Okay today worked on the b pillars. Wow lots of work. Slanting, getting the door to fit Here goes. Took out 2 7/8's out of the pillars Posted using the Full Custom H.A.M.B. App!
Not a whole lot done today still took 4 hrs. Clean up the b pillar and welded in the rear window corner. So, so much still to do. Haven't even started on the inside yet. Posted using the Full Custom H.A.M.B. App!
So today plan is to finish up the back window, rear 1/4 and b pillar on drivers side. Posted using the Full Custom H.A.M.B. App!
Couple more from today Flows pretty good. Need to hammer and shrink some more. Posted using the Full Custom H.A.M.B. App!
Thanks cap Got I bit more done. Second 1/4 window went much quicker Tackling driver b pillar and finish up rear window tomorrow. Got a real cul gadget from harbor freight. It's a cushioned attachment for my angle grinder. I've only seen them for air units. Since I don't have a compressor this is pretty cul Posted using the Full Custom H.A.M.B. App!
Got the b pillar in then the welder started acting up. Maybe doesn't like 90 degree weather!? More to come Posted using the Full Custom H.A.M.B. App!
Got all the rear tac down. Put it on the road for some pics Before After Now to finish the doors, trim ect... Posted using the Full Custom H.A.M.B. App!
In Denver for ten days. So will get back at it when I get back. Lots to do. Anyone have good results an ideas for shrinking welds? Posted using the Full Custom H.A.M.B. App!
Thanks 6racer. Yeah it's got a long way to go...as you know. Hope to see you in a couple of days. It will be great to get our shoeboxes on the road this summer. Not much in bend along the cars were building. Posted using the Full Custom H.A.M.B. App!
Just got the 50 fired up. After diyin since September thought I'd do some carb adjustments. Guess I can't post videos so you'll have to trust me. On the agenda is to start te finish work on the chop. Posted using the Full Custom H.A.M.B. App!
Hey cap My father has been hospitalized for the last month. Things has slowed down on the 50. Hopefully I can get some stuff accomplished soon. Posted using the Full Custom H.A.M.B. App!
Mine has a '74 Comet rear with new Yukon 3:55 gears and after market sway bar. Running a 302 roller motor with a 5 speed. I have Bronco rims, allows me to run caps and still fit under the fender skirts.
Attacking the body panels and finishing up chop seams. It looks good in its new home. Sent from my iPhone using The H.A.M.B. mobile app
Alright, yeap it's been awhile however I'm back at it...sorry for the delay, finished a build(62f100uni) and got it sold now putting a lot of energy into the shoebox before summer slips away...also I've noticed alot of builds that started years ago have gone the way of the dodo bird. Some of us have been on the H.A.M.B. For years. If we can all sustain our builds and this sight can continue to have the flavor of good workmanship and hardline, old school vision maybe we can revive some of the lost/ dead builds I.e. "Flop,", Rusty's 47, even farmers 41 Plymouth from Sweden. Well there's my soapbox. Started to complete and finish welding the seems and hammer an shrink butt welds around window and left C pillar. Lots of worn thin metal reviled when welding seems. Had to fill and chase some nasty areas around the gutter I was able to save the left gutter however when I get to the right side it's pretty pitted and well...we'll see Next I trimmed the cap that sits on the top of the rear quarter. Lots of canaer in that seam and had to work around the lead that ford uses to fill, whatever? Still don't know why ford did that Eventually got it welded and built up enough to round and smooth it out More to come, now need to finish welding from the inside. Sent from my iPhone using The H.A.M.B. mobile app
