Hot Rods Wide tire Balancing problem
Discussion in 'The Hokey Ass Message Board' started by jeffbwa83, Dec 26, 2017.
  1. jeffbwa83
    jeffbwa83
    from Washington
    I have a pair of Hoosier radials on the back of my model a that I cant get balanced by anyone in my area.(I live in whatcom county, WA.) The wheels are a 15 inch diameter and 17 inches wide. The tires are 33 x 21.5R15. I tried a bubble balancer but with no luck and they are too wide for any of the local shops balancing machines. Does anyone know of any shops maybe farther south that might be able to, possibly in the seattle or everett area? I'v heard of the balancing beads but was not sure if they would work with a tire that wide. Thanks for any information you might have.
  2. Mr48chev
    Well, does anyone in your area have an on the car strobe balancer? I bought an old one from a front end shop that was going out of business a while back but haven't had time to try it out yet.
    The strobe balancers have a sensor that hooks to the frame or axle or control arm with a magnet most of the time and there is a readout on the unit that gives the amount of weight it needs and the strobe shows the light spot of the tire being at the top. On the back it can be a challenge to deal with if the rig has a posi style rear axle though.
    I'd be a bit Leary of trying to balance the wide tires with a Hunter on the car balancer as the wheels probably won't match up with the adapters. I've never had one come off myself but have seen the results of the balancer head taking off across the shop.
  3. 1946caddy
    1946caddy
    from washington
    Static balance
  4. Terrible80
    Terrible80
    lothiandon1940 likes this.
  5. slowmotion
    slowmotion
    Beads. One of the shops I deliver to uses 'em in 'big truck' tires all day long, no issues.
    gimpyshotrods and Budget36 like this.
  6. vtwhead
    vtwhead
    gimpyshotrods likes this.
  7. Ralphies54
    Ralphies54
    I got balance beads in all 4 tires of my Pickup, work fine,cured a vibration.
  8. tred
    tred
    yeah, throw those bags in there and you'll be fine
  9. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Like them beads. PIA to insert the beads but just a minor hurdle if you get a funnel & a clear plastic tube or their insert setup.
  10. B.A.KING
    B.A.KING
    Out of balance or out of round???
  11. BamaMav
    BamaMav
    from Berry, AL
    Put some golf balls in the tires. Old tire guy I knew swore they were better than the small bb's.
  12. tred
    tred
    huh? they come in bags that disintegrate, you just throw the whole bag in there like i said, it couldn't be easier.
  13. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    tred I'd pay admission to see you put a bag in one of my tube stems. ha ha ha Yes if you use tubeless but mine have tubes in em.
  14. tred
    tred
    ha aha ha!
    PIA is an understatement!!!
  15. jeffbwa83
    jeffbwa83
    from Washington
    I'll check out the beads. I just need to find out how much to put in.
  16. Rand Man
    Rand Man
    I had my dragster slicks balanced at a place that does big truck tires. No problem.
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Those aren't that big or wide. Any 4x4 type place or place that works on full size vehicles should be able to do them. most stock 4x4 trucks run a tire almost that size now days. My little lifted mini truck ran those same tires and had no issues balancing them.
  18. tred
    tred
    we used to start with a 30 gram bag (which is about one ounce), that was perfect for most of the applications, if not spot on, it's a great starting point. start there.
  19. gimpyshotrods
    gimpyshotrods
    I ran nothing but Dynabeads in a set of 36 x 12.50 Super Swamper TSL bias plies.
    75+ on the freeway, on a softly sprung off-road rig. Zero shake.
    Ralphies54 likes this.
  20. tred
    tred
    aw jeez...
