Wife says I created a monster. Willys Jeep build
Discussion in 'The Antiquated' started by anthony myrick, Apr 22, 2021.
  1. We had this jeep tail gate filler/eliminator that came with the first jeep he bought. It’s 16 gauge. We chopped it up into a center floor riser/crossmember.
    Okie Pete likes this.
  2. ****py ole HF bead roller did ok
    35C09EAE-17FB-426A-9A97-B0B9B44F9612.jpeg 173944DE-5253-4191-9F07-871538A0055E.jpeg 9E7A6FF0-20EA-46F8-A0ED-2C810C15D1FE.jpeg 9FD67FC9-ACCA-4446-A027-B51FA0359226.jpeg
  3. Harv
    Harv
    from Sydney
    Very neat beads. I bought an al-cheapo bead roller to make some ally door trims. Hope they turn out as well.
    Cheers,
    Harv
    anthony myrick and OahuEli like this.
  4. That is some pretty stellar work, should keep the young guy interested.
    anthony myrick likes this.
  5. If you brace up these cheap rollers that do a good job.
    We also made a fence out 1 inch angle to get these straight
    Okie Pete and caseywheels like this.
  6. OahuEli
    OahuEli
    from Hawaii
  7. If you can fold and unfold a box, you can do sheet metal work.
    The hat channel is tricky.
    Cut some 1 inch wide s**** strips the width we needed. Took a couple tries to figure out the sequence. It’s easier if we had a press brake. We used a regular finger brake. Most straight brakes are too wide on the clamp side to do a narrow channel.
    These are 9/16 tall. The minimum for the brake we used after removing the angle brace from the brake.
    This weakens or reduces the brakes capacity.
    I plan on modifying the brake so we can lower the angle brace to accommodate the room needed for a reverse bend.
    For this bend, the outside fold was first, flip and do the inside.
    Rotate and flip, do the second outside bend. Flip and do the last center bend.
    Instant hat channel.
    R A Wrench, Okie Pete and OahuEli like this.
  8. Any updates on this?
  9. He’s in school now.
    We’ll get back on it summer brake.
    cactus1 likes this.
  10. Ah! School…it’s been a long time since I had to do that…
    I’ve been working on this for mine and remembered you guys were working on one so thought I’d check in!
    Nice work!
  11. We’ve got the crank turned.
    Need to get the block done and we’ll be putting it together
    that looks great. I’ll show it to him for inspiration
    OahuEli, Okie Pete, Sancho and 2 others like this.
  12. Kids back at it with school out
  13. Okie Pete
    Okie Pete
    One piece at a time . Very cool . Thank You for showing the progress being made .
    cactus1 and anthony myrick like this.
  14. rusty valley
    rusty valley
    That kid will be somebody someday with such a good teacher ! Keep it up !
  15. Hope so. He’s a great kid.
    Full time college. Works full time in the summer for a commercial roofing company. They have some nice sheet metal equipment. Hess getting good with a break.
    This stuff will be a hobby.
  16. Tailgate mounted.
    we’ll make a new bottom piece for it. This ain’t no resto. It’s a make a solid and functional woods buggy.
    He’ll figure out why I prefer radiuses instead of 90• angles. He is file fitting the patches.
  17. He made these 2 pieces.
    I’ll show him how to finish it out a little better
  18. Not bad for a first timer
  19. Really good!
  20. Okie Pete
    Okie Pete
    Great work. Great Teacher
  21. I’ve not made much progress on mine. How’s yours coming along?
    anthony myrick and Okie Pete like this.
  22. Nice work. Kid gets his looks from his mother? Good of you to give up that real estate in your shop. I tell mine- someday all of this could be yours…
  23. Not much.
    He still in school and works when not at school.
    Okie Pete and cactus1 like this.
  24. 1952henry
    1952henry
    Put you and your son in a box and mail it to me! I have Jeep you can fix for me! Nice work!
