Technical Why do I need a Mopar starter relay?
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Aug 1, 2024.
  1. Just Gary
    Just Gary
    Engine is a 354 Hemi with MSD distributor & coil.
    Here's its starter (source: late '60's 440):
    Relay in question and wiring diagrams:
    mopar starter relay 01.jpg mopar starter solenoid 01 with ign switch.jpg mopar starter solenoid 02  72 440.jpg mopar starter solenoid 04.jpg
    What does it accomplish?:confused:
    Why can't I just eliminate it and connect:
    • the red wire between the Battery + and the B pole on the ignition switch,
    • and the purple wire between the Starter Solenoid and S pole on the ignition switch (with the shifter's neutral safety switch in the purple wire between them) ?
    As always, TIA.:)
    Dino 64 likes this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    This should be fun.
  3. Phil P
    Phil P
    In general a relay is used to switch a larger load from a circuit that can't handle the larger load. So I ***ume the safety switch, egnition switch and there wires are not rated for the load of the starter.
    Phil
  4. squirrel
    That's pretty much it. Also the relay lets you have a neutral safety switch, if it's an automatic equipped car.
    The factory wire from the relay to the starter is 12 gauge, and it's not very long. That tells me it's going to load the ignition switch quite a bit, and maybe have excessive voltage drop, if you leave out the relay.
    good luck
    Dino 64, LOU WELLS, jaracer and 5 others like this.
  5. The37Kid
    The37Kid
    It's electrical and can't be seen, but what goes on inside that starter relay? Does anyone know, better yet can they explain what gets added or taken away?
    Just Gary likes this.
  6. squirrel
    there's a coil and a set of contacts. The coil gets energized when you turn the ignition switch, the contacts make contact and send power to the starter.
    this is a picture of a generic relay....so you can understand what's happening.
    here's a photo of a relay guts, so you can see what the coil and the contacts look like.
    Sorry I don't have any spare Mopar relays to take apart and show you the insides of.
    Dino 64, Just Gary, alanp561 and 3 others like this.
  7. 19Eddy30
    19Eddy30
    from VA
    I would think a good 20 -30 amp push ****on to stater solenoid 10 Ga, drop the Relay in drawing ,
    But Im someone Who does not have a Key,
    Just Toggo & push ****on,
    Toggo power up ignition,
    One side hot On Push ****on ,Other side to start solenoid,
    I can turn engine over Power Off @ Toggo
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    And that leads to how is Gary intending to set up his starter (start) wiring?
    Just Gary and squirrel like this.
  9. 31 Coupe
    31 Coupe
    Why not just mount a Ford starter relay nearby the starter with a 10g wire connecting it to the starter.
    The relay's primary signal wiring and switches can be connected with 16g because they're drawing negligible current.
  10. twenty8
    twenty8
    Relay good........... Fire bad...........
    Yes, you need a relay, but it doesn't have to be a mopar brand.
    Dino 64, oldsmobum, 73RR and 3 others like this.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    This. I use the Ford relay on my 413. Then pigtail the starter's internal solenoid terminal directly to it's main terminal.
  12. gene-koning
    gene-koning
    I have used the Ford relays on many of my Mopars. The Ford relay was always cheaper, and using it gave me an easy access to a battery hot if I ever needed one. The Mopar relay's spade terminals make accessing the the battery hot more difficult. The Ford relay makes it easy to jump across to crank the starter too.
    If you use the Ford relay, you can also eliminate the 12 gauge wire running to the Mopar starter if you want. All you need is a jumper from the battery cable on the starter to to the small post on the starter. Then when ever the Ford relay powers the cable going to the starter, the jumper also activates the Mopar starter solenoid and the starter spins.
    You do need to be sure what ever relay you use has a good ground at the mounting bracket. .
    Dino 64 and Just Gary like this.
  13. snoc653
    snoc653
    from Iowa
    For whatever reason, multiple manufacturers used both a relay and a solenoid on starters. The solenoid should be able to handle the job as you described. But on the off chance that manufacturer did something stupid, hook the starter to the battery. Take a wire, the same gauge as the one you plan to run from the switch to the solenoid, and connect the solenoid end. Then, hold the other end to the battery and let it spin the engine over for a few seconds. If the wire gets too hot to hold, you'll have your answer. Remember, the longer the wire the more amps it will take and the hotter it will get. You could even get fancy and use a VOM (volt ohm meter) to see what kind of amp draw the wire has. Some vehicles even took it a step further with a fuse to the relay hot wire.
  14. scrappybunch
    scrappybunch
    from nj
    Voltage drop of the wires and switches can cause the solenoid to not work, usually when engine is hot. Plus, they maybe not rated for the current draw of the starter solenoid. Yes, the relay could be by-p***ed with a 30 amp rated switch, and 10 gauge wires. But the neutral switch won't be happy.
    Back in the day, we installed ford starter solenoids on Pontiacs that had headers. When hot they would not crank.
  15. RodStRace
    RodStRace
    Safety and longevity. The contacts of the relay under the hood are designed to handle 'lifetime' use and are away from the operator.
    Plus as mentioned, the neutral safety switch is incorporated into the trigger circuit by providing ground.
  16. oldolds
    oldolds
    The starter relay is a work around on Chevy's with a "hot; no start" problem as well
    Just Gary and scrappybunch like this.
  17. goldmountain
    goldmountain
    The neutral safety switch goes to ground in neutral and park and you need the Mopar relay for this to work.
    Dino 64, scrappybunch and Just Gary like this.
  18. Just Gary
    Just Gary
    All good points. I'll rephrase my question.
    My '55 Chevy (SBC & Muncie 4-speed) didn't need a separate starter relay so why does my Model A (Hemi & T700r4)?
    The answer to that question is the Chevy's starter relay is inside the starter solenoid. Right?
    Dino 64 likes this.
  19. snoc653
    snoc653
    from Iowa
    Yes, the solenoid functions like a relay on the chevy starter. No the stand alone relay isn't required to start the car. But, as pointed out, the relay serves as the mechanism to make the neutral safety switch function. If you changed the neutral safety switch and ran the power through it to the starter, you wouldn't need the relay. That would require more wire to get to the neutral safety switch and then the starter and the switch and wires would have to be able to handle the amp draw. (refer back to some used the relay to over come the amp draw required when the starter was hot).
  20. squirrel
    Not quite. I think the reason Mopar used a separate relay is that they had a higher current draw from the solenoid/relay unit (which functions internally just like the GM design).
    Here are the insides, you can see they both have a plunger and contact washer, to act as a high current relay to switch the battery terminal to the windings
    The Mopar design is more reliable, as it has another relay (the one you don't want to install) in the circuit, and isn't subject to the heat soak no start issues the GMs experience.
    Dino 64, Fitty Toomuch and Just Gary like this.
  21. KenC
    KenC
    An earlier posted the 'chevy hot start problem' as a reason for the Mopar design. So true and Squirrel explained it well.
    On a lot of yard and small farm tractors they cheap out, even the green ones, and use the starter solenoid's internal relay. Then offer a kit to install a relay. At about 10 times the price of a generic Bosch type. The problem is the
    voltage drop through the safety switches (PTO, seat, neutral) and undersized wiring.
    I have my version of the John Deere kit on my 455, and will be putting one on my Hustler mower.
    TrailerTrashToo and Just Gary like this.
  22. Just Gary
    Just Gary
    Thanks, everyone.
    I'll be in the garage tomorrow, attaching a starter relay.
    Dino 64 and Johnny Gee like this.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ve got a full stomach of Taco Bell (gas reference) half a pack of chewing gum (gave up cigarettes) it’s morning (because it’s light) and I’m wearing sungl***es hit it.
  24. Jack E/NJ
    Jack E/NJ
    from NJ
    Use a push ****on instead. 8^)
  25. 31 Coupe
    31 Coupe
    Ironically, 45+ years ago I used a gear reduction Mopar starter in my race car and it had one of these heavy duty switches mounted within easy reach in the ****pit and operated by hand. It was coupled directly between the main battery cable and the starter mains post, and had a simple metal strap bridging the solenoid terminal to the mains post .... it worked flawlessly.
    Unfortunately they don't provide a Neutral start safety capability.
  26. Pinball Wizard
    Pinball Wizard
    If I recall correctly, the neutral safety switch grounds the relay coil. So if you are using the original neutral safety you would need the mopar relay.
    Chris
  27. squirrel
    you could use a normal "bosch" relay, instead of the Mopar relay....it's not rocket surgery....
  28. Jack E/NJ
    Jack E/NJ
    from NJ
    Or make your own.
  29. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    ^^^^^ " RELAY".......FFT.......
  30. ALLDONE
    ALLDONE
    do you know if they are volt specific , as in 6 or 12v
