Will 9.00 9.50 slicks fit on an Impala
Discussion in 'The Hokey Ass Message Board' started by Donaz, Sep 30, 2012.
  1. Donaz
    Donaz
    from Phoenix
    I have a chance to pick up some 9.00/9.50 X 15 Cheater slicks and would like to know if they will fit inside the wheelwells of my 61 bubbletop. I have a set of 15x7 steel wheels I plan on using.
  2. bobwop
    bobwop
    from Arley, AL
    depends on the backspacing of your wheels and the section width of the tires
    I have a hunch they will fit
  3. squirrel
    I had some 9.00 x 28.5 x 15 slicks on the back of my 61 bubbletop, on 6" wide wheels (which are rather narrow for those tires). They fit. You need to be careful with wheel selection, also they were pretty tight to the front of the wheel opening.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    I had a 64 Impala that I ran 11 inch M and H dragster slicks on, and they cleared. I had them on regular steel wheels. I suspect the 61 and 64 are similar in that area roomwise.
    Don
  5. squirrel
    I wouldn't count on the wheel opening being the same size, they're shaped quite different.
  6. oldolds
    oldolds
    The rocker panel area is the first part that us usually cut on those cars.
  7. squirrel
    examples
  8. zeph4057k
    zeph4057k
    you need a 3 inch offset on the front side and 4' on the back side with a 7' rim, it will work perfectly and look great! that will give you the nastalgic look you want. these are standard G.M. rims
  9. Wow, that 61 with the crossed flags is damn nice
  10. Donaz
    Donaz
    from Phoenix
    not sure about the backspacing or offset, but they are stock GM wheels. I think I'll give them a try. Thanks guys
  11. squirrel
    If they're stock wheels they'll probably work.
