whos made there own roll pans???
Discussion in 'The Hokey Ass Message Board' started by kustumizer, Apr 1, 2004.
  1. kustumizer
    kustumizer
    from Alton,NH
    any advice and pics?? Thanks Nate
  2. What kind of vehicle you talkin about? I've made a bunch of them for pick ups. I had the local sheet metal shop bend a bunch for me. I like to use the same radius on the side as the rest of the pan. Most pans just have flat sides. Heres one i just got done for a 38 Ford pick up.
    Clark
  3. fitzee
    fitzee
    Don`t know what type of car your looking for.So here is one I did for a Model A.
    fitzee
  4. 48_HEMI
    48_HEMI
    I'm using the rear 12 inches of a 50 plymouth station wagon roof its got a perfect compound roll that drops a couple inches in the center that gives a look that is hard to beat out on a sand bag.
    its not cheating to use factory parts, its how you use them! [​IMG]
  5. The Ford Courier pickup has a rear roll pan easily adapted to A's & 32's.
    I imagine it would work well on other cars.
  6. Paul
    Paul
    Editor
    it would help to know what car or truck you're puttin em on..
    I used pieces cut from a couple '36 Plymouth rear fenders for the corners and a chunk of '60 Ford roof for the middle on mine.
    'fabbed up the inner support out of 18 gauge sheet steel.
    Paul
    in this picture you can also see where I filled the holes where earlier I had put a pair of '62 Olds tail lights and recessed license plate. [​IMG]
  7. fab32
    fab32
    Paul. How is the sanding and priming coming along? Bet it's making a mess in that new shop. haha!!!
    Frank
  8. Nate
    I sent you a PM
    The PknBner [​IMG]
  9. McGrath
    McGrath
    I made this one out of 16g.
  10. enjenjo
    enjenjo
    from swanton oh
    I have made them from the sides of a 73 to 79 Ford truck hood. I also did the 50 Plymouth wagon roof one too. And one from 6" truck exhaust pipe, split into thirds.
  11. Jeem
    Jeem
    Alliance Vendor
    Check out oilpans from various engines, they usually have 3 to 5 pairs (left and right) compound curves that are great for things such as roll pans. Use the curves and span the center with similar guage sheet. I did a dash for a car utilizing an old oilpan that I found on the s**** pile at ElPolackos shop.
  12. Paul
    Paul
    Editor
    Hey Frank,
    I'm out there every chance I get!
    right now I'm thinking I have some rework to do, there is no way to get an even gap around the trunk opening, when I put the tail together I had no lid, I found this one only after I'd welded the body up..
    I think the easiest way to fix it is to cut the gutter free of the body and space it off of the lid..
    Will this car be done before I die?
    Not if I keep changing things!
    Paul
  13. FRKSHO1
    FRKSHO1
    I reshaped the rearend of a 37 plymouth by making a wood frame of what i wanted, and then i hambered the metal around the wood frame until it fit perfectly. then i welded it to the car.
