Technical Wide Five Wheel Modification
Discussion in 'Traditional Hot Rods' started by bondolero, Apr 16, 2015.
  1. bondolero
    bondolero
    Any individual/shop on the left side that will make a set of 15" X 5's rims using original wide five centers ??
  2. 33rag
    33rag
    from Pa.
    I made a few,lots of work.IT's tough trying to find a 15" wheel with a big enough center.I had to machine centers down to fit.
  3. tubman
    tubman
    Did you try Speedway's racing catalog? IIRC, they have 15" wide five centers. Probably not much help if you want to run stock hubcaps.
  4. doliak
    doliak
    Spare tires are a good place to find em and they are usually in perfect shape
  5. 55willys
    55willys
    I know that Marty Strode has done them in the past. He is on here and in Oregon
  6. Marty Strode
    Marty Strode
    I have done some for my own use, they are a fair amount of work. It's also difficult to find the 15" hoops with the large inside dimension, (13.25" as I remember). The hoops that Speedway sells have a 12.625" center hole, and using them, you loose the appealing character of the centers. Good luck in your search. IMG_0923.JPG IMG_0926.JPG IMG_0927.JPG
    Avgas and Texas Webb like this.
  7. hotcoupe
    hotcoupe
    Marsh Racing Tire, i think they are in Arkansas, put wider hoops on my original wide five centers. the centers were not modified in any way, the finished wheels had .015" T.I.R. or less! price was very reasonable too. hope this helps.
    tom
  8. flatheadfever
    flatheadfever
    What widths can they do?
  9. hotcoupe
    hotcoupe
    hello, give them a call,
    Marsh Racing Wheels
    OPEN NOW
    Today:5:00 am - 5:00 pm
    16951 Logan Cave Rd,
    Siloam Springs, AR 72761
    (479) 524-4157
    tom
  10. JOECOOL
    JOECOOL
    I made a set with 16 inch 2000-2001 Chevy pickup rims.These were spares and were steel not alloy.If I remember right the centers fit in the hoops perfectly. I'll try to post pics.
  11. Work4it
    Work4it
    Hey JOECOOL, what was your method for removing the center of the Chevy wheel? Did you do like most of us would and dig it out with heat and grinders? Or did you have a lathe big enough?
    I really want to make a set of these and want to put a new outer on instead of adding a band.
    Thanks
  12. Hnstray
    Hnstray
    from Quincy, IL
    The OP is asking for 15" wheels........'wider rims' apparently is not his sole criteria....putting wider rims on 16" centers is not so difficult.
    Ray
