Technical Why do my dash bulbs keep blowing?
Discussion in 'The Hokey Ass Message Board' started by evintho, Sep 28, 2024.
  1. evintho
    evintho
    Not all, only 3. One for my factory gas & water temp gauges, one for the radio and one for the clock. All others work fine. Car has been converted to 12v and the bulbs are all #55 singles. Painless harness throughout the car. Would it have something to do with the grounds? Each bulb grounds by the socket snapping into it's respective case. They last for a day or two and then they pop.
  2. gimpyshotrods
    gimpyshotrods
  3. chicken
    chicken
    from Kansas
    Aren't #55 bulbs 6V? A #57 is the 12V version.
    squirrel, 302GMC and The Shift Wizard like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes #53 is 12 volt.
  5. patsurf
    patsurf
    are they really bright for a bit??
    302GMC likes this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
  7. Bandit Billy
    Bandit Billy
    According to Meatloaf, you may be taking too long. Try not thinking about baseball.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Praying for the end of time ...
    lothiandon1940 and Bandit Billy like this.
  10. Bandit Billy
    Bandit Billy
    I can see paradise by the dashboard lights.
  11. Budget36
    Budget36
  12. gimpyshotrods
    gimpyshotrods
    Every single listing that I have found says that a GE55 is 7V.
    As @Johnny Gee says you want a GE53. Those are 12V.
    They have them at oh oh oh really? https://www.oreillyauto.com/detail/...-incandescent-mini-bulb-pack-of-2/syl2/53llbp
  13. squirrel
    Beware that the answers you get on google these days are "fixed" by AI to give you the wrong answer.
    ClayMart, bobss396, pprather and 5 others like this.
  14. Wanderlust
    Wanderlust
    I had to purchase a 12 pack of bulbs, smallest amount I could get on a special order. Not cheap and not any good either, after through 6 in no time at all, now I just scavenge them from the bone yards, a 9 volt battery will show if their good
  15. chevy57dude
    chevy57dude
    What is the actual voltage at the lamp socket? At the alternator when running? As stated, your regulator may be set too high. 14.2 volts at the alternator is about right.
  16. garyf
    garyf
    If it is electric spikes in your system causing dash bulbs to blow out, you can dim them to absorb the spike till you find the cause. It's easier than replacing dash bulbs
  17. MAD MIKE
    MAD MIKE
    from 94577
    gimpyshotrods likes this.
  18. evintho
    evintho
    To be honest, I haven't done any troubleshooting yet but I will. My 3G alt is a brand new PA Performance unit. I'll check the voltage. I'll have to pull my speedo and radio again just to get to the lamps then I'll check the socket voltage. I'll also replace with 53's. Hopefully, that'll do it!
  19. squirrel
    55 bulbs will be fine in a 6v car, but won't last long with 12v applied to them.
    I have a box of them for my pinball machine, but use 57s in the cars. 53 is pretty dim.
    bobss396, evintho and Johnny Gee like this.
  20. evintho
    evintho
    So, if I'm reading this correctly, 57's are also 12v and are brighter than 53's?
    BTW, just measured and I have 14.76v at alternator output stud.
    chevy57dude and squirrel like this.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes.
    Voltage is ok. Just a tat high but I’d run it. #57’s can handle what your alternator is putting out. I’d even bet the voltage at the lamp socket is lower due to run length and smaller gauge wire.
    bobss396, chevy57dude and squirrel like this.
  22. squirrel
    Yeah, just get some 57s, put them in, be done with this issue.
    chevy57dude, chicken and pprather like this.
  23. chicken
    chicken
    from Kansas
    Exactly. This is a no-brainer. You have 6v bulbs in a 12v system....not gonna work.
    chevy57dude likes this.
  24. evintho
    evintho
    Got it. I'll pick up some 57's tomorrow.
    Thanks everyone! HAMB to the rescue.....again!
    bobss396 and chevy57dude like this.
  25. patsurf
    patsurf
    alright--lets see the pinball...
    squirrel likes this.
  26. squirrel
    it's OT, sorry! 1976 Gottlieb Royal Flush. One of the last electro-mechanical machines.
    patsurf likes this.
  27. d2_willys
    d2_willys
    from Kansas
    55 bulbs might work IF you turn the panel dimmer control down to at least 1/2 the range of the control. This is 1/2 ***ed though.
  28. jimmy six
    jimmy six
    6 volt bulbs work just fine if you turn down the rheostat on the light switch.. But you need all the interior lamps to be 6v and don’t turn it up… there will be a load on the rheostat which causes heat not normally there when on the highest setting…….
