Technical Why wheel bearings are greased
Discussion in 'The Hokey Ass Message Board' started by trulyvintage, Oct 9, 2018.
  1. cadillacoffin
    cadillacoffin
    you paid someone to do a brake job.........?
  2. lonejacklarry
    lonejacklarry
    Did they teach you how to avoid dropping the newly packed bearings? I have a hard time with hand to spindle action.
    loudbang and blowby like this.
  3. Deuces
    Deuces
    Nope! I do my own.....
  4. Unkl Ian
    Unkl Ian
    Ever heard of "Film strength ?
  5. G-son
    G-son
    from Sweden
    Seems to be popular on US boat trailers, from what I've seen online. I can kind of see the point of pushing fresh grease through the bearings regularly, especially on boat trailers that get driven so far down the boat ramp so the axle(s) are below the surface. Around here we usually stop with wheels & brakes above the water line instead, boats load and unload fine anyway…
  6. 1996 F350 Quad Cab Dually 7.3 PSD
    Front rotors are one piece - I replace rotors & wheel bearings & pads when I have the front brakes serviced
    Calipers have to be compressed to remove & install pad - I don’t carry tools for that.
    I do pretty much all of my own service work on my truck & trailer.
    Jim
  7. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    lonejacklarry: Like I stated "Back IN 54" I wuz 21 just barely legal to have a beer,regular beer not 3-2.. Never dropped a thing back then ,not so much taday. Hell I'm barely able to pick anything up. Items that is.ha ha
  8. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Come on man improvise, string or wire or just squeeze them back after you open the bleeder.
  9. Atwater Mike
    Atwater Mike
    Well, then: "Take it easy, Greasy...you've got a long way to slide.":D
    pitman and Blues4U like this.
  10. Atwater Mike
    Atwater Mike
    Great idea...and ABOUT TIME!!!
  11. Blues4U
    Blues4U
    from So Cal
    I'm not familiar with those specific calipers, but compressing calipers to install new pads isn't difficult, a C-clamp has done the job for me too many times to count. Maybe there's something about these calipers that prevents that? Anti-lock brake systems may have some other considerations.
    loudbang, pitman and TTR like this.
  12. Might even suggest to surrender his AS* certificate + badge to nearest dumpster and contact school for due refund ? :rolleyes:
    Bearcat_V8 and Unkl Ian like this.
  13. ... and on a roadside emergency service, almost any pry-bar, screw driver, etc will likely work too.
    Unkl Ian likes this.
  14. Most new cars ( and I’m talking late 80’s to present)
    Require a tool to compress the rear pistons in the caliber, the piston is threaded to apply the parking brake
    Some cars need pressure and turning to press the piston in
    Some just turning
    Some also require the “ electric parking brake” denergized.
    And don’t get me started on abs and traction control “ warnings”
    New cars **** for the most part from a service stand point
    BAFBD021-C4A8-4DD8-9348-678C9604D226.jpeg DD415543-BCD5-4974-87B5-29163ED0833F.jpeg
  15. OK !?! o_O:confused:
    I was (mistakenly again ?) under the impression this site is dedicated to '65 and older vintage car discussions and stuff.
    OTOH, that "Hokey ***..." obviously covers and can mean more than I can comprehend. :rolleyes:
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    I gotta see one of these miracle Swedish boat trailers ......
  17. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    2old2fast they prolly bend or tip up & have rollers.
    VANDENPLAS I did the wifes park avenue with out anything but a C clamp. That is all 4 wheels.
    No clue what your trying to say.
    And the OP was defending why he did not do his own brakes and some folks where confused as to why he needed special tools.
    What year park ave and did it have the parking brake integrated in the caliper?
    Anyways to get more on topic with this site
    Drum brakes are better anyways and so are roller bearings !!
    Lol
  19. Well,...
    ... if OP would've disclosed in his opening post that this discussion is about some nineteenninety**** (OT ?) vehicle, I would've stayed clear and saved my two cents. :rolleyes:
    Teaches me to chase rabbit holes, right ? ;)
  20. thirtytwo
    thirtytwo
    Doesn’t matter out there somewhere is a “ase mechanic” who thinks grease is not really meant for lubricant... he could be working on a model a he will think the same thing
  21. bobss396
    bobss396
    It is possible that a bearing could get dirty, most likely from a tub of contaminated grease than anything else, or some crud gets knocked off when you tap in the oil seal. I now buy my bearing grease in the smallest possible container and don't dig into it with dirty hands, never put any excess back into the tub.
    Bearcat_V8 likes this.
  22. sunbeam
    sunbeam
    The thing wrong with the zerk where does the grease go if over greased into the brakes.
  23. This was about grease !!!
    In true Hamb fashion the pepper and fly **** turn the focus.
    First to brakes, then service, then it's about @TTR ,,, again. No disc brakes are Pre 65 and no 65 service manual states a procedure for retracting calipers. You'll find nothing there about pry bars or scwerdivers or C clamps or twist in pistons.
    So you're right @TTR but still hoisting your own petard.
    Have something interesting to add about grease or wheel bearings ? No need to pepper it up into a brake job or roadside work or shop procedures
  24. bobss396
    bobss396
    Looks like a *** toy gone real bad.... but more lube is better than NO lube....
