widening a 26/27 body
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by chris76, Jan 24, 2021.
  1. chris76
    chris76
    I just go a 27 model T body I'm try to decide if i should wider it by about 50 mm or 2 inches to gain some extra foot room.
    Anyone done this any photos?
  2. X38
    X38
    How big are your feet? How many pedals?
  3. chris76
    chris76
    Before i start working on the body I'm trying to work out if i should make it a little larger. Im 5'11 size 9 shoes .
    I have been told there very small. Do most people modify them or leave them as original?
  4. X38
    X38
    Leave them original.
    mgtstumpy likes this.
  5. mgtstumpy
    mgtstumpy
    23T
    27T
    It may look awkward if widened
  6. X38
    X38
    I've seen it. Not good. Especially if you know what a 26/7 T looks like.
  7. chris76
    chris76
    thanks I have seen that image before i didn't know if the width of 49" was correct everywhere else i could find said the width was 46" or 1168mm at the back of the doors.
    I found this on line somewhere
    REFERENCE DATA FOR 1927 FORD MODEL T ROADSTER BODIEs
    SPECIFIC MEASUREMENT REF_REC Tolerance
    To SCTA
    Rules Committee
    Tolerance:
    Double Digit Measurements: +/- 1"
    Single digit measurements: +/- 1/2".
    TOTAL LENGTH 2349.5mm
    F/W WIDTH 793mm
    F/W TO BACK OF DASH 419mm
    F/W TO BACK OF SEAT 1393mm
    F/W TO RA CL 1930mm
    F/W WIDTH AT BODY SEAM 800mm
    F/W PROTRUSION AT SEAM - UPPER 60mm
    F/W PROTRUSION AT SEAM - LOWER 34mm
    WIDEST POINT OF BODY 1231mm
    LOCATION OF WIDEST RDS+203mm
    OVERALL HEIGHT 615mm
    LOCATION OF HIGHEST POINT SEAT BACK & DASH
    REAR BODY WIDTH 1069mm
    REAR BODY TO RA CL 431mm
    REAR FENDER WELL TO WELL AT CL 1105mm
    REAR BODY IN LEAN AT TRUNK SEAM 19mm
    WIDTH OF COWL TOP 965mm
    WIDTH OF COWL BOTTOM 901mm
    WIDTH OF BODY AT FDS TOP 965mm
    WIDTH OF BODY AT FDS BOTTOM 908mm
    WIDTH OF BODY AT RDS TOP 1168mm
    WIDTH OF BODY AT RDS BOTTOM 1054mm
    FDS TO WINDSHIELD INTERSECT - TOP 31mm
    FDS TO WINDSHIELD INTERSECT - BOTTOM 57mm
    COWL TO FDS FOR REFERENCE MEASURE 38mm
    ABBREVIATIONS
    FDS = FRONT DOOR SEAM
    RDS = REAR DOOR SEAM
    DNM = DID NOT MEASURE
    CL = CENTER LINE
    RA = REAR AXLE
    NA = NOT APPLICABLE TO THIS CL***
    INSIG = INSIGNIFICANT VARIANCE IN MEASUREMENT
  8. adam401
    adam401
    Hot rodding is certainly about cutting up cars but I gotta say ive never seen a 30s car widened that didnt look like ****. Maybe you'll do the first good one.
    I have size 12 feet and have driven at least 2 friends 27 roadsters both with manual transmissions. No problem.
