Technical Why Was Factory Ignition Timing So Retarded?
Discussion in 'The Hokey Ass Message Board' started by Truck64, Oct 29, 2016.
  1. Truck64
    Truck64
    from Ioway
    Tuneup specs for old school iron typically runs 3° or 4°, but savvy mechanics know the engine will run much better with advancing ignition timing as far as practicable just short of pinging or detonation. The engine will run cooler and get much better fuel economy and power. It's not so much that the total timing numbers is any different but when in the advance curve certainly is. I'm running 17° initial and around 37° total with light springs and pump gas. With vacuum advance it is even more of course.
    So what was the rationale though for the slow initial timing? Keep in mind this was long before any thought was given to emissions control or high compression designs as well.
  2. khead47
    khead47
    ****py fuel back then?
    Atwater Mike and Truck64 like this.
  3. oj
    oj
    Its a complicated subject but originally timing was retarded to start the engine, manifold vacuum would quickly get it into the 16-18ish range and mechanicals would get it higher. Enter the fed's and they want emissions, vacuum went to ported and the retarded timing at idle burnt the g***es better.
  4. wraymen
    wraymen
    Just guesses here, easier to start(crank), lower operating temps and economy.
    lothiandon1940 and Truck64 like this.
  5. jimmy six
    jimmy six
    Pollution, simple answer in California anyway.
    Truck64 likes this.
  6. ^^^^^^^^^^^^^^^
    All the above answers are correct answers.
  7. Truck64
    Truck64
    from Ioway
    Easier to crank, yes. But operating temps actually go down not up with advanced timing.
    Fuel economy goes down with slow timing as well.
    need louvers ? and Atwater Mike like this.
  8. Truck64
    Truck64
    from Ioway
    Ported timing vacuum predates emissions controls by decades. It was around long before anyone worried about smog. It is true that retarded timing keeps certain pollutants at bay, I think that's why they had to introduce catalysts. An efficient (read fuel economy) burn means lots of nitrogen oxides, the component that makes smog. So they retarded the timing at idle, and then burned all the wasted gas in the exhaust? That's stupid, but I think that's what happened?
    But none of this mattered in the 1930s, and they had 3° or 4° timing specs for the initial timing then.
    6 volt systems maybe didn't crank so well?
  9. Truck64
    Truck64
    from Ioway
    I thought of that, but the actual total timing doesn't really change with a "hot rod" advance curve. V8 runs about 35 degrees or so not counting vacuum advance. Tuners just change when this advance happens, and how quickly.
  10. warbird1
    warbird1
    Exactly... I don't know where the myth about ported vacuum advance not being in use before emission controls came from. But that's what it is; a myth. Ported vacuum was in use on most makes in the late 40's-early 50's. Well before they were worried about emissions...
    need louvers ? and Truck64 like this.
  11. squirrel
    wonder how the really low idle speeds contributed? like 450 rpm was standard
    Truck64 likes this.
  12. jeepsterhemi
    jeepsterhemi
    Plus, all the time the new car was under guaranty and tune by dealer mechanics, it seems to perform less than what you'd expect!!!!........... around here anyway...........
    Truck64 likes this.
  13. Rusty O'Toole
    Rusty O'Toole
    Some good answers. Gas was low in octane, and they had to set up the engine so it would start and run without fail, red hot or stone cold, on top of Pikes Peak or the bottom of Death Valley, and Mrs Peasy Weasy could make every driving mistake in the book and still make it to the Piggly Wiggly with no drama.
    Needless to say this meant some pretty conservative decisions. Which is why a hot rodder could get 25% to 50% more HP without hurting drivability or reliability too badly.
  14. oj
    oj
    Maybe we are using the terms differently, I believe 'ported' vacuum is that vacuum sourced from above the throttle blade - like carbs from the 60's on up have. That was an emissions thing, when at idle the distr retarded an draised the exhaust gas temps to burn off the fuel and reduce emissions. You won't find a 'ported' vacuum fitting on any carbs from the 40's or 50's that I'm aware of.
    I'm not 100% certain and can be wrong.
  15. Truck64
    Truck64
    from Ioway
    The MoToRs Repair manual I have from 1950 says that ported vacuum is used (above throttle plates) so as to obtain a steady idle. It was used long before that, I would imagine. Some manufacturers did use manifold vacuum, and ported was used to keep certain NOX emissions lower, but the ***ertion that ported vacuum is some kind of emissions era atrocity invention foisted on us is not the case. Maybe they had to use it because of technical considerations, but it's been around pretty much forever, probably as long as vacuum advance anyway.
    need louvers ? likes this.
  16. warbird1
    warbird1
    Nope, were are not using the terms differently. Let's see here: After Ford lost the lousy Load-a-Matic distributor in '57 they went with ported vac*** (the Load-a-Matics used both ported and manifold vacuum), Early 50's Cads and Olds used ported vacuum (I've had and worked on a few of those) and the Ignition Systems chapter of my 1950 Motor's manual shows both Autolite and Delco-Remy distributors using ported vacuum... The idea that ported vacuum came about because of emission controls is a myth...
  17. warbird1
    warbird1
    Truck64... you beat me to it! ;-)
    And I just checked my Motor Service's Automotive Encyclopedia from my days at Tech. School long ago. The vacuum advance section of the Engine Ignition chapter makes NO mention of manifold vacuum being used for distributor advance, just ported vacuum. Also, this book is old enough that it has no mention of emission controls.
    Truck64 likes this.
  18. blowby
    blowby
    from Nicasio Ca
    So with all the tweaks Duntov did to obtain one horse per inch with the 283, all you had to do was bump the timing to get more?
  19. 19Eddy30
    19Eddy30
    from VA
    Use a Vac gauge , @ idle to set initial timing and go from there ,Then check total timing , a good # around 35 degs
    But not set in stone , then if timing is like 50 degs or higher
    You have to limit total timing , stops on Avance,
    Some engines like 35,36,-45 total deg of timing,
    You have to experiment and do***ent what you're doing !!
    This is part on how to tune a engine,
    Ist not just bolt in and go!!!! Work has to go into it,
    I uses a 6 inch round vacuum gauge that reads 0 to30 in 1/8 internets , But I am a die hard Motor Head !!
    Truck64 and need louvers ? like this.
  20. Truck64
    Truck64
    from Ioway
    Sure, everything you mention is correct. I just wondered why Ford or Chrysler or anyone else didn't use a hopped up curve, especially initial timing. For one thing, fuel mileage improvements. I've seen V8 mileage double with careful tuning.
    Some people claim that "back in the day" nobody cared about fuel mileage because gasoline was 20c a gallon. I don't believe that either.
  21. squirrel
    20c a gallon was a lot when you earned less than a buck an hour.
    sunbeam, Bubba1955 and Hnstray like this.
  22. Engine man
    Engine man
    from Wisconsin
    They didn't burn anything in the exhaust. They just pumped clean air to mix with the exhaust to make cleaner exhaust. Of course that isn't what they told the government but all that was needed was for the exhaust coming out of the tailpipe to meet the specifications.
  23. 19Eddy30
    19Eddy30
    from VA
    A ll the guys I now that worked a Dealership
    In late 50's - 70 where doing this to cars Wright off dealership lot , I guess that's why their cars were kings over other guys they didn't know tunning tricks
    Truck64 likes this.
  24. 54stude
    54stude
    Truck64 understands a bunch about combustion, and combustion g***es based on what he wrote. He made a good point, which could be restated this way, good hot and clean combustion of fuels makes higher levels of NOx, which is why they cars of the 70's and 80's run like they do. Dig into this if you want to learn more.
    https://en.m.wikipedia.org/wiki/NOx
    Truck64 likes this.
  25. Truck64
    Truck64
    from Ioway
    Thanks for the kind words, but I really don't understand very much about this. I've read that an engine tuned and timed for maximum fuel efficiency and power will fail certain exhaust emissions measurements. NOX I think, there's HC and CO standards too. It's kind of a balancing act to meet the specs, and probably why some of the 70s era motors were so problematic, they were de-tuning the timing, "lean burn", lowering compression and other things that were kind of a Rube Goldberg approach to the problem at hand.
  26. caton462
    caton462
    I've heard stories of broken arms from hand cranking an over advanced engine. We had a v-12 in the shop some time ago the timing procedure was to set the timing at top dead center and keep advancing it for best vacuum then back it off if detonation or starter kick ocurred
  27. Come on over! Show my Buick to you
    Ben
  28. 19Eddy30
    19Eddy30
    from VA
    The trick when timing is hight at idle is to spin the engine before you turn on the ignition,
    No kickback even with a hand start
    It would be interesting to know the real reson for 6-8 Degree's at idle ,
    Was it poor gas or to keep starter kick back from occurring ???? Or what !!
  29. Los_Control
    Los_Control
    from TX
    I know of 1 engine in particular, I was doing some research on it.
    Thinking I might buy it for use in something else.
    1978 ford 400 small block.
    They retarded the timing on it by relocating the key way in the timing chain gears.
    They did this for emissions. But it is simple to install a older timing chain set from a older engine year.
    This just raises the question, How many engines did this, and would there be any practical gain?
    Or can you just rotate the distributor and advance it as much?
    Would there be any value to a list of the different ford, chevy, dodge etc... engines that did this?
  30. squirrel
    You're talking about cam timing. We were talking about ignition timing.
