Why would my carb be smoking?
Discussion in 'The Hokey Ass Message Board' started by Stevie Nash, Apr 4, 2011.
  1. Stevie Nash
    Stevie Nash
    So I just installed a used Edelbrock (1406) carb on my 327 sbc. The thing looks brand new, got it from a guy here on the HAMB. It has an automatice choke, which is really why I bought it.
    Turn the starter over and the thing starts right up. Voila!!! Let it run for a couple of minutes, mess with the idle but not the mixture screws. Turn the engine off and smoke starts coming out of the carb. Not a lot, but not a little either if you know what I mean.
    What would cause this? I haven't messed with the other carb adjustments yet...
  2. shemp
    shemp
    Alliance Vendor
    Your needle and seat may be leaking gas after you turn your engine off.
  3. Bill Van Dyke
    Bill Van Dyke
    Not enough info..but too rich? What do the plugs look like?
  4. Harms Way
    Harms Way
    Q;
    A;
    Because it wants to look tough, and be part of the wrong crowd,... Just remember, it won't be able to smoke in public or inside a building,... I suggest you have a talk with it,... and explain what that kind of activity will lead to. I hope this helps,.... :D
  5. harrington
    harrington
    from Indiana
    Gas is leaking out of the carb and into the intake. Find the source of the leak, most likely it is a bad needle and seat.
  6. Mike51Merc
    Mike51Merc
    Did it start by chewing gum? Will it be doing hard drugs and having unprotected *** next?
  7. johnnie
    johnnie
    from indiana
    Check the fuel pressure. Ebrocks don't like more than 5psi.
  8. BE CAREFUL, those fumes are toxic and could lead to an addiction to Hot rodding or racing....or a professional job working on cars..... Warning..Warning.
    Your fuel is leaking, its not smoke, it fuel vapors caused by: too high fuel level, or the needle and seats (one or both are leaking) or leaking float, or too high fuel pressure.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    X2, this is the most common problem with the Edelbrock Performers and Carter AFB's put a fuel pressure regulator on it and set it at 4 1/2 psi and you should be good,you will probably find 100's of posts like yours on the web and the solution will be the same.
  10. It just got laid...........................
  11. Stevie Nash
    Stevie Nash
    I don't think that's it. The fuel pressure is 5-6 psi...
  12. budd
    budd
    it is fuel leaking in, try to shine a flashlight down the carp when you first shut it off.
  13. Harms Way
    Harms Way
    Yes,... sadly, If it dosen't change its ways,..... it's unfortunately inevitable, I remember seeing the movie in junior high school,..... it's not pretty,... next thing you know,.. it will be hanging out in pool halls and consorting with loose women,... this should be nipped in the bud ! :D:D:D
  14. Abomination
    Abomination
    Maybe a phenolic spacer would help, too.
    ~Jason
  15. JeffB2
    JeffB2
    from Phoenix,AZ
    If you are sure the fuel pressure is as recommended then the next step is to check the float level and float drop settings these settings can be knocked out of wack from being jostled in shipping,you can download the Edelbrock tuning and troubleshooting guide off the Edelbrock website.
  16. Frank
    Frank
    I have the same issue and I have read other similar thread and they all seem to point to getting a new phenolic spacer because your carb is probably boiling due to heat soak. I think it makes sense. I just haven't been to a parts store to get one yet though.
  17. dirt slinger
    dirt slinger
    x2 on the float level. Thats always been my experiences on this issue, when the carb smokes on my race motors the float level needs adjusting. This is a holley carb in my situation tho.
  18. 61 chevy
    61 chevy
    here a man asked for HELP, and all you can do is make a joke :eek:
  19. Stevie Nash
    Stevie Nash
    I already have a spacer to get the edelbrock carb on the stock intake. Isn't that pretty much the same thing? Plus it wasn't even running that long so I wouldn't think it was near the boiling point...
  20. 53sled
    53sled
    from KCMO
    its over 5, that is too much. i hydrolocked my 305 with an afb. used a regulator and the problem disappeared.
  21. what he said
  22. d.reese
    d.reese
    Ok, lets start over here. Start the engine, warm to temp and set timing 1st. Then set idle rpms. By doing it opposite (set idle 1st) you are raising the ****erflys up out of idle circuits, causing the fuel to bleed past!
  23. dave lewis
    dave lewis
    from Nampa ID
    Last time I tried that, I got bit and had to throw it back... ( I could not resist..Sorry )
    Dave
  24. Harms Way
    Harms Way
    Why, Yes,..... Yes I did ! :D:D:D
  25. Harms Way
    Harms Way
    I am sooo sorry,... and I owe you all an apology ! I had no idea we were talking about
    Smoking Carp !,..... That can be a really serious problem !
    :eek:Theres the little scoundrel now !!!:D:D:D
  26. Francisco Plumbero
    Francisco Plumbero
    from il.
    Let's see, why does my carb smoke?
    Fuel pressure too high, set it at 5 like they said.
    Floats leak set them at 7/16 with a drill bit.
    Put a spacer in it.
    Here's another, choke not adjusted correctly, so it ran rich while being choked, I didn't warm the engine up long enough to burn the rich fuel load out of it and shut it down with the choke still engaged, let a wispy wiff of rich evaporating fuel out of it. ( Yeah wispy wiff, I know, say that 3 times fast fella.)
  27. 39pontiaccoupe
    39pontiaccoupe
    :D Thank you guys for this thread. I laughed so hard that tears rolled down my face and initally spit my coffee on the keyboard! Some fun! :D
  28. Kripfink
    Kripfink
    If you can't see the humour in the thread ***le then there's no hope for you really. No one's disrespecting the original poster, just having a little fun. Fun, you remember that don't you?
    As to the t***** problem in question, if it's just cigarettes I wouldn't worry too much, but if it's crack cocaine you'll never get it to stop and it will rob you blind to pay for its habit. Have you thought of rehab?
    Paul
  29. R Pope
    R Pope
    I agree that 5# is too much, seen AFB's that had to be below 4# to work right. 3 1/2 seems to be enough.
  30. texoutsider
    texoutsider
    from Frisco, Tx
    not true...Edlebrocks can take up to 9psi
