Technical Wide five Ford rims
Discussion in 'The Hokey Ass Message Board' started by roder1935, Feb 22, 2020.
  1. roder1935
    roder1935
    Just got new tires mounted on some wide five rims for a 37 pickup but hey said they didn't have a machine that could balance them I live near Spokane Washington any help
  2. tubman
    tubman
    I'm not a fan, but you could try "balancing beads". A lot of guys swear by 'em.
  3. 51504bat
    51504bat
    You might try and find a shop that still has a strobe balancer (truck shop?) if they still even exist. Or get an old front brake drum and bolt it to the wheel so it can be mounted on the machine.
  4. Budget36
    Budget36
    I'm a fan of the beads, used them for years in my Dad's Peterbuilt's. We changed tires ourselves and tossed a pack in.
    Pack we had were for 10.00-22.5's, I guessing for a automobile tire they would have a different/smaller pack?
    stillrunners likes this.
  5. roder1935
    roder1935
    Not sure how the beads work or where to get them. Any more information would be helpful. Thank you
  6. Call around tire shops and local car clubs to find someone that can balance the tires on the car. Be sure to put the rims back on the same each time.
    Charlie Stephens
    alanp561 likes this.
  7. Inked Monkey
    Inked Monkey
    I've used Counter Act balancing beads for years. They work great and are cheaper than Dyna Beads. You can get them on ebay or from this website https://www.counteractbalancing.com/
    Just follow the chart on how much to add.
  8. jaw22w
    jaw22w
    from Indiana
    Speedway Wide 5 Wheel Adapter, 5 on 4-3/4 Inch
    Universal Fit, Wide 5" Bolt Pattern, 5/8"-18 Thread Pitch, Steel, Powder Coated
    5 Reviews | 5 Answered Questions
    In Stock
    Can Ship FREE
    here for details and exclusions.">
    Select your vehicle to verify fitment.
    Select Vehicle
    Part # 91658251
    $54.99
    each
    Quan***y:
    Add to Buildlist
    Click to Login
    Compare
    I run W5 wheels on my hot rod and had the same problem. I solved it with one of these. Just swap it to each wheel for balancing.
    Well ****. The pic didn't post. There's enough info there to find it if you're interested.
    stillrunners and town sedan like this.
  9. town sedan
    town sedan
    Any shops in your area that work on early Volkswagens?
    -Dave
  10. roder1935
    roder1935
    Thanks for the help I will look into all of the suggestion if I understand how the beads work the tires are tube type so not sure if they will work but I will check into it a little more thanks
  11. gowagn
    gowagn
    from benton,la
    I used a Wide Five adapter also , just put on each wheel worked fine
  12. Inked Monkey
    Inked Monkey
    I've ran the beads with tubes and w/o tubes
