Art & Inspiration WILD PIPES...cool and crazy headers picture thread
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Mar 25, 2015.
  1. wsdad
    wsdad
    Me too! BTT
    els likes this.
  2. daddylama
    daddylama
    didn't see these here... from another thread on the HAMB
    Stogy, els, kiwijeff and 1 other person like this.
  3. I think it depends on the way the motor is built and the way that the collector pipes are built.
    For zoomies the power band is very narrow generally. Ideally they make you lay down a little on the bottom and gain some on the top. There is actually a whole new angle on them as well. The top fuel guys build them so that they not only deliver in the HP/Torque dept. but they also enhance traction.
    A properly built collector exhaust one built to perform more then to look good will deliver a wider power band in the desired RPM range. For example I am building a Tri Y header for my small block, it needs to stand up and deliver from 3K to 7K ( give or take 500) I am using 1 3/4 primaries into 2" secondaries. 16"x22" is the desired tube lengths. You can move your torque band in either direction by lengthening or shortening the primaries.
    There is no real reversion factor with zoomies. You still get exhaust pulses back from the end of the tube and where they are tuned to run the pulse will return in time to help scavenge the cylinder. There are formulas for that and are dependent on displacement and desired RPM. That is overly simplified, but you catch the drift of it, right?
  4. Larry T
    Larry T
    Collector length and extensions make a difference too.
    Stogy, els and loudbang like this.
  5. Yep as well as diameter. ;)
    I am no exhaust guru, I know the basics and enough more to get myself into trouble. :D
    Stogy and els like this.
  6. Speed Gems
    Speed Gems
    Square tube headers on a O/T modified dirt track car.
  7. Max Gearhead
    Max Gearhead
    from Wisconsin
  8. loudbang
    RAMCHARGER with no clothes LOL
  9. DDDenny
    I been to the big city and a few goat rop'n contests, nev'r seen noth'n like them before.
    els likes this.
  10. loudbang
    In the what engine in your hot rod thread today.
    No idea about what that 5th pipe is, it's not mine.
    Stogy, cruiserjohn76, loner2 and 5 others like this.
  11. Devin
    Devin
    from Napa, CA
    Just literally saw this on Jalopnik. Sorry if it is off topic but the pipes are wild. Its a Mercedes M119 twin turbo v8 from the late 80s which powered the Sauber C11 Le Mans prototype cars. ImageUploadedByH.A.M.B.1455787004.645931.jpg
    els likes this.
  12. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    GUESS I AM KEEPING THE TIMES ALIVE ON HEADERS THEN.
    els, mad mikey and Jet96 like this.
  13. Jet96
    Jet96
    from WY
    Just saw this on another thread, belly/weiner/shin burners image.png
    Stogy, els, kiwijeff and 3 others like this.
  14. I wonder if they are hinged so that the door will still work. :D
    @Devin maybe OT but it is fun to look at, there is a lot going on there aside from just the pipes. That baby is wilder than a marsh hair.
    I'll bet the 5th pipe comes from the heat riser for the intake. Instead of blocking it they just ran a tube from it. Just a guess on my part.
    els, wingnutz and loudbang like this.
  15. nitrobrother
    nitrobrother
  16. nitrobrother
    nitrobrother
  17. nitrobrother
    nitrobrother
  18. alfin32
    alfin32
    from Essex, Ma.
    Built by Ronnie Gagnon at New England Rod Shop.
    Stogy, els, loudbang and 1 other person like this.
  19. els likes this.
  20. BigDrag
    BigDrag
    from Milwaukee
    For me the Silver Bullet hits the mark dead center, with elegant design the pipes...and whole car become sculpture.
    Stogy, 1947knuck, els and 6 others like this.
  21. I live down the street from Stan and I feel bad that I didn't submit his car on this thread. Glad you did!
    els likes this.
  22. The silver bullet is very cool !
    The pipes though, remind me of speedway roadsters
    els likes this.
  23. loudbang
    Must sound hellish when you are sitting inside the ****pit.
    Stogy, cruiserjohn76, loner2 and 2 others like this.
  24. treb11
    treb11
  25. treb11
    treb11
  26. patmanta
    patmanta
    from Woburn, MA
    I must say, Whatever do you mean?
    Stogy, els, Jet96 and 1 other person like this.
  27. nitrobrother
    nitrobrother
  28. nitrobrother
    nitrobrother
    Overdue for a bump...
    It's amazing what you stumble across while looking for something else. From Australia...
    Stogy, els, mgtstumpy and 2 others like this.
