Wide 5 Wheels
Discussion in 'The Hokey Ass Message Board' started by mark 52, Sep 5, 2012.
  1. mark 52
    mark 52
    from Ottawa
    Does anyone know how to get tires mounted on wide 5 rims. The tire shops around here say they can't do it because the rims won't mount on the machine they have, no help.
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Do you have a spare front brake drum? Knock out the internals and use that. I use an old circle track adapter.
  3. Hnstray
    Hnstray
    from Quincy, IL
    Your local shops must have some really old center mount equipment. Later tire machines use rim grips and the center of the wheel matters not............until you get to the wheel balancer, that is :)
    Ray
  4. johnny bondo
    johnny bondo
    from illinois
    i use tire irons, soapy water on a rag to wipe the rim and tire edge, and baby powder on the innertube. old school baby, do it.
  5. cvstl
    cvstl
    from StL MO
  6. I bought one adapter from Speedway and take it to the tire guy when I have them mounted.
  7. mark 52
    mark 52
    from Ottawa
    Thanks guys for the help. I found the speedway adapter but was unsure of how well it worked.
  8. 1pickup
    1pickup
    I did it by hand. Umm.. I'm talking about mounting tires on wide fives here
  9. Saxon
    Saxon
    from MN
    Ah yep, have one and have balance a dozan wheels with this adaptor. only problem with these is the bolt size and nut tapper, does the job though.
    Dont think ****s is a problem with that.
  10. i did mein with a hand machine
    extended the center pipe by slipping another over or inside
    and sometimes used 5 in long bolts to space the adapter
    think and adapt people we did this long ago and made it work:eek:
    and now theres a lot beter equipment out there now:)
  11. Saxon
    Saxon
    from MN
    All due respect, and i mean that. I dont have abalance machine in my garage, so i have to take it to a shop. The shop i take it to has a wide varity of people that can get things done. But without the adaptor (like old vw rims) they are stuck on balance.
  12. mark 52
    mark 52
    from Ottawa
    I ordered the speedway adaoter this morning.
