Why cant I just
Discussion in 'The Hokey Ass Message Board' started by 32Gnu, Dec 5, 2010.
  1. 32Gnu
    32Gnu
    Got a fibergl*** tank for my 32. It wasnt precut for a sending unit.. is there any reason I cant just plumb the line to the motor from the drain plug? Its brand new and shouldnt have any **** in it..
  2. Royalshifter
    Royalshifter
    Moderator
    You could but as a safety caution it is better up top because they hold alot of gas and if there was something to hit or damage the line you could be in trouble.
  3. oldman2
    oldman2
    I don't think it is a good ideal, fire waiting to happen, my 2 cents.
  4. luckyuhaul
    luckyuhaul
    Could you make a skid plate to cover the bottom portion of the tank?
    I've done it on Jeeps but the tank was raised and well protected.
  5. NWRacing
    NWRacing
    I would NEVER put a fuel pick up in the bottom of the tank, why build problems into your car? If you get a leak your going to pour every bit off fuel out.
  6. bobj49f2
    bobj49f2
    The tanks in '48-52 Ford trucks are tapped from the bottom with a manual shut off valve so you can turn it off to do repairs to fuel system without gas pouring out. The valve is somewhat protect by the sitting up high and in the frame.
  7. stuart in mn
    stuart in mn
    Another problem is any water or sediment that gets in there will go to the bottom of the tank, and then right into the carburetor.
  8. Francisco Plumbero
    Francisco Plumbero
    from il.
    All above and besides It will have **** in it as soon as it starts to be used, they all do.
  9. chevyshack
    chevyshack
    One reason your pickup is on top is to keep it out of the dirt that will eventually end up in your fuel. The dirt will settle on the bottom of your tank. If you mount your pickup there your in for a whirl of trouble later.
  10. Deuce Roadster
    Deuce Roadster
    AND ... besides ...
    a nice steel car like yours DESERVES a nice steel tank.
    :D :D
    Call me ...
  11. 32Gnu
    32Gnu
    I appreciate all of the above... Thats why i am her to get good and safe info..
    I was more worried about the sediment and water than the safety part... thanks guys..
