Technical Who sells door fuzzy strip retaining clip 1949-51 Ford
Discussion in 'The Hokey Ass Message Board' started by rob-redm, May 30, 2014.
  1. So I'm working on the 51 Woody...Replacing the door glass fuzzies that brush against the door glass. So after 63 years the reatining clips are no good... Looked in my Dennis Carpenter catalog, and Bob Drake... with no luck... Does anyone know were to get them or what may work instead ? Will putting the passenger door back together next week... Maybe someone has the Ford part number I could search for.. Thanks Ole Redwood
  2. oldsman41
    oldsman41
    not for sure on this but try macs and synders also.
  3. Mike51Merc
    Mike51Merc
    Try Restoration Specialties.
  4. ebfabman
    ebfabman
    Dennis Carpenter ???
  5. AlbuqF-1
    AlbuqF-1
    from NM
  6. ryno
    ryno
    Try shoe box central in okc ok
  7. plywude
    plywude
    from manteca ca
    I pop rivered mine on right thru the fuzz and then painted the heads black you really can't see them ...
    good luck
  8. Russco
    Russco
    from Central IL
    The vintique ones are pretty nice and I just used them and some very small black oxide sheet metal screws for the garnish moulding side rather than the factory "staple" fasteners. Both came from Vintiques and worked great.
  9. 302aod
    302aod
    from Pelham,Tn.
    When I worked at a Ford dealership we called them cat wiskers. I think that was a universal name for them around this area.
  10. seb fontana
    seb fontana
    from ct
    Concours Parts...800-722-0009...if they still around..
  11. Thanks guys if anyone has a part number they can share with me that would be great...
    These are more a " S " style clip...these crimp over the wisker brush LIke the truck and 36-39 Ford clip, but slide over the top edge of the sheet metal on the door frame...
  12. plywude
    plywude
    from manteca ca
    I have a window felt kit in front of me that was sold by Dale's Manufacturing Co. a complete kit for 49 thru 51 ford Convertible, their part # is 8A-7621452-3-K. They make this they should know about your clips. Their # is 405 631-8988
