Who's running a mustang Radiator and SBC???
Discussion in 'The Hokey Ass Message Board' started by chaddilac, Jan 17, 2011.
  1. chaddilac
    chaddilac
    Thanks ******!!
    Thanks HRM2K... Headed to the radiator shop!!
  2. GrungyGary
    GrungyGary
    Yes, mine is a 2 core.. i used one in a '35 truck too..sold it to a friend. it was his daily driver for 3 years...never overheated.
  3. gimpyshotrods
    gimpyshotrods
    Same here. No problems, even crossing the Sierra Nevada Mountains, or in the high desert.
    I love how someone always chimes in to say that this wont work.
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    maybe i missed it..what are the core dimensions of the mustang rad?
    W=?
    H=?
    Thickness=?
    thanks
  5. alwayzarat
    alwayzarat
    Mine is a 3 row copper radiator for a 65 mustang. It is low, non dropped front axle though.
  6. junkyardjeff
    junkyardjeff
    Will you cheap *** *******s just let a local radiator shop build you a radiator that fits the shell and does not looks so damn ugly,you know buying those cheap China or Mexico made radiators are putting the locals out of buisness and where are you going to go when you really need some help. Daily drivers I can see but not the hotrods,a mustang radiator in a early shell looks like something that belongs in a ratrod and you dont want that do you.
  7. alwayzarat
    alwayzarat
    To me, and many others on here, hot rodding is about making parts work and often doing it on a budget. I would never pay the cost to get a radiator fabricated, but hey, that's just me!
  8. fleetside66
    fleetside66
    I'm running the 3 core on my stock 283 sbc, with a regular fan setup & it works just terrific. I bought through Ebay for about $125 if my memory serves me well. It is great...no issues & I left the outlets were they were & just bent the hoses to comply.
  9. hrm2k
    hrm2k
    Junkyard Jeff's signature: Do not own anything with a sbc and never will.
    Thanks for your advice Jeff. I'm sorry that my piece of **** doesn't fit your idea of a hot rod. I'm sure you wrote the book and could probably find many things wrong with my piece of ****. I appreciate you giving me a heads up
    cheap *** ******* :cool:
  10. Jimv
    Jimv
    Better check your facts, theres a reason why they switched over to alumn! It gets rid of heat much better then copper!
    Seems like thats all the Radiator companies are making now.Don't think it being done cause alumn is cheaper, its better.If it wasn't Walker won't be using it.
    JimV
  11. Jimv
    Jimv
    Dude your handle is "Junkyardjeff" & your advising to go out & pay for a new one!!WTF??
    Maybe if you have the extra cash you can give it to him to have one made.**** i don't even have 135 bux for a AZ chinese one!
    JimV
  12. The reason for aluminum radiators is weight. I can not find my book right now. Copper has a better heat transfer rate but weighs more than aluminum. I will supply the numbers when the book is found.
  13. HELLBILLY
    HELLBILLY
    Autozone 2 core Mustang radiators have been in both these since 2001.
    Thats alot of miles, the truck did get hot on me one time at the dragstrip...... but it was my 37th p*** that day lol
    Why buy a $500 to $700 radiator when you dont need it?
    I did buy a Walker for a Coupe that I know will need it.
  14. SinisterCustom
    SinisterCustom
    It's not just the weight.....
    Aluminum is a little stronger, allowing aluminum radiators to have larger tubes over the more fragile copper radiators, hence more capacity, than the same "outside" dimensions of a copper rad...
    But yeah, copper disipates better....as does straight water over "coolant"....:)
  15. See what you started Chad !!! >>>>.
  16. Thermal Conductivity of materials
    copper = 220
    aluminum= 132
    fire brick =.358
    These numbers are at 100*F. The numbers are dependent on alloys added to the metal and temperature. Some mechanical engineer has probably developed a computer program that optimizes the design of radiators. The program is probably based on parameters like coolant flow, air flow, material, space limitations, size of tubes, number of tubes and the thermal conductivity of the coolant and the temperature of the coolant.
  17. chaddilac
    chaddilac
    Geez!! :D
  18. 1971BB427
    1971BB427
    from Oregon
    My neighbor is using a 3 row Mustang style radiator in his Austin g***er. It's welded aluminum tanks and only cost $159 locally.
