Technical Why not the C4? TH350 vs C4
Discussion in 'The Hokey Ass Message Board' started by 57JoeFoMoPar, Feb 14, 2024.
  1. 57JoeFoMoPar
    57JoeFoMoPar
    When talking about swapping to a more modern transmission, it seems almost universally the first transmission that comes up is the TH350. In fact, GM Turbo Hydramatics seem almost universally more popular than offerings by Ford or Chrysler. Admittedly, GM makes some good transmissions. The Powerglide in stock form made for reliable cruising and modified made for a great drag transmission. The TH400 is tough and strong and well suited for heavy duty applications. The 700R4 is the path of least resistance into automatic overdrives and doesn't require a computer to run.
    And the TH350 seems to be the gold standard for ease of installation and operation, needing only a vacuum source to function. They shift nice, gear ratios are suited for a wide array of uses, and they can take a decent beating. They're also the second half of the 350/350 combo that has dominated rodding for the past 40 years. It's a proven formula.
    The intent of this thread is not to say "Why the TH350?" Instead, I want to focus on the positives of the C4. Having owned both, I'll start.
    -I can't speak for the upper limits of the C4s capabilities but probably 90% of us do not have drivetrains that are going to turn a properly functioning automatic to minced meat with raw horsepower, outside of abusing driving habits. The C4 seems to be comparable to the TH350 in terms of durability.
    -In modified form, the C4 seems to be a very sturdy transmission, often used in SBF and Mustang drag applications.
    -Gear ratios are substantially similar.
    -Neither requires a TV linkage and is able to operate properly with a vacuum source for the modulator.
    -Performance parts are readily available and not terribly expensive.
    -The C4 is physically smaller than the TH350, and would be able to fit in a more confined space.
    -The C4 has a completely removable bell housing that could, in theory, be utilized for a number of applications where the Chevy bolt pattern is too big, or where there is no need for an integrated bell on the transmission case, such as Early Hemi, Early Cadillac and so on, where there is a deep skirt on the block.
    -The SBF/C4 seems to be the lesser used, but still very effective, alternative to the 350/350. Which is still a proven formula.
    So with all of that said, why not use a C4?
    LCGarage, loudbang, Cooon and 3 others like this.
  2. 73RR
    73RR
    Good question Joe.
    One of my adapter projects (about half finished) is for using the C-4 behind the 51-53 331 Chrysler Hemi specifically because of the removeable bell. I also know that the C-4, with the proper pile-o-parts, will hold near 800-900hp. That is no small feat.
    Why the popularity of the sbc and ***ociated parts? I can't figure it out. Must be the kool-aid.
  3. tjm73
    tjm73
    Behind a small block Ford or road going Cleveland there is no reason to convert to a TH350. The C4 will reliably do the job. And the aftermarket support is quite good for them too.
  4. RmK57
    RmK57
    Nice thing about a C4 or C6 is when you start in second gear it starts off in second, rather than upshifting to second like a t-350, handy for burnouts. Good little trans that can hold big power, but won’t be cheap.
  5. I’ve seen healthy big block Chevys which c4s
    The reasoning I got from em was the parasitic drag was low.
    Those c4s were heavily modified.
  6. 57JoeFoMoPar
    57JoeFoMoPar
    Agreed. My question was less about putting a TH350 behind a engine that was intended for a C4 and more about why when we do off branded swaps the default always seems to be to the GM TH350 for a basic 3 speed. But your point is well taken.
  7. 57JoeFoMoPar
    57JoeFoMoPar
    Less parasitic draw is another good reason I hadn't considered.
  8. 57JoeFoMoPar
    57JoeFoMoPar
    As I'm seeing it right now, a TCI StreetFighter C4 is actually a couple hundred bucks cheaper than the TH350 from Jeg's. I agree with you though that Ford and Chrysler parts are going to be more expensive than Chevy, but I feel like in the grand scheme of things, the difference in cost between the C4 and TH350 is negligible.
    loudbang and 73RR like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Because a C4 does not bolt up to any of the SBC’s in my fleet. ;)
    Jibs, 51 mercules, reagen and 4 others like this.
  10. 270ci
    270ci
    Does anyone even make a C4 adapter to a Chevy engine....or is that outright Blasphemy?!
  11. 73RR
    73RR
    I doubt that the shiverlay crowd would ever buy one so no market = no margin. Personally, I wouldn't even bother to sketch out a rudimentary design.
  12. the C4 has good aftermarket support and is extremely light. Plus the added caveat of having a separate bell which makes it pretty adaptable. You can buy a bell for many applications other then Ford motors. I actually saw one with a GM bell a couple years ago.
    The adapter bells are not cheap. Last I priced them they ran about 400 dollars probably way more than that today.
    I think they are an excellent option for a small car. The thing that keeps me from using one is cost. I am just not in a position to drop that much cash to bolt a ****** whatever I am running. That they are a good choice if you got the cash.
    anthony myrick likes this.
  13. RmK57
    RmK57
    I’ve considered using a C4 behind my 501 bbf. Still might but have to find a core C4 with a 429-460 bell. There out there but not too common and then there’s the cost of the build $$$$$…..
  14. oldolds
    oldolds
    porknbeaner and 57JoeFoMoPar like this.
  15. Plus you get 3 gears opposed to 2 from a PG
    I’m hearing they are similar in weight and parasitic drag.
    Truth?
  16. loveoftiki
    loveoftiki
    from Livonia,Mi
    Got one in my car..can withstand some HP when built right..post 70 26 spline are the desirable units..I had a very well known shop do mine and it was pretty reasonable
    34 5W Paul and loudbang like this.
  17. saltflats
    saltflats
    from Missouri
    Most seem to always start out in second for me after a rebuild.
  18. seb fontana
    seb fontana
    from ct
    Funny.
  19. squirrel
    May be funny, but there's something to be said for Chevy bellhousing bolt patterns being the same for so many engines over so many decades. It makes sense to adapt something that is common, even if it's not quite the best transmission. Bonus is that if you adapt for the Chevy bell, you can also choose a PG, 200, 200-4R, 700, 4L80E, 400, 6L80E, 8 speed, 10 speed, etc.
  20. bchctybob
    bchctybob
    Every C4 I have ever had has worked great.
    Years back, I was building a Model A coupe for my Dad. The plan was to use a 322 Buick but my Dad wanted an automatic due to his advancing age. I figured that the C4 was the perfect candidate since my measurements showed that I could get it into the Model A ch***is with a lot less cutting than any other automatic trans - like none. As I researched it, I arrived at the same thoughts as 57JoeFoMopar. Why isn't the C4 used more often? It's readily available, has small outside dimensions and low parasitic drag. Unfortunately, my Dad's health declined rapidly and the project went away but I still think that the C4 is underutilized.
    I think a series of adapter kits for early V8s would be great. If only I was ten years younger....
    rod1, aussie57wag and loudbang like this.
  21. Having a bolt on bell is a plus.
    Ned Ludd likes this.
  22. squirrel
    yeah, and now you can get bolt on bellhousings for the th350, if that's the way you want to go
  23. Sure. Ya just have to cut off the old one
    just easier to fix those pesky bell housing cracks.
  24. squirrel
    yup. Ford saves you that trouble.
  25. JohnLewis
    JohnLewis
    IMG_0008.JPG IMG_0344.JPG IMG_0345.JPG IMG_0710.JPG Always perfered the fords over chevy, ignore the scribble (electric water pump) and the broken case. Still worked just fine lol.
    loudbang and bchctybob like this.
  26. Growing up if we were looking at trucks to buy and it had a c4, we usually p***ed on em. I’ve got a SBF c6 in my save pile at home.
  27. RmK57
    RmK57
    Most if not all of those sbc bellhousings are SFI approved. More of a necessity than getting tossed in the tech line. So I guess the whole trans is an aftermarket creation?
    squirrel likes this.
  28. Ebbsspeed
    Ebbsspeed
    Looks like that bell also has the Chevy and BOP pattern.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Nope. But I did have a T350 with the pattern you mentioned. IMG_2461.jpeg IMG_2462.jpeg
  30. Ericnova72
    Ericnova72
    from Michigan
    JPT (Jim's Performance Transmission) in Eaton Rapids, Mi was a proponent of this, even tried to talk me into a C-4 for my Nova instead of the Reverse manual TH-400 he was building for me.
    He had bells cast and everything.
    Wanted me to use a full roller bearing C-4 instead. I couldn't get over how tiny it was.
    I know he had a lot of guys using his C-4's in racing.
    Jim Paquet, brother of Super Stock Thunderbolt racer Ray Paquet.
    He's retired now though, 10 years at least.
