Who sells ring and pinion ford 8 in
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Aug 14, 2010.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I have early mustang rears ,Who sells ring and pinion or posi units
  2. Jimv
    Jimv
    speedway, jegs & summit.Not that cheap though. I never see them at swap meets.I always look.
    One place ya might be able to get them is at a Ford dealer.
    Let me know how you make out, i'm looking for a set of 3:50-3:75's
    JimV
  3. coupster
    coupster
    from Oscoda Mi
    Google 8 inch Ford you will get a bunch of vendors. The bay has a pile of listing also.
  4. Set up a Jegs ring and pinion yesterday, wasn't marked with the pinion depth. No luck with the Jegs phone monkeys.
    Buyer beware
  5. I got a friend that swears by Jegs but I am partial to another catalog speed shop.
    No one has mentioned Summit Racing so I'll through that one into the fray. I'd say you can mention me when you call but that and a couple of bucks would get you coffee at the local diner. :D
  6. Da' Bomb
    Da' Bomb
    Good luck. I just went through the cost estimation for an 8".....About $1400 to have a limited slip and gear change built. You can save a couple hundred by doing the build your self.
    I went the 8.8" route, 3.55's and limited slip for $200 plus the new drive shaft and spring hangers etcetera
  7. boutlaw
    boutlaw
    8 inch stuff is definitely more expensive, but available. I have an 8 inch in my OT 66 Mustang and had some difficulty even 4-5 years ago getting posi parts/ring pinion, bearings etc. The local drivetrain store can get everything needed, but they generally have to order, but I know its available, just not stocked like 9 inch stuff. When I took the Mustang to Bonneville on 09, I destroyed a pinion bearing because the pinion nut/crush washer was over torqued and was worried that the only
    Auto Parts store in Wendover could not get a replacement. I called my local drive train people to get the correct bearing number and the Wendover guys got it overnight from Salt Lake City. Repaired it overnight on the "Save the Salt" blue tarp.
  8. Moneymaker
    Moneymaker
    We sell new 8 inch ring and pinions and new Auburn posi units.
    Gears are not bad but
    as stated, the posi units are not cheap.
  9. treb11
    treb11
  10. We got a R&P set from Richmond Gear......lots of miles and some "abuse" and no issues at all.
  11. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Man this is an old thread ,I decided to use what I have,,,,,,,,But thanks took 2 years
  12. hotroddon
    hotroddon
    Except the first guy to answer 5 months ago :D
  13. MikeRose
    MikeRose
    from Yuma, AZ
    More like almost 2 years ago. :p
    I feel good about how much I spent on my 8inch. I got the whole housing with brakes, a rebuilt center section with an almost new ring and pinion and auburn posi for $800 setup.
