Who re-works stock 6v gauge clusters for 12v operations and how much?
Discussion in 'The Hokey Ass Message Board' started by TERPU, Sep 11, 2006.
  1. TERPU
    TERPU
    I need to have my '54 Chevy gauges re-done to work with 12v and a small block. I was wondering who would I send it too and about how much does it cost.
    Thanks, Tim
  2. BobbyD
    BobbyD
    from Belmont NC
    Go to a good parts house, tell them you want a voltage reducer for the gauges for a 66 mustang, standard part # vrc603, put that in-line to the power source to the gauges, done deal..........
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    The mechanical oil pressure gauge isn't high enough for a SB. Instead of changing it i just used the 0-30 psi gauge and as long as it stayed pegged I was happy. The rest of the gauges can be adapted with a voltage reducer as said before. Dont pay to have them redone. You dont need to do that.
  4. pistinbroke
    pistinbroke
    Be careful, that's funny Petejoe!! Thanks for the info on the reducer BobbyD, not to high jack the thread, but I was getting to the same point in my build and was wondering this as well. Good question TERPU, thanks for asking.
  5. Scotch
    Scotch
    Cl***ic Instruments offers this service, but I couldn't tell you how much they charge. It's best to call and ask them directly.
    They are a top-notch operation...I'd trust them with any of my stuff.
    ~Scotch~
  6. TERPU
    TERPU
    Thanks to all, will the fuel sender work? I have a 6 volt and a 12 volt, if I drop the voltage to the gauge which one do I use? Alternator same question, how does it work Mr. Wizard? I like the oil pressure suggestion. Lastly the temperature gauge, how do I make that work.
    I know enough questions,
    Tim
  7. Automotive Stud
    Automotive Stud
    I don't think any of the senders need to be changed. They get power from the gauges, which you already used the voltage drop to bring back to 6v, so they are fine.
  8. Paul Windshield
    Paul Windshield
    Yeah that's what I did.
    Paul
  9. Paul Windshield
    Paul Windshield
    I did the ford voltage reducer thing. Went Schuks autoparts and asked for a gauge voltage reducer for a 64 falcon.
    Paul
  10. Dakota
    Dakota
    from Beulah, ND
    I got a quote from CL***ic instraments to have the factory Panel redone in my 49 Chevy. $3,200!!!!!!!! i about fainted.
  11. UPSrodder
    UPSrodder
    You will need 2 voltage reducers, One Low amperage for the guages, this will work the sender for temp(if electric) and the fuel. One High amperage for the heater motor if its still 6Volt. You can also do a search for the 6 to 12 volt conversion on here if you aren't sure what else needs to be done.
    Alternator will be internal regulated or external regulated. How you wire it will depend on the type. Just some of the basics. There is also a good book out there on the complete conversion, not sure who published it.
  12. stickylifter
    stickylifter
    from Detroit
    I had gotten a quote form a place in Howell, MI at around $80 per guage... that means you're looking at around 320 bucks. The speedo will work if you hook it up to a T350. It's a little off, but you get to know it and you can make some good educated guesses as to how fast you are going. :) I use the chevy mechanical oil pressure for now and an Auto Zone temp guage that's mounted under the dash. Screw the ammeter. I think I'll know when my alternator is dying. :)
  13. burger
    burger
    Rather than playing with the stock ammeter, use a Chevy 3-wire 10SI or 12SI alternator and wire it to trigger a dash warning light. Who really sits there and watches thier voltmeter/ammeter anyway. Here's a thorough article on the 3-wire alternator.
    Hope this helps,
    Ed
    PS- On Chevy Advance Design trucks, you need to wire a voltage reducer into the fuel level sending unit or you'll fry it with 12V. Not sure how things worked with the p***enger cars, but I'd definitely do some research.
    PPS- Most parts suppliers sell individual "converted" gauges for the Advance Design trucks. You can buy an oil pressure gauge that reads to 60 PSI, a temperature gauge that's set up for the small block, etc. If you don't already have one, get a Chev's of the 40's catalog and see what they offer.
  14. Automotive Stud
    Automotive Stud
    Famous last words! I had a battery cable starting to corrode internally. Car started fine. Drove about 5 miles, went into the store, came out, started right up again, drove another 10 miles, went inside for 5 minutes, came back out. Dead :mad:
    Now the amp gauge works!
  15. Ragtop
    Ragtop
    I couldn't find anyone that recognizes that part number. Ford dealers in Canada said it was a US number and the Us Dealers said it was obsolete and gave me a different niumber that was also obsolete, however, this number was good at Napa and the guy (in Canada) had it for me the next day. The Napa store in the US said he could get in a day too. Ford number 39MZ10804C and the Napa number was IRI ECH
  16. thekid
    thekid
    from PDX
  17. overspray
    overspray
    I was thinking of looking in the junkyard for 12 volt fuel and temp gauges that would be close enough to swap into the 6 volt instrument panel, even if could swap the electrics onto the original gauge face/dial or find something close enough for a "bolt-in". You could probably find a 12v sending unit that would swap also. This would be much less expensive. My local yard has a wide variety of stuff-and I enjoy the hunting. Mechanical temp, oil and maybe some amp gauges would not need to be changed.
    overspray
  18. squirrel
    the only gage that actually runs on 6v on a 54 chevy is the gas gage, you can use that voltage reducer mentioned, or use a 7806 electronic voltage reducer (this one needs a good ground too), put the reducer in the power feed circuit for the gage, not in the sender side of it.
    speedo, temp, oil, ammeter, etc will all work as is, although the temp and oil gages will be running high most of the time.
  19. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Haha I do when its nighttime and my turn signal is on at a light! Tick (up) tock (down). Darndest thing not having a radio for so long...
  20. overspray
    overspray
    squirrel--is the gas gauge sender voltage sensitive? If not, it would be easy to swap a 12v gauge into the cluster (GM IH Mopar), except maybe with Ford fuel senders.
    overspray
  21. squirrel
    the mid 1960s and older GM gas gage senders were all 30 ohms, you can use them with either 6 or 12v GM gages, but it's nice to use the correct voltage to feed the gage
  22. markanthony
    markanthony
  23. Thunder Road
    Thunder Road
    VRC603 = VRC604, same thing, just mounts diff.
    I got mine at Carquest.
