Who's thrashing for the Pileup???
Discussion in 'The Hokey Ass Message Board' started by CURIOUS RASH, Sep 21, 2011.
  1. Woo hoo im going almost had to work.
    I was wondering who wants to race minibikes in the hotel parking lots im game if there id anybody else pm me
  2. ryno
    ryno
    sounds like you sir had a good night.
    i got the unibody fired up tonight and running goo don the lift.
    re bleed the brakes,installed a residual valve for the rears, got all excited to put it in gear, **** for got to buy type f ford ****** fluid, ****ing fords! gots a case of good mercon, but no type f, so tomorrow!
    i just may make this trip after all!
  3. ryno
    ryno
    i wouldn't mind smashing you, i mean racing you, if we could find a nice gr***y field to make an oval track!
  4. Haha smash this I mean race I think behind the host hotel there is a gr***y knoll for some *** whipping hahajaha
  5. Hellfish
    Hellfish
    I got the headliner and 59 Olds interior door trim installed. I just need to re-install all my interior mouldings and I should be good to go.
  6. flt-blk
    flt-blk
    from IL
    Dragster trailer is 60% done. stopping by HRCC to pick up some 2X4 steel to finish building it.
    It's going to be close.
  7. I'm not ready to admit defeat, but I have a ways to go yet...
  8. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    Replaced all fuel hose, filter, and pump. Figured out why electric choke wasn't working, got the rear deck fastened back down, greased the slip joint, modified the heater controls so we can use them to switch from heat to defrost again, cleaned it up a little. Got it aligned today, they were able to get it in tolerance.
    She's smoking something bad though. Blue through the pipes. Dead heads.
    I hope BenD keeps his ears on this weekend!
  9. squirrel
    Have fun Ron!
  10. CURIOUS RASH
    CURIOUS RASH
    I always do!
    Drove it to work today. Turned off the road, left onto 66, got up to 43 miles and hour and the steering wheel was trying to jump out of my hands. My plan was to get on 44 on my way to work. Quickly revised my plan, flipped a U and headed into Catoosa on 66, most of it's under construction so keeping the speed down was not an issue. Drove into BA on the backroads. Finally found someone to align it. They said the toe was 3 degrees out. Drove it home on the pike after work. Slight shimmy at about 83 now.
    I can live with that. This engine doesn't have that many more RPM's in it.
    Got it in the shop, built some kick panels, hid some speakers in em, installed them. Vaccuumed the pig out, adjusted the carb a bit. Realized the rear main is going by the stripes it lays down each time I start it. This probably accounts for the constant burning oil smell, some of it anyway. Looks like the oil gets flung onto the exhaust. Probably not as big an issue if I had a converter cover on it. Looked at the donor motor I'm about to start building and it still had a cover on the trans. Slight modification on it to fit the starter on teh goofy trans in her car and it was installed.
    Gotta load the tools, give it a quick bath and I'm set to go....
  11. squirrel
    Too bad you can't still buy REV! recycled motor oil at Checkers....when I got my truck in 1977, there was half a case in the cab. Burned a quart driving 10 miles to my house.
  12. flt-blk
    flt-blk
    from IL
    Glad to hear you finally shook it down.
    The FED won't be chasing me down, There was a mishap with my steel, stupid fingers texted 4X4 tube instead of 2X4 tube so I don't have the right materials to finish things...
    Life is still good though, I'm still driving a 59 ElCamino, just not towing a FED this trip.
  13. 4950ford
    4950ford
    from cushing,ok
    Hey Ron,
    When are you leaving, I'm pulling out of cushing at about 7pm tonight so I'll be on the road if you need help from some Okies
    Carl
  14. CURIOUS RASH
    CURIOUS RASH
    Answered your pm. Good to see so many Okies going!
  15. CURIOUS RASH
    CURIOUS RASH
    At Ryno now. The 59 rides, drives, handles better than I hoped. That was definitely worth it!
  16. modelamac
    modelamac
    Heading out around Noon!
    After 2 months of thrashing... a bunch of cash, blood, sweat and tears!
    The dormant old Oldsmobile (un-changed since it's young pilot parked her in 1962)... is running (kind of LOL), shifting (sort of), now lowered (as much as I could without MAJOR frame modifications), and loaded (mostly oil, antifreeze, and of course beer)!
    Hoping for the best the Old's hasn't gone down the highway in 40 years... especially not 3 hours on the highway, let see what happens!
    A friend is going to follow me with the rescue rig, hopefully we won't need it!
    See everyone later today!
  17. CURIOUS RASH
    CURIOUS RASH
    We're in St Louis now. Pei Wei. Lunch.
  18. CURIOUS RASH
    CURIOUS RASH
    Post trip update:
    Looks like the entire trip was about 1200 miles.
    Zero problems. I popped the hood only to check fluids. Got a screw driver out only to tighten the sun visor.
    I'll call that a successful trip!
  19. Hellfish
    Hellfish
    Awesome! Yet another year went by and you, me and Tyler did not get together for a 1959 group photo!
  20. Deadbird
    Deadbird
    Glad to hear it was a trouble free trip. Good to see you up here in the land of corn.
  21. CURIOUS RASH
    CURIOUS RASH
    Doh!
  22. lowpunk
    lowpunk
    from berwyn, il
    Damn man, if i new this i would have gave you some!!!! I had some in the garage waiting for a project but would have given it up to see the FED there!
