Hot Rods WIDE Rear, SKINNY Front
Discussion in 'The Hokey Ass Message Board' started by Adrenaline, Jun 6, 2023.
  1. Adrenaline
    Adrenaline
    Ive looked through quite a few threads and found a lot of cool combinations but a lot of them were old and didnt include much if any info so im looking for some pics and specs of hot rods with 12-15in wide rear wheels and 4-5in wide front wheels. I need some inspiration for my 32 since it needs new wheels and im not a huge fan of the current look. Thanks
  2. 427 sleeper
    427 sleeper
    Check out @-Brent-. With his Model A build... You'll love it! :cool:
    mad mikey, -Brent- and chryslerfan55 like this.
  3. -Brent-
    -Brent-
    Thanks!
    Mine has 4" front Ford steelies and 9" rear Halibrand wheels (with 15x10" tires).
    Tman, mad mikey and 427 sleeper like this.
  4. Adrenaline
    Adrenaline
    Have any pics? May be a little smaller than im looking at but sounds cool. lol
  5. It has to be tires that were available back in 65, can't do anything pro street looking size here, I've been scolded for it myself :D
  6. Adrenaline
    Adrenaline
    Might have to just delete the post and do my own thing. lol
    swade41 and chryslerfan55 like this.
  7. mad mikey
    mad mikey
    I run 15 x10 old American 's on rear and 15 x4 front, not vintage just what I could afford to have the look.
  8. Adrenaline
    Adrenaline
    The one in your profile pic? I actually ran across it in another thread. It looks great!
  9. -Brent-
    -Brent-
    What are the rear tires you have now, 15x8? Going with a wider slick, like a Radir, will get you a taller tire, too. That may help.
    Here's mine:
  10. chop&drop
    chop&drop
    IMG_4049.jpeg These are 15X4.5 and 15X10 from American Rebel Wheels (now owned by Wheel Smith). I believe they make them up to 14” wide.
  11. Thought this was a post about a chic
  12. Ohh brother
  13. No, my wife
    deadbeat, scotty t and chryslerfan55 like this.
  14. 210superair
    210superair
    from Michigan
    When I was a kid I had a slot car that looked just like that but yellow. Loved that thing....
    chryslerfan55 and 427 sleeper like this.
  15. Lord no lol, just saying if you're talking BIG tires!
  16. swade41
    swade41
    from Buffalo,NY
    If you live near me I have an ***ortment of vintage mags, if bolt pattern worked you could come over and try different combos to get a feel for what you like.
    This particular set are 3.5's and 11's
  17. wheeldog57
    wheeldog57
  18. fastcar1953
    fastcar1953
    10 on back and 4.5 on front 155485652_4086313014726287_2212874296002967922_n.jpg
  19. DDDenny
    Do these tires make my **** look big........I sure hope so!
  20. kabinenroller
    kabinenroller
    When you change the tires adding front brakes would be a good idea.
    twenty8 likes this.
  21. deucemac
    deucemac
    Blown Red Ram, shortypu and Budget36 like this.
  22. lostn51
    lostn51
    from Tennessee
    That is one fine coupe!!!!
  23. deucemac
    deucemac
    Here's my big/little. 14x31x15 Firestone double diamonds on the rear and 165-80-15 Texans on front
  24. deucemac
    deucemac
    stupid autocorrect changed Nexen to texan
  25. lostn51
    lostn51
    from Tennessee
    I love autocorrect :mad::confused::mad:
  26. mad mikey
    mad mikey
    Yes.
  27. '29 Gizmo
    '29 Gizmo
    from UK
    The thing to remember is that the sidewall height is critical. if you have skinny rubber on the front and fat at the rear, and the sidewall height of the rears is much taller than the front you get an optical illusion which makes the front wheels look bigger than the rears. look at some of the pics of this combo and you will see what I mean. it can work, or not depending on the rest of the stance of the car.
    You can compensate for this by running smaller diameter front wheels, but this optical effect can make or break the look of a car from the side.
    mad mikey, ekimneirbo and X38 like this.
  28. krylon32
    krylon32
    from Nebraska
    Recently finished another chopped deuce highboy sedan. On the front I'm running polished American Rebel sprints 15X4.5 with 145X15 Michelin XZX radials and on the rear polished American Rebel Sprints 15X10 with 285/70 X15 BFG radials. I got the tires from Speedway because they were close and they offered free freight. Bought the wheels direct. I've ran this combination on several deuces and still go back to it. Last time I looked pewsplace.com had pictures of the sedan.
  29. 1971BB427
    1971BB427
    from Oregon
    Big and littles are pretty common on old hotrods. But how little you use in front really depends on the weight over the front axle. I run 15" all around, and have pie crust slicks on the rear of both of my cars. But my '39 Chev coupe is a heavy car, so I am running 5" Torq Thrust on the front. My little Austin g***er is over 1000 lbs. lighter, and it has 3.5" Ansen slots up front. Both drive great, and look proportional to the size of the two cars.
    mad mikey and -Brent- like this.
  30. ekimneirbo
    ekimneirbo
    Looking at your pictures, its hard to tell if its the camera angle or not. The rearend seems to be a little too wide or the bed a little too narrow and creates what appears to be a big space there. Also, (camera angle?) the rear may be slightly too far aft as well. Need some more pictures to actually determine what would help the most. If you can make it to the Street Rod Nationals in Louisville KY the first of August, you can see a lot of wheel vendors there and compare their wares. Last year Summit had a booth where they offered 10% off of almost anything they sell. They also had catalogs with a "number" on them offering a discount for after show buys. You can save quite a bit on large purchases and free shipping. I bought 6 wheels and 4 rear tires so I can work things out when building. If you can make that show there will be thousands of cars to compare and photograph, so you can see what you like first hand. I like to take pics and save them for later reference.
    You might look into some of the Pie Crust tires as they usually look good, but if you want wiiddeee street tires, you can see what looks best to you and compare bed widths as well as rearend widths. Bring a tape measure with you....... 32 Ford Color 2x.JPG
    You can see that even with a wide tire, the space between the back of the tire and the body affects how the set up looks. So my reccomendation is to think about all the components if you decide to change.
    shortypu and swade41 like this.
