Who restores "old Plates"?
Discussion in 'The Hokey Ass Message Board' started by Oldmanolds, Nov 10, 2006.
  1. Oldmanolds
    Oldmanolds
    Anyone know somebody that restores old state auto plates?Plate is in good shape.. just needs a steady hand to repaint it.Dave
  2. Here ya go.......hope this helps. D
    http://www.tagdr.com/
  3. Elrod
    Elrod
    you can use a decopage roller to roll on those numbers. a rubber roller about two inches wide rolled in some one shot paint. looks beautiful.
    use an eye liner pointed sponge you would find in the cosmetics area of walmart to fill in any mistakes.
    Or call gerald thiele. $40 a plate from start to finish.
    940-553-4000
    940-552-2038
    http://jalopyjournal.com/forum/showthread.php?t=133560
  4. Katuna
    Katuna
    from Clovis,Ca.
    Damn fine web site. A little rich for my blood but if you have the need, he does some sweet work.
  5. Stick Shift
    Stick Shift
    from LENA IL
    I believe John Berry in Davenport Iowa does them. His business is Phoenix Restorations (I think). He does gauge restoration too.
  6. i did the one for my house in spray can......starting to fade have to redo it in auto paint but it was easy. pound out any dents, blast plate, fill if needed, prime, paint with letter color first (a few coats to get it thick), paint plate color (a few thin coats just to get the color), let cure, wet sand off the plate color on the letters/numbers (i started with 400 and finished with 800) until you have reached number color, then clear whole plate..............done. took me about 3 days after work with a heat gun to speed up drying.
  7. Phat Gio
    Phat Gio
    Plates look great, oldtimer! Thanx for the tip. I'm getting ready to restore a set of black Cal plates.
  8. hotrodladycrusr
    hotrodladycrusr
    Ray Smith, Safariknut here on the HAMB, did my Dad's '56 plate for his Olds. Looks totally awesome. PM him for price. He's in Michigan
  9. fordy7coupe
    fordy7coupe
    from Wylie, TX
    Here's an easier way to repaint old plates, and it doesn't need a steady hand. Say you want black background with white characters. Clean up the plate...rust, dents, etc., and prep it for painting. First spray paint the face of the plate with several coats of white, get it thick (or powder coating works real good). Let the paint dry real hard. Then, spray paint the whole plate (front and back) with black, just enough to hide all the white. After it drys good and hard, get a sanding block and holding it flat, sand off the black paint from the tops of the letters and numbers until the white characters are exposed. If you got the white thick enough it won't sand thru. If you get too heavy handed you can touch up. Then clear coat the plate.
  10. Sawracer
    Sawracer
    from socal
    i am painting my new ones old colors, or having the $40 dude do one for me.
  11. fordy7coupe
    fordy7coupe
    from Wylie, TX
    Doh, I started writing my repaint instructions earlier today before I saw 1oldtimer's response. Well, what do they say about great minds?
  12. Jeff Norwell
    Jeff Norwell
    MODERATOR
    HIRE A HAMBER
    Safariknut!!
