Whos running ford 302/5.0 in their machine?
Discussion in 'The Hokey Ass Message Board' started by 65fordguy, Nov 30, 2008.
  1. j.r. Nice
    j.r. Nice
    1) 5.0 H.O. in my 65 Falcon.
    2) Blown 302 in my 66 Bronco.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    My '54 Ford Customline with a 302& AOD and a k.i.s.s. HEI :D & 289 "K" code heads
  3. briggs&strattonChev
    briggs&strattonChev
    what is the advantage to the 289 heads?
  4. 48fordnut
    48fordnut
    53 cc combustion chambers.
  5. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Higher compression...and that's it.
    The best flowing head was the 302 J code heads made in 1968.
    The one flaw on 289/302 is the exhuast side flow. Opening up the heads and letting them breathe gives some serious power.
  6. 1stshift
    1stshift
    from Sacramento
    A 302 in my 53 MERC.
  7. 65fordguy
    65fordguy
    some mighty fine rides here fellas!
    you know when I got my motor done... Originally I
    wanted an 84 302 done... turned out it was trash...
    the engine builder had a complete 86 mustang setup..
    the heads are E6... and he told me that if I could take
    a beating from the hot rod guys for having them he would trick me up a set that would
    out perform any E7 stock head out... dunno.. im no head guy..
    but looking at a stock E6 and the ones after he got done.. look alot diff.
    not sure but I think he put differnt valves in it... and ground off alot of stuff.
    anyway.. its built for flat top pistons... and apparently 86 was the year they did that... and some fancy swirl quench head design... that was shrouded by something that made it not worth it.. so they went to the E7.. and apparently thats what he fixed
    Anyway... love to hear your opinions on this.. I love hearing people tell me they arent worth it.. but two racing engine builders here love them. quite a conflict of information there.
  8. ChopTopJimmy
    ChopTopJimmy
    My heads have been reworked and should make real good power. CTJ
  9. dakotajayne
    dakotajayne
    from 3c1
    Here is my version of '32 w/302! I might have cheated on the stroke a bit. While the DUI is big and ugly, kiss makes it a good idea. Use aluminum heads if you can. Have fun:D
  10. scelatore
    scelatore
    Good to see Fords in Fords ! Hears one of mine ( Home biult)
  11. Jalopy Jim
    Jalopy Jim
    Collecting the parts for a 331 Ford in my 62 Falcon project.
    I have the 3-2 Blue Thunder intake, 4 Autolite 2100's, 86 T5, or C4 ( have not decided yet ) 68 -302 motor from 68 Mustang GT, and a couple of dizzys., and 351 Exaust manifolds.
    I should be working on that car by late summer 09.
    jim h
  12. 65fordguy
    65fordguy
    how many miles are you guys getting out of these? I knew a guy who had like 300k miles on his old truck... still ran.. had an oil leak. but didnt smoke.
  13. Bull
    Bull
    I had less than 1000 miles on mine.
    Before this happened.
    (hit head on by an inattentive driver)
    Causing this.
    And this.
  14. Tacson
    Tacson
    I have a 5.0 Speed Density EFI out of a 88 Crown Vic in my 55 F100
  15. 65fordguy
    65fordguy
    btt.. been awhile, thought I would see if any new comers had anything to offer.
  16. HOTRODPRIMER
    HOTRODPRIMER
    I'll play,,1954 Ford "Ranch Wagon" with a 302/5.0 and a 5-speed transmission. HRP
  17. millersgarage
    millersgarage
    EFI 5.0 in my 28 coupe
    '69 302 in my 47 sedan (with the HEI dist too)
  18. flatheadpete
    flatheadpete
    from Burton, MI
    302 and a broken C4 in my '51. Anyone have a C4 I can damn near have?
  19. 302/306 in our OT road-race Mustang (Fox Body 1987 old school) - just completing a new motor for next year's season. Will probably also build a 331 stroker short block . . . 3.250 stroke 4.030 bore, Mexican 302 block.
    Will post pictures later one . . .
    Dale
  20. old lady's mad
    old lady's mad
    i got a 302 in my 55 fairlane with a aod behind it . nothing special just stock.
    i got a 302 with 289 crank rods and heads with a c4 for my 53 f100 and i have a 302/5.0 with aod waiting to go in my 48 ford 2 door sedan.
    i only do fords in my fords . and regular ford electronic dist.
  21. Kustomline54
    Kustomline54
    my 54 will be running a 302 w/ a t-5 behind it. oh yeah :cool:
  22. GassersGarage
    GassersGarage
    This has got a 302 out of an '86 Mustang with a C4.
  23. 65fordguy
    65fordguy
    I love mine.. I intend on replacing the large HEI with either a hei with a pack or a ford electronic.. not sure.. but until I get all my body work done and wheels and tires bought.. it will keep the big ol hei.
  24. hotrodj54
    hotrodj54
    54 ford with 69 302 balanced and blueprinted, with a toploader 4sp and a 4:11 rear behind it. sorry no pics yet.................john
  25. toxictom
    toxictom
    i do.....
  26. frank dog
    frank dog
    I'm in the proses of installing a 302/C4 combo in my F100.My engine rebuild guy rebuild my distributer also and i'm goin to install a Petronix set up.I have installed a couple and have not had problems with them.Keep a set of points in your glove box just in case.;)
  27. Just rebuilt mine. Looks just like it did except a lot cleaner.
  28. eldiablo
    eldiablo
    my daily E100 econoline from 1974 has the stock 302 5L still in it from the factory
    i have to admit that it has a chevy HEI dis. and runs on LPG & gasoline
  29. 0rg0
    0rg0
    I have a 302 and AOD in my '59 Edsel. It's nothing special, but damn it runs great, and that AOD is fantastic on the highway.
  30. 342, tremec 3550 in my 32. Also efi. not forum friendly.
