Why SBC runs way hot on right bank?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Aug 1, 2011.
  1. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Ok, I know this probably isnt helping his problem much and I dont want to hijack his thread, but I always figured that extra hole on the p*** side of the water pump mating surface was a "byp***" that was built in. The way I see it, running a hose either through the heater core, or just a loop from the intake to the water pump is doing the exact same thing that small hole is doing....putting water on the intake side of the pump....please correct me if I am wrong, so I can inform my engines that they have been working incorrectly since 1988, thanks:D:D:D....
    Now if he has no loop or heater, and has plugged that small hole (with silicone), I think that it would create a problem, but not convinced that the problem would be limited to only one side. I am with the guys that say its either and intake or exhaust gasket/seal prob....time to invest in a vacuum gauge, and one of those infared temp sensing guns...If you work on your own cars they are good investments anyway.
  2. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Just out or curiosity....are you running a pcv system? If so how is it routed, and also where are you getting your modulator vacuum for your ******? (im guessing its a th350)
  3. Engine man
    Engine man
    from Wisconsin
    The header color could be a difference in air flow over the outside of the headers.
  4. S.O.B.
    S.O.B.
    You might have a late model water pump that uses a flat belt. If this is the case, the pump is running backwards.
  5. lippy
    lippy
    from Ks
    Luke, may the force be with you...read your plugs, read your plugs...
  6. oldrelics
    oldrelics
    from Calgary
    No leaks detected, no vacuum on the dipstick tube.
    Th350 vacuum fitting in one of runners of the rear of the intake.
    Its a short style water pump so definately early.
  7. oldrelics
    oldrelics
    from Calgary
    black sooty. but I can't take it for a long drive yet....
  8. mustang6147
    mustang6147
    from Kent, Ohio
    If it is only the header getting hot, then it is an exhaust valve issue. Either to tight or burned. perhaps a valve isnt seating?
    One thing good, its the valve right where the header is hottest. no more **** shoot.
  9. IndyHolland
    IndyHolland
    Hmmm, two carbs and one side getting hot. Throw a four barrel carb on it, see if that solves it. How confident are you that both carbs operate correctly?
  10. bobss396
    bobss396
    Everything is pointing to a lean condition on that bank, too much air or too little fuel. I'd leave it as is, put in fresh plugs, take it for a nice run and read the plugs, see what the differences are between the two banks.
    Bob
