Hot Rods Who overseas owns this '32 5w?
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Sep 26, 2015.
  1. Eric1967
    Eric1967
    from Union, Mo
    Wishbone
  2. Eric1967
    Eric1967
    from Union, Mo
    Frame
  3. Eric1967
    Eric1967
    from Union, Mo
    Flathead
  4. thirtytwo
    thirtytwo
    Hard to see whats going on with the rear suspension, but I can say where you wanna go .. Some of that needs to be ditched , that crossmember direct above pumpkin needs to go for sure...
    Your right ,complete 42 front ... Whats the steering?
    If I were doing it for you as a customer and you wanted cheap and simple , I would get 40 wishbones for the front , split them , put on a model A drop axle , get 28-34 perches and spring , model A front cross, for the rear a 40 rear spring , a simple tubing crossmember like so-cal does and either Pete and jakes ladder bars or some 35-36 rear bones
  5. Eric1967
    Eric1967
    from Union, Mo
    The steering was a cobbled up mess. It had some kind of GM box. I pulled it off. Thinking of going Vega box. They cut the frame to clear the box. I will have some work to do there.
  6. thirtytwo
    thirtytwo
    I can't see if frame is boxed but I would be tempted to put a f-1 or f-100 box in it
    It's harder for a novice to figure out right away, but if you can fabricate it shouldn't be too bad you can rebuild one yourself for 50-200$ and you don't have to worry about columns, borgson joints , double d shafts, and a panhard bar
    If you get a certain years f-100 steering gear it has a longer sector shaft , you can get an aluminum wedge Vern tardel has an it becomes pretty much bolt in affair... Besides cutting holes
  7. A Rodder
    A Rodder
  8. Eric1967
    Eric1967
    from Union, Mo
    I think you are referring to the steering box that goes thru the frame rail. That maybe an option. Not sure the Vega box will clear the motor mounts
  9. thirtytwo
    thirtytwo
    That's a wierd set up looks like truck pulleys on a 49-53 car pump ?,if it were me I would use the standard style pump with ford biscuit mount
