Who's running a quickchange...
Discussion in 'The Hokey Ass Message Board' started by sedan_dad, Mar 4, 2004.
  1. sedan_dad
    sedan_dad
    ...and what do you think of it.
    I'm thinking about a Halibrand V-8 conversion.
    What do they go for.I've seen prices all over the place.
  2. GREAT! Noise isnt an issue, every once in awhile I can hear kind of a harmonic-whir from the spur gears, but nothing compared to the rest of the racket my car makes. Looks *****in, ability to change rear end ratio in 20 minutes is great.
    Mine is a 'Torrance City' housing and cover which I think places it around '64 to '70, I got on Egad for $1500, aluminum was perfect as was pinion gear and bearings but lower shaft and bearings needed work. Cost another $500 to get like new. Since then Ive only seen beat-up/butchered early ones going for 1000-1500 or new ones with the big V8 logo on the side pieced together with various parts going for a little more, except for one cherry complete early set-up just like mine that went about 3 weeks ago for $2700(OUCH!!).
  3. Got a pal with a Winters Champ in a '34 Coupe with no fenders and a hand grinder. Everytime I drive it all I hear is loud pipes and burning rubber.
    I've got one of them for my '32 roadster project, along with a big block an' a 6 speed. My pals car gave me serious inspiration!
    Charlie
  4. hotrodA
    hotrodA
    Got one under my roadster. Noise? Whos cares! About like a cam gear drive. Have another one for the 27. [​IMG]
    Halibrand V8 QC from dirt track guy: $75
    Charge to polish case: $75
    Machine shop mods to r&p and carrier: $100
    Charge by a guy who knows his stuff to setup: $100
    Cool index: PRICELESS
  5. phat rat
    phat rat
    Know the same guy as Charlie Chops, the two of them worked on me until I also bought a QC. Mines a Frankland and it's going into my 30 roadster with a BBC. Got it on e-bay for less than $400 and it's got Ford axles 5 on 4 1/2
  6. Corn Fed
    Corn Fed
    I have a Torrance City under my 29 Coupe also. It's been there for 15 years and I've never had a problem with it yet. It'd been in the family for 25 or so years so I have no idea how much it cost. Probably a couple hundred bucks. For some reason the noise gets a little quieter around 55 MPH and doesn't get noisy again until about 70. So it works as a good speedo too!!! Wish I had another one for my current project Coupe. The cool factor of a Halibrand sticking out from the back of an early Ford is way off the scale.
    Corn
  7. lakes modified
    lakes modified
    If your after some new ones, then call Norm Rapp racing equipment.{415-333-8510}, he has new cases and parts, but not a lot of them.i have no idea on prices, but new stuff is usually not cheap. i have been getting some gears for my old culver city housing and other parts for it from him.
    i hope to get mine under my modified by this summer.
  8. Stovebolt
    Stovebolt
    With no intention of hijacking this post - Has anyone heard about how good the new Winters V8 QC is??
    I see that **** Spadaro is even selling them on Ebay - so I says to myself - are they ****, or are they slow moving? [​IMG]
  9. racer5c
    racer5c
    The Winters units aren't really "new" I ran one just like it in my race car for 10 yrs or so, and Halibrand before that. They both are fine although the Halibrand is a little beefier around the front flange area but if you use an open drive line that won't be a problem. In the race cars we would bend the front of the center section with the winters units if ya hit the wall very hard, the halibrands never did. I have a Halibrand in my 31 Ford Roadster that was the last Halibrand I had in my race car.
    Roy Caruthers
  10. cabriolethiboy
    cabriolethiboy
    I have one of the new V8 quickchanges under my 32 cabriolet. Love the looks, but it is noisy. But only with the top up, with the top down it doesn't bother you at all. The noise only bothers you when are on the road for a couple hundred miles, then you start hearing all kinds of things(imagination). I will never take it out though. I have 3 more old ones(Culver City) for other projects.
  11. sedan_dad
    sedan_dad
    Halibrand wants $1595 for their's and $1395 for a Winter.
    I'm a little gun shy about buying a used unit ($700-$900).I really don't know what to look for in a used one.
  12. Sixcarb
    Sixcarb
    from North NJ
    there's nothing better then the smooth humm of a quickchange when blowing down the road and backing off the throttle and listening to it sing. Music to my ears.
  13. racer5c
    racer5c
    Oh by the way I first had old Halibrand gears in mine, changed the ratio and used Winters gears and they are MUCH quieter the pitch of the gear is a little different, they aren't Helical but they are rounded a little more than the Halibrands, and seem to be a lot quieter.
  14. sedan_dad
    sedan_dad
    Well,I'm going to bite the bullet and buy a new one.Halibrand ($1518) or Winters($1395)I've talked with Halibrand and ****Spadaro's shop,They have just what I want.A closed drive shaft,use your existing axle's and tube
    "kit".Any experience? How about installation tips for a first timer?
  15. hotrodA
    hotrodA
    1st tip: Halibrand's have TWO lube sections; the r&p and the spur gears. Fill them separately. Run a vent tube from the center section (r&p) to a vented puke can in the trunk and you can fill from that also.
  16. I ran a halibrand in my 32 with no problems at all, they whine and cost money but so does my ****ing wife. Im running one in my 32 three window I am building right now. They are totally over priced and not really needed but so are our cars!
    Paul
  17. visor
    visor
    from Missouri
    So what do you get for 1500 bucks from Halibrand?
    How much of the unit is ***embled?
    Tip #2
    If the bearings aren't installed, your're going to have
    use the wife"s oven.... now you're really going to here
    some whine'in!! [​IMG]
    Heating the case and installing the bearings is really
    no big deal.
    What axles, housings and diff. and gears are you going to
    use?
    Give us all an idea of what your usin.. and we can maybe
    help out here.
  18. sedan_dad
    sedan_dad
    I'm going to replace the '36 banjo in my roadster.I'll be using my bells ,axle tube retaining the torque tube.I'm leaning towards the Winters unite.
    Here's a link to ****Spadaro site.
    http://www.****spadaro.com/whatsnew.html
  19. Sonnydsicko
    Sonnydsicko
    Hey... If you're looking for a cheaper option you can always pick up a winters qc for a couple hundred bucks at a circle track race flea market. I scored mine for $150 and I put another $60 into it. Not too bad. When I was in the market for a qc a ebded up with parts of a Stauffer. I have no clue what the deal is with it. It looks like it goes to a banjo center, but I'm not sure. If any of yous have heard of it please drop me a line. ---Sonny O
  20. kustombuilder
    kustombuilder
    from Novi, MI
    here's mine. i have'nt even opened the rear cover on it yet. i got it from a friend who said it was a Frankland but i looked and in little letters it says "Winters" on the cover. all i know is i can't wait to get the axles converted and get it in running order under the FnA. it's BEEFY!!!! [​IMG]
  21. visor
    visor
    from Missouri
    Sounds like a good choice Sedan Dad.
    I also used the '36 bells and radius rods.
    The small 36 bells look so much nicer than
    the later larger diameter ones such as the 40's.
    Are you also using the 36 diff and ring & pinion
    and axles? They will work just fine.
    I used the later '40 axles, diff. and r&p. You
    just need to use the 36 bell races and diff bearings
    with this switch.
    I also used a '34 torque tube and drive shaft,
    and a model a spring to make room for the
    Halibrand quickie.
    My good old buddy Bob.... (Newport Engineering)many of
    you know him for his windshield wiper mods.
    Has been runnin a Hal Quickie in his 29 A truck and in
    his 29 A Sedan for 12 years or better. Still goin strong.
    You're going to love it!! [​IMG]
    "OPOSSUM BENDERS"
    Central Missouri Chapter
  22. sedan_dad
    sedan_dad
    Anyone know much about the old Frankland quickchange's.
  23. Yeah....same here. I emailed Frankland some time ago about their "new" closed rears....no dice.
    Do these guys sell rears to us gearheads or only racers? I really like the look of their QC. Would look killer under my 3W.
    Anyone know whats their story ? Also, I scoped out Dutchman Motorsports' QC rear ends too....they seem like a real nice unit....but pricey !!
    Rat [​IMG]
