who works at a wrecking yard
Discussion in 'The Hokey Ass Message Board' started by Boones, Nov 27, 2012.
  1. Boones
    Boones
    from Kent, Wa
    I am trying to figure out what a fair price to pay for a Chevy LS series motor (5.3 or 6.0) out of a truck or suburban. the prices locally here in Seattle seems high for motors with 70k - 100k miles. I realize the lower the mileage the more it cost but I am looking for average prices in other areas of the country. I figured it might be cheaper to have one shipped in than it is to buy locally.
    I want to use one of these motors in my next project as you can not beat the power potential nor the mileage you can get and the hood will never come open so what you can not see will not hurt you.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Ken,,send Randy a PM,,he helps Scott at his huge yard near Lexington,,I'll bet he can help. HRP
  3. raidmagic
    raidmagic
    I have a 5.7out of a WS6 with the harness and all accessories I'm asking $3000. That is about avg for a LS around here. You can get the 5.3 much cheaper
  4. Truckedup
    Truckedup
    5.3's from PU trucks go for 500-1000 bucks retail around here depending on mileage ...Truck 6.0's are more,all aluminum car LS engines a lot more.
  5. oldolds
    oldolds
  6. I picked up an entire Silverado drop out swap for 2200.00
    All from the same vehicle
    40k 5.3 engine
    40 k 4l60e
    Harness with fuse box
    Computer.
    TAC module
    Gas pedal
    Radiator
    All engine accessories
    Shorty headers
    factory crossover pipe with convertors
    Fuel sending unit
    And a box full of junk
    I did have to wait on it though,
    Told the guy what I wanted and he said next one would get taken apart as I asked if I left a deposit.
    You can't beat the 5.3 swap.
    My daily driver has 110,000 on it and it runs as good as it did with 10,000
    The swap has another 40 k on it so that's 80k and still runs perfect.
  7. bustac
    bustac
    Look around you can find 5.3's for less then $800 plenty of power and plenty of upgrade options.
  8. Brandi
    Brandi
    You might give East Side Auto Wrecking in Bremerton a call. Word on the street is they are folding after the first of the year and everything's getting s****ped. They may have something and be willing to deal.
  9. GREASER815
    GREASER815
    When I see them around here, they are in the $1000 range.
  10. flamedabone
    flamedabone
    You can LS all you want, but you still won't beat me.....
    :p -Abone.
  11. Deuce Roadster
    Deuce Roadster
    :confused::confused:
    In my area of the Carolinas ... a 6.0 core block is around 600 dollars ... if you can find one. Almost no hobbyist has them as of yet ... due to them not being made in high numbers and them being usually late model stuff.
    I recently SOLD ( at the Scott's salvage yard ) a late model Silverado 5.3 --- engine, transmission, computer, wiring and the drive by wire gas pedal for a little over 3 grand ... It was for a nice 32 Ford sedan. :)
    It is in the 32 now and runs nice. Great mileage and good performance.
    It was a 20 thousand something mile engine/transmission combination.We have 3 or 4 decent, good running 350 Chevrolet engines ... with the old style oil pan seal for around 600/700 dollars.
    I myself, would go with the older style 350 ... because of no computer and a regular gas pedal. I do not like the drive by wire type in a old rod. PLUS the newer engines do not look as good to me with all the sensors, wiring and stuff.
    BUT ... they are coming ...
    and more and more folks will learn to adapt them and use them.
    Most of the prices I have seen listed in this thread are quite low ... and most likely could not be found in my area for that type of money.
    But like anything ... price is determined by SUPPLY and DEMAND.
    In a good bit of the USA ... a 4 or 5 year old vehicle is rusted out ... and driveline parts are more plentiful there. Here ... driveline parts wear out before rust is a issue.
    Boones ... call me
    we have a Nationwide hot line and I might could find you something in your area.
    Randy
  12. Inch per inch and boost for boost to make fair ?
  13. raidmagic
    raidmagic
    Keep telling yourself that...
  14. eberhama
    eberhama
    I work at a late model yard, and the prices are around 600-800 for a 5.3 with 100-150K on them, 900-1200 for a 6.0 with about the same miles(engine only, no acc's). The ones with close to, or over 200K we have to core out because no one will buy them. Maybe look at 4.8s? We cant give them away. In our area its nearly impossible to find a 2wd truck with enough options to have a 5.3 or 6.0 and not have 300K on it, so complete set ups are few and far between.
  15. 296 V8
    296 V8
    from Nor~Cal
    I wouldn’t worry all that much about mileage. The one in my 99 Silverado has just under 200 k on it and runs perfect …… and I clip my toenails daily w the intake valves. :D
  16. Boones
    Boones
    from Kent, Wa
    Thanks everyone for your input. maybe the prices here are not to far out of line. 5.3 without the accy are going for a grand or more and 6.0 for 1500 to 2000. (these are all 100k miles or more. I prefer a cast iron block as they seem to handle boost alot better. (mine will be getting a turbo or two.)
    Randy, thanks for the offer..
    Flamedabone, it will take 500 plus inches of pontiac with a huffer to hang with a 6.0L and single turbo motor on the dyno LOL.
  17. I recently SOLD ( at the Scott's salvage yard ) a late model Silverado 5.3 --- engine, transmission, computer, wiring and the drive by wire gas pedal for a little over 3 grand ... ........ Great mileage and good performance.
    That sounds like a great deal for a 20k drive line.
    Some guys want the entire drop out and that seems to contain more value buying it that way.
    Some guys just want a block and will run a carb and distributor and custom accessories and then wind up with 10 grand in it before it putters
