Hot Rods Wide Fives
Discussion in 'The Hokey Ass Message Board' started by jscott1, Mar 3, 2018.
  1. jscott1
    jscott1
    Using a 38 Front axle with wide 5 drums. Have a 56 F100 front axle with brakes. If I use the 56 brakes will the 38/39 drums fit? Want to stay wide 5 if I can.
  2. no....`56 f100 brakes are 11" diameter and wide 5 is 12"
  3. jscott1
    jscott1
    Thanks, learn something new each day.
  4. jscott1
    jscott1
    I guess I will have to use the 56 drums and a set of adapters from Speed way.
  5. xlr8
    xlr8
    from Idaho
    1939 had the combination of wide fives with hydraulic brakes so 39 brakes would be a bolt on. Also the 40 style brakes could be adapted easily if I'm not mistaken.
    jscott1 likes this.
  6. bct
    bct
    You can buy converted self energizing brake backers that will work with your wide five drums. Isnt it neilinca ? I dont normally suggest "buy it" options but for front brakes cost is a secondary issue.
    jscott1 likes this.
