Technical wide 5 adapters
Discussion in 'Traditional Hot Rods' started by Alaska Jim, Jun 27, 2018.
  1. nailedbuick
    nailedbuick
    I would be interested as well. Thanks
  2. panhead_pete
    panhead_pete
    51 mercules likes this.
  3. Jmountainjr
    Jmountainjr
    You may well know, but the race intended adapters use the 5/8" course thread wheel stud common to most racing applications. Most of the wheels that you might use don't play well with the big 5/8" lug nuts. So before buying come up with a plan to modify / reduce the stud hole to use the 1/2" wheel stud you most likely want to use. I have seen both threaded and splined 5/8" studs used and the hole size varies a bit.
    tractorguy and panhead_pete like this.
  4. 51504bat
    51504bat
    IIRC there is a Dorman 1/2x20 wheel stud that can be used to replace the 5/8" studs used on the roundy round adapters. Maybe @gimpyshotrods knows?
  5. gimpyshotrods
    gimpyshotrods
    Yes, there is!
    Unfortunately, I can't get to the shop! It's not wheelchair accessible.
    It is in the catalog of wheel studs.
    51504bat likes this.
  6. gimpyshotrods
    gimpyshotrods
  7. panhead_pete
    panhead_pete
    Thanks fellas, thats important information I hadnt considered. Cheers for raising that and a solution.
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Moroso 46180
    1/2-20 in Thread
    3.000 in Long
    0.615 in Knurl
    Black Oxide
    Set of 5
    Moroso 46190
    Wheel Stud, 1/2-20 in Thread
    3.000 in Long
    0.685 in Knurl
    Mopar, Set of 5
    Moroso 46220
    3.000 in Long
    0.563 in Knurl
    1/2 in Frankland Hubs, Set of 5
    Also available in kits which include the lug nuts.
    The Dorman parts normally have pretty shallow knurls and most don't have the correct diameters to work with the race car stuff.
  9. gimpyshotrods
    gimpyshotrods
    The 0.685 knurl ones are ringing the bell.
  10. gimpyshotrods
    gimpyshotrods
  11. 51504bat
    51504bat
    panhead_pete and gimpyshotrods like this.
