Technical WHO was the Einstein that came up with this 'great'idea ?...
Discussion in 'The Hokey Ass Message Board' started by 6sally6, May 29, 2025.
  1. 6sally6
    6sally6
    The good old simple/reusable/dependable/very affordable/and available everywhere HOSE CLAMP.
    You know the ones with a 3/8" or 5/16" nut (with a screwdriver slot!!) on top...
    Great for small hoses to HUGE hoses....
    You know the ones...........
    WHO was the Einstein that decided..."Hey...let's switch 'some' of them over to metric !
    But not one of the so-called "common" size metric...noooo.. let's use the 7MM size! That way..these poor do-it-yourselfer-wanna-be-shade-tree clod mechanics will need a whole fist full of sockets/drivers/ratchets/screwdrivers to turn a simple 5 minute job in about a 1/2 hour ! Stomping back and forth to his tool box looking for 'just the right size tool !":p:p:p:p:p:p:p:p YEAH.. dats a great idea !
    Thank you for your attention !
    6sally6
  2. TagMan
    TagMan
  3. 19Eddy30
    19Eddy30
    from VA
    This started in mid 90s when
    Supplier , Vendors , Companies
    Moved manufacturing to offshore's
  4. tomcat11
    tomcat11
    Tell us where you bought the clamp so the rest of us can remain pain free:D China bean counters at work again!
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Never seen a 7mm standard screwdriver.
  6. Hotrodmyk
    Hotrodmyk
  7. vtx1800
    vtx1800
    Glad I have a drawer of old hose clamps....although the ones I have for 3/8" hose are dwindling, although it can be tough finding enough with the same size socket for one car!
    Deuces, hrm2k and bschwoeble like this.
  8. twenty8
    twenty8
    Try using a 9/32" socket..............o_O;)
  9. LOL!
    Ben
    Deuces and hrm2k like this.
  10. G-son
    G-son
    from Sweden
    Most of the world is metric. Might be time to join in. ;)
    Ned Ludd, Driver50x, Bcap55 and 5 others like this.
  11. 05snopro440
    05snopro440
    I have both metric and standard sockets (and wrenches) in my box, because the stuff I work on is never just standard. All my hose clamps work with my standard 1/4" drive sockets, but if I ran across one that wasn't there sure wouldn't be a 25 minute delay because of it. Sounds like you just need more tools.
    I mean... Most vehicles made in the last 30+ years are primarily metric if you work on other vehicles than just your hot rod.
  12. snoc653
    snoc653
    from Iowa
    Sounds like the perfect excuse to start a new traditional hot rod project. Tell the wife you have to build it to save your sanity.
  13. squirrel
    7mm is very common if you work on cars less than 40 years old.
    I got some clamps that had heads that were not 7mm, not an inch fraction, not a MM size. And the combination slot/phillips did not work for either. They hit the trash can pretty quick.
    But seriously, folks who work on modern cars would only use a 1/4" nutdriver on hose clamps, they don't fit anything else made recently. And they'd use an 8mm on the common hose clamps that have a 5/16" hex.
  14. 51504bat
    51504bat
    I don't care if it's standard or metric but what gripes me is when both are on the same car. Take a Ford AOD trans. It has "Metric" embossed on the pan. WTF? But I guess it could be worse. I could still be messing around with English cars and Whitworth spanners for British ***ociation bolts and nuts.:cool:
  15. evintho
    evintho
    I'm a big fan of the metric clamps cuz I get 'em for pennies or even free at the local Pick-N-Pull. Next time you're there, mosey on over to the european section and grab a handful. They range from 1/4" (or metric equivalent) up to about 4". Most are made in Germany and they're much more robust than the cheap american pieces.
    The german ones are louvered instead of having just stamped slots and the edges are rolled unlike the american pieces. Much better holding strength, they don't dig into rubber and they won't strip!
  16. I never thought I would come across a metric bolt or nut on my Model A, then I started fixing an oil leak and transmission mount.
    After crawling under the car a few times I found 2 metric bolts for the mount, 1 nut for the shift shaft.
    I have come across pesky hose clamps, they occasionally get cut off and they get replaced with an IDEAL brand stainless one.
  17. @squirrel had a post or answered a post about old hose clamps with a round head and slot only. Sent me down a rabbit hole......now I have a bunch :D.
    To the O.P, it's global market and we're one of the few countries to still use the imperial system (and our own version to boot).
    05snopro440 likes this.
  18. 49ratfink
    49ratfink
    progress is *****
    squirrel and 05snopro440 like this.
  19. 41 GMC K-18
    41 GMC K-18
    And don't forget these monsters, with the wrong pliers, they can be frustrating !
  20. arse_sidewards
    arse_sidewards
    from Central MA
    Stop using the ****py little 1/4" hose clamps and this problem goes away because. The larger size clamps are toleranced such that both 5/16 and 8mm always work
  21. 19Eddy30
    19Eddy30
    from VA
    Gm trucks 90 to I think 97ish
    SAE threads Metric heads ,
    I have been running into Metric nuts sizes with SAE threads lately Big Box Store ,,,
    Most modern worm clamps are very cheap made , When I see old ones I grab Also ,
  22. CSPIDY
    CSPIDY
    I save all of the old clamps that I find
    most of the new clamps fail when you try to really get them tight.
    it’s not the metric system that makes them junk, it’s the material and design that makes them junk.
    Model A spark plugs have metric threads
    Stogy, rod1 and 05snopro440 like this.
  23. Greg Rogers
    Greg Rogers
    Battery clamps too! I go to chage battery and take 1/2" wrech with me, then find newer ones use a 12 mm, just enuff smaller that will slip..
  24. clem
    clem
    vise grips usually get them off, or a grinder.
    I don’t have the spe******t tool or patience to get them back on, so the rubbish bin is usually the next stop for them !
    41 GMC K-18 likes this.
  25. 05snopro440
    05snopro440
    Most spark plug threads since the early 1900's are metric.
    Here's an interesting read that explains a bit of why that is. https://www.wiseautotools.com/blog/...g-sizes-and-the-influence-of-albert-champion/
    dogwalkin likes this.
  26. larry k
    larry k
    The older I get , the more I hate change !!!
    Deuces, Alaska Jim, jaw22w and 10 others like this.
  27. 05snopro440
    05snopro440
    Here in Canada we tend to use both despite not officially having the imperial system since the 1970's. Mainly because continued efforts to officially change some products and measurements were halted in the 1980's. Construction and piping tends to use imperial, but when I renew my driver's license I give my height in feet and inches and weight in lbs and when my license arrives the measurements are in cm and kg. As an engineer we use both, but for precision measurements mainly use imperial. We have to know and understand both. We measure temperature in Celsius, volume mainly in litres or ml, and driving distance mainly in km. Shorter distances are imperial.
    The metric system is simpler and more logical, but for no good reason we still use a lot of both.
  28. Paladin1962
    Paladin1962
    Funny; I just bought a few Whitworth spanners for my Morris... unfortunately 60-70 year old nuts and bolts are rarely the original size
  29. squirrel
    When GM started to go metric in the 70s, they went slowly...one of the things they did with the old transmission designs was to change the hardware that interfaced with the rest of the car, so the shift shaft threads and rear mount threads changed, but the rest stayed the same. They also went to metric power steering pumps and AC compressors, so you'd need a 15 and 18mm socket, along with fraction inch sizes, to change a water pump on a 350, for example.
    There's no easy way to keep two systems going. It's just one of the little challenges of life that you can meet, or give up and sit on the couch and watch TV instead.
    Deuces, alanp561, rod1 and 7 others like this.
  30. Fortunateson
    Fortunateson
    I agree that those German hose clamps are extremely good. I also like the ones you pinch with pliers to tighten. Kind of a one use thing but they get things TIGHT!
    Now if you don’t have metric sockets I’m sure if you toddle down to your American version of Princess Auto (HF) you could find an inexpensive set...
    My wife is going through a “policy” situation with GM about a shifter on her autotragic OT car. The policy is good for 18 more months and the only part they can find in NA is in Texas and the dealer wants $500 for it and GM will only cover $150! Now the dealership has had the car for 1 1/2 months which is WAY more frustrating than a measly hose clamp...
    ffr1222k and 05snopro440 like this.
