Who's runnin a Flatty..........?
Discussion in 'The Hokey Ass Message Board' started by cruzr, Mar 6, 2006.
  1. Crusty Nut
    Crusty Nut
    Since this thread came back from where ever it is old threads go, I thought I would post an update of mine.
    after and before:
  2. Vergil
    Vergil
    Mine in a '31 Coupe.
  3. greenracer
    greenracer
    from sequim wa
    Here is mine Not running yet still in the fabrication stage. Twin turbos original Navarro heads and intake.
  4. glmke
    glmke
    my v8-60 any info or comments are always welcome
  5. JimSibley
    JimSibley
    More pics please.
  6. Snipe
    Snipe
    Here's my mill. 4" mercury crank, 3 5/16" bore, Schneider 260F cam. It's in my '40 deluxe coupe.
  7. greenracer
    greenracer
    from sequim wa
    Here you go Jim
  8. vintagehotrods
    vintagehotrods
    Here's one of mine in my '32 Tub. 8BA 239 with a Thickstun tall 2 deuce with Holley carbs, Edmunds heads, converted Mallory SBC distributor, Patricks coated headers. The 3 other's I have are still stock.
  9. Pete1
    Pete1
    from Wa.
    323 cubic inch flathead Ford V8.
    **** crank. 4 7/16 stroke. Balanced with NO heavy metal. Knife edged, polished, OD reduced.
    Steel main caps.
    CAT H beam rods. (lightened)
    Ross forged pistons. 3 3/8 + .030.
    D&L radius lifter cam. #4 270 Offenhauser grind.
    Solid guides with bronze inserts.
    ***anium valves and retainers.
    1.685 diameter valves with 5/16 stems.
    Hilborn injectors with custom air cleaner.
    Edelbrock heads. 11-1 compression.
    Harmon Collins magneto with lead plate. (Mag has aircraft coil conversion)
    D&L accessory drive. (Inj. pump, mag, tach.)
    Martas crank driven water pump.
    Water headers.
    High volume oil pump.
    Hayes aluminum flywheel/clutch.
    Gear drive starter.
    2 inch W type headers with 3 1/2 inch O-ringed dumps.
    Baffled center exhaust ports.
    ALL studs in the engine are custom made of 4340HT steel.
    This engine makes over 1 hp per cubic inch on gas.
  10. vintagehotrods
    vintagehotrods
    WOW!!! Now that's a hot flathead!
  11. 296 V8
    296 V8
    from Nor~Cal
    whats that monster in. ruler Pete 1
  12. Pete1
    Pete1
    from Wa.
    296V8: This is the car.
  13. Backtoflatheads
    Backtoflatheads
    Pete, after seeing that, it's difficult for me to claim that I'm running a flattie:eek:
    or even running at all for that matter...
    geez:eek:, in the name of all that is holy:eek:
  14. VanHook
    VanHook
    Here is my 39 that will be powering my A coupe if I ever get the thing done!
  15. Pete1
    Pete1
    from Wa.
    Backtoflatheads:
    It's not rocket science.
    It does take a bit more money to build a go fast flathead the conventional way (no blower or nitro).
    I just wish more guys were interested in vintage racing.
    On the west coast we have races from Washington to Arizona all summer...The best shows are 3 day all vintage...Usually draw 70 cars.
  16. ModelAHotRod
    ModelAHotRod
    from MO
    Here's mine. Very early mock up stage.
  17. Backtoflatheads
    Backtoflatheads
  18. flathead fred
    flathead fred
    Here are a couple from my 51 Shoebox, sorry so small
  19. 4dFord/SC
    4dFord/SC
  20. Henry Floored
    Henry Floored
    Here's one we put in Don's `37 this past weekend......
  21. I just picked this one up...
  22. "Doc" Parsons
    "Doc" Parsons
    Be careful Nitroflatty1, the way that is mounted on the engine stand can break the back out of the block, those should be mounted off the exhaust ports
    "Doc"
  23. [quote="Doc" Parsons;2537799]Be careful Nitroflatty1, the way that is mounted on the engine stand can break the back out of the block, those should be mounted off the exhaust ports
    "Doc"[/quote]
    will do...its a bare block now...and on the floor..thanks for the heads up though :D
