1952-59 Ford Will a T5 work in a 52 customline
Discussion in 'Off Topic Hot Rods & Customs' started by Kustom_Galaxie, Sep 11, 2012.
  1. Kustom_Galaxie
    Kustom_Galaxie
    from Arizona
    I am putting a 302 in the car and want a manual trans. Will the mustang T5 shifter location work with a bench seat?
  2. the-stig
    the-stig
    You might want to check into a T5 from an S10, I think the shifter is farther forward.
    I'm using the 302/5 speed from an 85 Mustang in my 56 and the shifter is about 18½ inches from where the trans hump angles up into the firewall. I have buckets in mine so I don't know if the shifter would interfere with the bench seat.
  3. Kustom_Galaxie
    Kustom_Galaxie
    from Arizona
  4. Custom_Crestline
    Custom_Crestline
    You can use the tailshaft from an s10, they all interchange.
    I've got a mustang t-5 behind a Y, and I moved my seat back about an inch.
    Its a tight squeeze in there
  5. FlatHat
    FlatHat
    I put a T5 in my '53 Victoria.
    Using an S10 rear case, the shifter will be quite a ways forward, so you'll have to use a long stick. The longer the stick, the longer the throw between gears.
    If you use a Mustang or Camaro rear case, the shifter will be practically under your seat.
    BUT --- if you can find an Astro Van rear case, the shifter will be about halfway between those two, perfect for our cars. A standard S10 shifter will bolt right up to the Astro Van rear case.
  6. Ole don
    Ole don
    The single best addition to my 55 was the five speed. Never give up!
  7. Custom_Crestline
    Custom_Crestline
    Same, the good y-block and the t-5 were the best things I did to my car.
  8. Kustom_Galaxie
    Kustom_Galaxie
    from Arizona
    Thanks for all the info
