Technical Wide 5 question
Discussion in 'The Hokey Ass Message Board' started by LarsL, Mar 8, 2026.
  1. LarsL
    LarsL
    from Norway
    Hey guys. Hear me out: Can i use 40-48 backingplates on 37-39 wide 5 drums? If my reading is right, 37-48 drums Are 2 inch deep. So on paper it seems it will work?
    I love the wide 5 look but want hydraulic. Yes i know that 39 is first year hydraulic but to find that specific year here is not easy.
    Am i right? Will the backing plates work? Or to ask more right, will wide 5 drums work on later backing plates?
  2. Budget36
    Budget36
    There’s a way in the front. The Ford Pilot had wide 5’s with front hydraulic brakes, but rears were mechanical.
    That would get you 1/2 way there.
  3. The rears fit fine….I think the later wide 5 fronts will work, my ‘36 fronts did not and I bought later, I think they were ‘39’s…..
  4. 29Sleeper
    29Sleeper
    from SoCal
    I think you mean 5 on 5 1/2 not Wide 5 which are common on Sprint cars etc.
  5. LarsL
    LarsL
    from Norway
    28-36 have 1-3/4 inch deep drums
    37-48 have 2 inch deep drums
    The drums Are 11 inch all the way down to 1928.
    So in my mind, that means that you could swap 37-48 around as you see fit.
    Thats what i Get from it Anyway.
  6. LarsL
    LarsL
    from Norway
    No, im talkin about wide 5. The bolt pattern from 1936 til 1939.
    winduptoy likes this.
  7. RICH B
    RICH B
    '37-'39 fronts and '36-'39 wide 5 drums work with Ford Lockheed brakes and repop Lincoln style Bendix brakes with 1-3/4" shoes.
    '36 fronts won't work; they are pretty easy to recognize by the long nose.
    Irish Mike and LarsL like this.
  8. LarsL
    LarsL
    from Norway
    I think you are almost right. 1936 wont work as those drums Are 1-3/4.
    1937-48 Are 2 inch. So lockheed will work with 37 and up. Not 36. Right?
    Irish Mike likes this.
  9. Ziggster
    Ziggster
  10. Wide 5s are stock 36-39 Ford which is very common in all forms of oval track racing but not sprint cars
    Stock Ford wide 5 still used in oval track today.
    upload_2026-3-8_22-49-57.png upload_2026-3-8_22-50-49.png upload_2026-3-8_22-53-18.png upload_2026-3-8_22-56-9.png
    Sprint cars run a splined wheel that slides over the live axle and uses a single wheel nut. upload_2026-3-8_22-48-24.png
  11. RICH B
    RICH B
    '35-'48 Ford brakes all have 1-3/4" shoes.
    '36 front drums have a much deeper offset than the later drums that is why they don't work.
    The '36 rears work as all* Ford banjo rear axles have the same offset.
    *A rears are slightly different as noted when using juice brakes.
    Some of the later Lockheed drums may clear 2" shoes on repop Lincoln brakes; but I wouldn't use that criteria to describe them as 2" drums.
    Picture to illustrate how close a 1-3/4" shoe is to the edge of the braking surface in a '40 drum.
    alchemy, winduptoy, Toms Dogs and 2 others like this.
  12. 31Apickup
    31Apickup
    37-48 are 12” drums. Model A’s are smaller if I remember right they’re 10”.
    LarsL likes this.
  13. RICH B
    RICH B
    Model A have 11" brakes.
    '32-'48 have 12" brakes
    '32-'34 have 1-1/2" shoes.
    '35-'48 have 1-3/4" shoes.
  14. LarsL
    LarsL
    from Norway
    Great info!! Thanks!
  15. LarsL
    LarsL
    from Norway
    So, is this 37 and up?
  16. The image isn't sharp but it looks like that the front end has a round back spindle and then it's a 1937-38 (mechanical brakes).
  17. Mart
    Mart
    Simple answer to your original question is yes, 37-39 hubs/drums will work on 39-48 backing plates and shoes. That's what I did on my 32.
    Mart.
    ronzmtrwrx, Irish Mike and winduptoy like this.
  18. LarsL
    LarsL
    from Norway
    Thanks for all the help and great info.
  19. Roothawg
    Roothawg
    Rich B is the man. He knows....
  20. nobby
    nobby
    the pic is 1937 1938 cable brakes
