Technical Why no or weak spark?
Discussion in 'The Hokey Ass Message Board' started by johnnybronco, Dec 10, 2021.
  1. Budget36
    Budget36
    A good DVM will also show the pulse at the bottom of the screen. Won’t be like an ****og meter, but will still indicate a rise and fall of DC.
    jaracer likes this.
  2. johnnybronco
    johnnybronco
    Now you tell me. Bell is ringing like someone just fired off a .45 next to my ear. :confused: How do I prevent that when testing next time? Yowsers.
    Need to walk away for tonight, but thanks for all the tips so far, gang. Done a bunch of Pertronix in the past and have always like the simple two wire hookup. The only issue I have ever had was the low voltage through a resistor wire which was brought up earlier.
    I'll keep you posted. I don't think it is a cranking or battery issue. It's something with my wiring, Pertronix coil or Ignitor. Starting to think the Ignitor even though it p***ed my last test.
    This particular Pertronix kit is designed for 12v not 6. I'm honestly not even sure they even make a 6v unit.
  3. I agree a scope would be best, but a two lead (positive and negative) LED test light would work fine as well. If the Pertronix unit is working correctly, the negative side of the ignition coil will flash red-green-red-green and so on if it’s working correctly when cranking.
    VANDENPLAS likes this.
  4. saltflats
    saltflats
    from Missouri
    Need to check the phasing of the rotor.
    Truck64 and Wanderlust like this.
  5. Ebbsspeed
    Ebbsspeed
    DVOM's aren't traditional. My Simpson 260 ****og meter shows pulses at engine cranking speed.
    Blues4U, Truck64 and jaracer like this.
  6. d2_willys
    d2_willys
    from Kansas
    2 things to look at: 1) If points are still being used, then are they gapped correctly? 2) Condenser if still used is shorted to ground or the distributor switching (- side) wire is shorted to ground.
  7. johnnybronco
    johnnybronco
    Ok, I was able to get my timing light working (which really makes life easier); however, this motor doesn't have a stock crank pulley or a timing pointer, so I guess I be trying to time it off that flywheel window.
    Also, one thing that seemed weird when I did the light. My light did (flash) spark when I shut it down. Still worried about another backfire. Advice?
  8. Blues4U
    Blues4U
    from So Cal
    What's with the red wire from the + terminal of the coil to the distributor?
  9. johnnybronco
    johnnybronco
    That is the Pertronix wire. Red goes to + on the coil, the Black goes to - on the coil.
  10. johnnybronco
    johnnybronco
    Why would my timing light give off erratic, non consistent flashes at cranking?
  11. Truck64
    Truck64
    from Ioway
    What kind of timing light? Some of them (dial back) don't play well with certain types of ignition. Pertronix basically either works, or it doesn't.
    Since this engine has never ran since you've taken over, a different approach is required. You can't ***ume anything. The previous occupants could have done just about anything wrong, and probably did. So you need to check everything.
    Are the (for example) spark plug wires connected in the correct firing order? Do you know for sure i.e. have you verified this?
    "***uming" everything is more or less straight at that point I'd find TDC for the #1 piston using a piston stop tool and make my own "0" mark. Then static time the distributor to set the ignition about 5 or 10 degrees BTDC.
  12. johnnybronco
    johnnybronco
    Light is just a basic old Craftsman. No timing adjustment dial or anything. Just a straight up induction light with wire clip and two battery connections.
    Firing order was wrong when I got it, but is right now.
  13. Truck64
    Truck64
    from Ioway
    OK...
    I'd still want to verify TDC "0" on the pulley or damper or whatever. Because even if you time it correctly with a timing light, it is only going to be as accurate as the timing marks. It sounds a little like the ignition timing is retarded a lot for whatever reason.
  14. Truck64
    Truck64
    from Ioway
    When you ground a spark plug to a head bolt or whatever and crank the engine over it should have a nice fat snappy rythmic hot spark. Kind of bluish white. It has to have a good spark, not just "a" spark.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    put the points back in it, I bet it will start right up.....
  16. johnnybronco
    johnnybronco
    About to try that. Getting fed up with it.
  17. Truck64
    Truck64
    from Ioway
    Wouldn't it be easier to check the spark first, though?
    Work smarter, not harder!
    Blues4U likes this.
  18. johnnybronco
    johnnybronco
    Yes, I’m trying to avoid swapping, Truck64.
    Can anyone explain what would cause my spark to be erratic? I can reach my timing light into the cab while I crank and it is getting spark, but it not a steady, rhythm of flashes. Shouldn’t it be with steady cranking?
  19. Budget36
    Budget36
    Are you on the coil wire?
  20. johnnybronco
    johnnybronco
    I am on #1.
  21. Doublepumper
    Doublepumper
    from WA-OR, USA
    Cracked or carbon tracked dist. cap, slipping dist. drive gear, worn dist. shaft bushings, bad contacts in the ign. switch, causing intermittent dropped voltage to the coil, points worn/misadjusted, oxidized contacts, pickup coil or control module faults, are a few.
    Bring #1 piston up on compression, align timing marks for initial timing, and check rotor position against #1 cap terminal. While there, check for shaft side play and try to turn rotor. If all good, loosen dist. hold down slightly, to enable turning dist. by hand. With timing light connected or #1 plug grounded, turn on ignition and rotate dist. back and forth until there is spark or timing light flashes, stop there and tighten down dist. Start the engine and check timing.
    Truck64 likes this.
  22. Truck64
    Truck64
    from Ioway
    Pertronix Ignitor isn't some super sophisticated high-tech gee-whiz-bang component. Some people don't like them, but they will either work, or not. Make sure the little uninsulated braided copper ground wire is still inside the distributor connected from dist. housing to points plate.
    On the timing light itself, if I was su****ious I would connect it to a running engine to verify that it appears to be working correctly. Sears hasn't made a timing light in a long time.
    Is there in fact a good spark at the plugs or not? We're on pg. 2 now. A more broad test is simply disconnect the coil wire at the distributor and hold terminal about 1/2" from a head bolt or good ground. It should have a stout spark there.
    (For troubleshooting a remote switch is nice to have. Two alligator clips, some wire and a push****on and Bob's Yer Uncle. Connect one to the + battery terminal and the other to the I terminal on the solenoid.)
    Careful not to forget and leave the ignition key switch in "Run" during your testing of everything. This will sometimes cause coil to go all 'splodey after a half hour or so.
    Blues4U likes this.
  23. johnnybronco
    johnnybronco
    No progress yet. It appears these distributors get a little "sticky" in the block over the years. Lot of meat on that distributor shaft that mates with the block. Yikes. Mine doesn't appear to have seen the light of day since '46 either. Soaking and doing some prayers. Don't want to go down the road of these two soldiers.
  24. johnnybronco
    johnnybronco
    Guess who was right? Something about sticking with stock stuff. Put the old coil, cleaned old points, and put resistor in and she started in one crank.
    Had good luck with Pertronix in the past, but looks like their coil was probably the failure point. She’s leaking only after a few starts. Think the module is still good, but it still won’t be going back in.
    Distributor still won’t budge, so that will have to wait for another day. Thanks gang!
    Moriarity likes this.
  25. A Boner
    A Boner
    You might want to buy some new sparkalaters!
