Features Who's Building a T?
Discussion in 'The Hokey Ass Message Board' started by Slimegreeeeeen, Nov 19, 2011.
  1. GuyW
    GuyW
    ...just awaiting my DVD order....
  2. MMM1693
    MMM1693
    Had to cut up my Howells deck lid to make it fit. Made my own inner support.
    26 T Ford RPU and loudbang like this.
  3. DesmoDog
    DesmoDog
    Grrrr.... but I'm trying not to stress about it until it needs to be done.
    loudbang and 26 T Ford RPU like this.
  4. Them repop deck lids are kind of pricey and originals are hard to find to say the least. I went the 3/4 square tubing, heat and bend for a frame, then skin 20150707_161304.jpg
    jimgoetz, MMM1693, loudbang and 3 others like this.
  5. Blue One
    Blue One
    from Alberta
    I had an original deck lid along with a really cherry 27 roadster body that I had in a shed for over 20 years while I was trying to make a living and raise my family.
    I became so disillusioned with the whole thing that I gave up on being able to build it and sold it.
    Crated it up and shipped it out to Hortons in Ontario for a guy who had them build it for him.
    I had a wife that’s now an ex who wasn’t supportive of the hobby and I had pretty much given up on the dream.
    That was quite a while ago now.
    loudbang, AndersF and 26 T Ford RPU like this.
  6. jimgoetz
    jimgoetz
    Good looking job. I thought about doing the same thing but I wanted to keep the original look. The two round spots are where the gas tank mounting straps were brazed on and a little bit of the 1952 paint when this thing was first built. I have "Not Fake Patina" with two arrows pointing at them now. DSCN1182.JPG
    loudbang, Jet96 and 26 T Ford RPU like this.
  7. goldmountain
    goldmountain
    Here is my latest deck lid attempt. I had stuffed a piece of wood in the trunk opening and traced the curvature on it and cut it with my bandsaw for a template. Also made templates for the curvature under the rear window and the top of the panel under the deck lid. IMG_1358.JPG
  8. goldmountain
    goldmountain
    I had a piece of leftover fibergl*** sheet from my old teardrop trailer project. This stuff is available from places like Home Depot in 4X8 sheets. It has a pebbled texture on one side and smooth on the back side. I find that it is commonly used in the washroom facilities at campsites. I cut the curved side pieces out of this with two layers per side glued together with kitty hair body filler. IMG_1375.JPG IMG_1376.JPG
  9. goldmountain
    goldmountain
    I made the top and bottom pieces out of s**** wood cut to fit the contours of the templates I had made previously and screwed them onto the side pieces with drywall screws that I countersunk. IMG_1377.JPG
  10. goldmountain
    goldmountain
    Incidentally, the deck lid is a t****zoid shape so there are not a lot of 90 degree corners anywhere. I made this with an 1/8" gap along the sides and the top edge tucks under the rear window frame. I managed to find one trunk hinge and made a mirror image for the other side. IMG_1366.JPG IMG_1367.JPG
  11. goldmountain
    goldmountain
    Now I am at the point where I am adding horizontal straps and little vertical ones. This is getting a lot stiffer. I have leftover stiff paper from my 3 piece hood pattern making exercise for making the outer skin. IMG_1379.JPG IMG_1380.JPG IMG_1381.JPG
    oldandjaded, OFT, swade41 and 9 others like this.
  12. goldmountain
    goldmountain
    This should theoretically be like doing drywall where I screw the fibergl*** sheet to the wooden framework but the various curves in the panel could possibly be my downfall.
    irishsteve, Jet96, loudbang and 4 others like this.
  13. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^^^ Like that a lot. Years ago when there were HAMB Tech Weeks things like that were worthy of prizes. Bob
  14. GuyW
    GuyW
    Received it and watched it. Good stuff and I know I'll be studying it at length.
  15. goldmountain
    goldmountain
    Went to the next step of making the pattern and since the framework is mostly wood, thumbtacks work great. No silly rare earth magnets needed. Next problem was how to mount the fibergl*** sheet on straight since it is a whole lot stiffer than the paper pattern. Established a center line and went off that, hoping for the best. IMG_1382.JPG IMG_1383.JPG
  16. goldmountain
    goldmountain
    Drew lines where the horizontal bars were to screw to and started from the center. Just making it up as I go along. Started out easy but going to the reverse curve on the top became a struggle so out came some clamps. IMG_1384.JPG
  17. goldmountain
    goldmountain
    Just as I feared, mounted the thing crooked. On the plus side, once the clamps were used, the fibergl*** sheet pulled into place quite nicely. My fears of the mild compound curves were unfounded. Kitty hair should fill the gaps. I decided to mount the sheet with the textured side out ***uming that it would give me more surface area for the kitty hair to adhere to. Have to fill in the screw holes anyhow and I'm sure that there will be low spots that will have to be dealt with. Overall, I am quite pleased with how this is turning out. I have very little money invested in this, mainly wood screws, thumbtacks, a sharpie, and a tub of kitty hair body filler so far. For anyone following this who want to copy, Lang's Old Car Parts have the trunk hinges available. IMG_1385.JPG IMG_1386.JPG IMG_1387.JPG
  18. Wayne looney
    Wayne looney
    from Roanoke va
    I have one you can have , complete with bullet hole
  19. Tall t 26
    Tall t 26
    I have had my 26 T sedan for awhile.
    It's got a 327
    350 turbo
    Quick change rearend
    Cawl steering.
    It is fun to drive, easy to work on. Been a great car.
    I have also been building a 26 T coupe for about two years now.
    It's got a 383 stroker, 700r4, and a ford 9" positive rearend with 3.50 gears.
    I bought the body here in Missouri and started with that. Built the frame 2x3 square tubing then moved on to making it a rolling ch***is. This last summer I built the floor and roof top. Once I gather all the pics I would like to do a build thread on it. Still have the steering gl*** and interior to do, and hopefully work out any bugs. Thanks for looking.
    brEad, Stock Racer, AndersF and 4 others like this.
  20. fiftyv8
    fiftyv8
    from CO & WA
    I like those wheels on your Tudor.
  21. Blue One
    Blue One
    from Alberta
    Sitting here relaxing with my new I-Phone 11, pro trying to stay warm.
    Weather like this (-26C with a wind) makes me want to hibernate :D
    Going outside reminds you that you’re still alive :)
    My day started out with my Stihl backpack blower cleaning snow from my driveway and sidewalks.
    Now I’m day dreaming about when I can get my RPU out and go for a ride.
    I had intended to get the upholstery done this winter but I’ve been chasing other little things like small leaks and minor stuff.
    I switched to a better cooling fan and then cut down a deep aluminum transmission pan to stock size for better sealing and ground clearance.
    I bought a set of exhaust hoses to vent the exhaust through the door of the garage so that I can run it to set the timing and tune the carbs
    But it’s even too cold to cut the hole through the door to install the exhaust hose porthole.
    I do have other things to do but right now I’m thinking about warm days and fun cruising. :cool:
    5B84C876-F337-4846-985B-27341DDEBD64.jpeg 09BAF84B-3EF0-4DF5-B7D9-B8B26D847ACF.jpeg BC2F7356-B07E-4D95-A09B-30CC2E036DC3.jpeg 848EE7C7-EA8A-4B6E-A192-F7E0CBA7A01F.jpeg B577AFE2-1693-4DC2-8C2B-F4E7B7C90133.jpeg 475FAD41-CDC9-4253-813A-49933C7FC47D.jpeg E2B400E7-0661-4B70-AD04-560571C297B8.jpeg FCA67B68-8698-42FF-B016-EA400D9ECE20.jpeg ACA32D78-53A8-415C-AF78-16B1471433BD.jpeg
  22. ENess
    ENess
    from Illinois
    Start build 35 yrs. ago now retired so end in sight. 27 2dr. shortened to a club cab, full fendered, home made box, 351 Windsor and lots of odd parts.
    brEad, AndersF, loudbang and 2 others like this.
  23. fiftyv8
    fiftyv8
    from CO & WA
    Build thread for this beauty would be nice.
    Great work and a good chance to burn up some of the numerous T Tudor bodies out there, especially in central KS on the I70.
  24. loudbang
    What's the round thing near the front of the engine.
    1947knuck, MMM1693 and oldiron 440 like this.
  25. Inked Monkey
    Inked Monkey
    Looks like a factory gauge with the oil pressure in it? Short line run just to hook it up?
  26. ENess
    ENess
    from Illinois
    That is a 50 plymouth oil gauge to hook direct for initial startup.
  27. loudbang
    NOT mine found it on the web and it's the first T stock car I have ever seen.
    AHotRod, 1947knuck, VA HAMB and 8 others like this.
  28. bobbytnm
    bobbytnm
    ^^^ That guy needs to eat a truck load of Chubby Chuck Burgers or something....sheesh
  29. Tall t 26
    Tall t 26
    loudbang and fiftyv8 like this.
  30. Tall t 26
    Tall t 26
    A few more pics. Of my 26 model T sedan.
    brEad, AndersF and 26 T Ford RPU like this.
