1952-59 Ford whoa man
Discussion in 'Off Topic Hot Rods & Customs' started by elkomn, Apr 12, 2012.
  1. elkomn
    elkomn
    from Minnesota
    Just discovered groups here on the hamb., too cool. Can someone please post a close up detail shot of trunk lid seal on 55-56 car. Tore it off before repaint and did not look. Now I am on my second new seal. Need orientation and placement (how far in on the lid) thanks a bunch
  2. Retro Jim
    Retro Jim
    It gets glued to the truck lid . Start at the bottom center and work around the truck lid . Use some tape to hold in place . It needs to line us so it sits down in the groove when the truck is closed . just measure and you are good to go .
    Not sure what else you need to know .
    Jim
  3. elkomn
    elkomn
    from Minnesota
    That part is easy but there is a fine line between being in the right place and not. My first try was not. Just looking for what kind of gap from outer edge of trunk lid and the orientation of the gasket itself. What side gets glued and the (direction?) of the narrow versus wide part. I know what did not work and dennis carpenter, macs, tbird, concours noone has a picture and dimensions. Again, a pic if you please thanks ford guys
  4. 56FRLN
    56FRLN
    I'll try to remember to snap a pic for you when I get home tonight.
  5. 56FRLN
    56FRLN
    Basically the inside of the "U" faces the inside of the trunk lid all of the way around. Hopefully this makes sense.
