on springs. 5-6 pages of heights and pressures. Retainers (7*-10*), keepers (at 3 different heights), bases for aluminum heads, and even lash caps. Seals too for your valve guides and the tool to cut them…..
  6. Budget36
    Budget36
    Thanks gents.
    I don’t have full particulars, but this is for a friends 390.
  7. My local engine parts supplier has em
    I just tell em what # spring is needed by application
  8. Mr48chev
    Every major cam grinder sells valve springs for the engines they make/grind cams for.
  9. tjm73
    tjm73
    Tons of off the shelf options for the 390. Don't over think it.
  10. gimpyshotrods
    gimpyshotrods
    Is this a Ford FE 390?
    If it is a Cadillac 390, the answers are going to be a bit different.
  11. Budget36
    Budget36
  12. RmK57
    RmK57
    Comp cams catalog should have what you need. I picked up the one on the right as a souvenir, it’s a Comp Cams spring from Greg Andersons Pro stock Camaro.
  13. The ideaman
    The ideaman
