who's runin A BB 6-71 and whats ur highway MPG
Discussion in 'The Hokey Ass Message Board' started by bigalow1, Jul 12, 2011.
  1. bigalow1
    bigalow1
    from 496 C.I.
    Do you drive it?
    Whats Your Criusing MPG?
    Whats your Combination?
    This should be fun!!
    I know a guy that gets 5 gallons to the mile?
    He doesn't get out on the highway much-only good for short bursts!1
  2. Get hold of Squirrel. He's been driving his BBC huffed for ages.
    A blown motor doesn't have to get crappy mileage. It depends on a whole lot of variables, but set up right it sould get as good a mileage as any other engine. A well tuned engine is an efficient engine.
  3. bigalow1
    bigalow1
    from 496 C.I.
    There is hope!
  4. squirrel
    Depending on gears and how I drive, I get anywhere from 6 to 12. I have a relatively mild 454, th400, 9" rear. Engine has a hydraulic roller cam with about 235 degrees duration at .050, two 650 double pumpers, 7.5 compression. mostly stock iron rect port heads. Converter is switch pitch, so it will get either 1500 stall "off" or 3000 stall "on". I ran 3.25 gears the past few years, just changed back to 2.75. With the 3.25 gears I ran a low 11 at the strip in Phoenix, driving the car up there and back on drag radials. I run 87 octane almost all the time, I spend a few extra bucks and buy 91 when I go racing. The engine has about 90k miles on it total over 20+ years. I did take it apart and freshen it (rings, bearings, valve job) at 50k miles.
    Mileage is not really the goal here...but it can get expensive to drive if you only get a few miles per gallon, especially if you have to run race gas.
    rod1 likes this.
  5. thorpe31
    thorpe31
    from nor-cal
    Its not what you asked for, and it's mainly for just putt'n around.
    2300 lbs, 327, th350, 6psi, 471, 1 700 holley, 16mpg freeway
  6. bigalow1
    bigalow1
    from 496 C.I.
    Thanks guys,
    you helped my quite a bit Sqiurrel with blower education in the past-Thank you.
    I finally saved enough to purchase the unit
    10% under
    112 lobe sep on cam
    248 dur @50 557 lift
    single key crank?(i know) RP Crank end is stout-plus take it easy
    3.23 gear
    8-1 CR w iron heads
    Dont have carbs yet -I will run what Squirel is running-Saved info from past
    Thanks for helping!
  7. kkustomz
    kkustomz
    from Texas
    ill chime in when i have more time, but a single key way crank on a bbc is more than enough for a 6-71 or 8-71 on the street. Your not turning that blower upwards of 30 or more pounds of boost.
  8. bigalow1
    bigalow1
    from 496 C.I.
    i want to run 6psi to 8psi to get familiar with it...Tune ect... Dyno shop close to house to help eliminate a lean condition at initial start up
    i should have gone Procharger but I LOVE THE OLD SCHOOL LOOK-NOTHING COOLER !!! Dont see a roots criusing around everyday either?
    I have pulled my balls out of my wifes purse and i am getting ready to do the change over--exciting!!
  9. bigalow1
    bigalow1
    from 496 C.I.
    How do you keep from having a lean condition if you run out of gas???/
  10. squirrel
    Make sure you don't run out of gas....the fuel system needs to be up to the task. Although I've only run out of gas (like empty gas tank) when putting around town, good thing we have cell phones now.
  11. if your running a BB and a 671 do you really care what the MPG is?
  12. squirrel
    Depends on how much you drive. I've run about 8,000 gallons thru my blower motor over the years....the fuel bill adds up over time.
  13. bigalow1
    bigalow1
    from 496 C.I.
    I like to get in my car and drive out in the country. not really an around town kind of guy so yes it does make a difference. Want to get as much MPG as i can. anything less than 4 will be a problem
    If you run out of gas or your fuel pump quites won,t this ceate a lean condition and ruin your rings or pistons?
  14. Gerry Moe
    Gerry Moe
    6-71 on a 392 Hemi
    8-1 cr
    225 duration @ .050
    114 lobe separation
    2 holley 600 vac referenced blower carbs
    3.89 rear gears
    33 1/2 height rear tires
    700 r4 trans
    91 octane
    If I stay at 65 mph at 1900 rpm I get 10-11 mpg, around town driving the speed limit, normal acceleration 9-10 mpg, if I play all mpg stats are gone.
  15. Tom S. in Tn.
    Tom S. in Tn.
    Who would even bother to try to calculate such a thing ??
    Tom S.
  16. squirrel
    If you're making a lot of power (like a full throttle run) and you have a fuel starvation issue to where it's running lean for a while, it might burn a piston. But in normal driving, running out of gas is not a problem as far as the engine is concerned
  17. Gerry Moe
    Gerry Moe
    I have never ran out of gas, imo an occasional and I mean like once a year, would do no harm. If I ever was to run out, first sign of any sputtering, coughing, misfires I would shut down immediately no matter where I was at and check problems.
    In my first post I failed to mention that I am 20% underdriven and running just under 5lbs of boost
  18. propwash
    propwash
    from Las Vegas
    I'm with the "if you can afford this kind of an engine, why would you give two hoots about mileage" posts. I have cars I can't keep my foot out of...I know the mileage sucks...I don't care....I'm a car person...not a friggin' accountant/bean counter.
    dj
  19. bigalow1
    bigalow1
    from 496 C.I.
    I know but i am going to the Mopar Nats and look forward to driving the 320 miles each way!! If i get much less than 6 Mpg criusing i will have to trailer it .
    If its riding on a tailer and i am not going to the drags its NO FUN for me.
    (im excited-sounds like at the performance level I will be running the blower at, motor melt down wont be as big an issue! COOL I have been lookin at it and setting it on my hood but now i am getting the confidence to start wrenching!!!
    After i get it started i will take it to the dyno place and have them help me adjust my carbs so I am not running lean) i am going to be alright with this
  20. bigalow1
    bigalow1
    from 496 C.I.
    I am cruising at 3100RPM now and 6mpg. Going to drop my gear to 2.94 for the trip (easy on a mopar)which should drop RPM to 2500. Plus running lower CR heads and I will try gas with less octane than 94. Should be OK?
  21. squirrel
    There are lots of variables as far as boost, compression, fuel, chamber configuration, timing, etc.
  22. bigalow1
    bigalow1
    from 496 C.I.
  23. Gerry Moe
    Gerry Moe
    I don't worry about the cost more as effects of running out because not enough fuel capacity to get me from one gas station to the other ( some stretches in Nevada,Mojave etc). So I did the calcs for that purpose
  24. bigalow1
    bigalow1
    from 496 C.I.
    Must be geat to drive it out west?? Can you really open it up in certain area's?
    I am a top end Ben!
  25. Gerry Moe
    Gerry Moe
    Legally no. I live out in the country and know what country roads to use and it takes awhile to find a good one, the quality of our county roads are getting worse everyday. I run a built 700 r4 gives me that overdrive for the highway, but at the same time I can flip a switch at 65 mph and lock out the overdrive, chirp the tires and rpm goes to 2600, instant speed rush, flip the switch and bring it back down. Might want to look into an overdrive either manual or auto your choice
  26. bigalow1
    bigalow1
    from 496 C.I.
    Thats Cool and oh yes i have been eyeing overdrive units!! $3000 seems to be the magic number fo everything these days?
  27. rat nasty
    rat nasty
    this is in my 57 wagon...468 BBC 6-71 on 9 lbs boost and pump gas .850 solid roller and twin 1050 dominators makes over 750 h.p. @ 6300 rpm 4.11 gear 31" tall slick & 4 speed. I drive it around town/expressway dont know the exact mpg but the H.P./grins ratio makes it well worth it!!!!!!!
    guessing if i had to make a 55-60 minute trip which is approx 55 mile round trip it would drink about 8 gallons but thats also mostly all expressway and a little side road drivin and floggin on it frequently and really runnin through the gears when ever I can! I've seen a lot of stock BB's in tow rigs and trucks that dont get that type of mileage! this combo has been dyno'd and tuned my A/F's are spot on through out the entire power band for 93 pump gas!
    I am wanting my next hot rod to be blown as well!
  28. flamedabone
    flamedabone
    Beins you bumped this old thread, I'll toss in my 2 cents...
    On the highway, the 389 Pontiac in my 3200# Model A (10#s of boost, 2 750s) gets 15 mpg or so on long trips with 2.89 gears in the quickchange. In town with 3.89s she gets about 8. On the flip side, she does run 10s on street tires..
    I spent 600 a month on fuel in the last year. But, I drive her every single place I go. Back and forth to work every day, going to the grocery store, pick up the kid from school, yada yada...
    -Your mileage may vary.
    -Abone.
    Desoto291Hemi likes this.
  29. DS1937
    DS1937
    A 6-71 @ 6% underdrive on a .030 over 454 (461). 400 turbo, Crane solid roller, 8-1/4:1 2 holley 850's, 9" Ford w/3.89:1 gears, 31-1/2" tires and I get about 8 mph if I don't beat it up too much. Car weighs about 3200 lbs.
  30. fastcar1953
    fastcar1953
    Old thread I know but anyone else want to talk about it?
