Folks Of Interest Who on Hamb cuts splines?
Discussion in 'The Hokey Ass Message Board' started by 1934coupe, Apr 10, 2017.
  1. 1934coupe
    1934coupe
    I have searched high and low on Hamb but can't find the guy that cut the splines on my steering for my MG. I found him on Hamb and he did a great job, that was 9 years ago. Anyone know of someone that cuts splines?
    Thanks Pat
  2. cjsavage
    cjsavage
    from eastern nc
    I cut axle and some transmission splines. What do you need?
  3. 56sedandelivery
    56sedandelivery
    Not local to you, but he's a guy I used. Jantz Engineering 20555 Pugh Road Poulsbo, Wa. 98370 (360)598-2773.
    In my case, I had to "shorten" an axle at the spline end, but then did't have enough spline left to slide in far enough into the side gears; a big oops. Also cut the centering bung off. A couple of people recommended him, and I had to hop the ferry to get to where he is from me. Did the job with no problem, and did't cost much. This was on a set of old Strange, 31 spline, Olds/Pont axles going into a 57 Olds housing, and they were too long. Only one side needed to be done.
    I am Butch/56sedandelivery.
  4. 1934coupe
    1934coupe
    Thanks CJ and Butch it's a steering shaft that was cut and shortened now we need to re-spline. I will p*** this info along to my brother. It's his project.
    Pat
