Hot Rods Will I fit?
Discussion in 'The Hokey Ass Message Board' started by midnightrider78, Sep 10, 2017.
  1. midnightrider78
    midnightrider78
    001-lomas-1934-ford-coupes-white-and-black-lpr.jpg OK So I have wanted a '33 or '34 Ford 5 window for as long as I remember and I am finally in the position where I can probably afford to buy a project like this.
    The potential trouble is this. If I drop the kind of coin it takes to buy one of these, I insist on chopping it at least 4". However, I am 6'4", 240 lbs. So the first question is simply, will I fit? 2nd is If I fit, am I going to be stopping to get out and stretch every 30 miles?
    I fear I already know the answer, but I thought I would ask somebody who has been there and done that.
    Haden59 and ls1yj like this.
  2. 3banjos
    3banjos
    from NZ
    Build a seat to suit and you'll have oodles of room. Just don't stand up too quick hopping out. The roof sticks out a fair bit more than floor.
  3. Tim
    Tim
    from KCMO
    Honestly the getting out and stretching often has more to do with suspension on the car or a poorly designed seat than space. A 33/34 is a pretty big car comparatively, If you takenyour time and explore all the ergonomics I don't see any reason you couldn't fit and be comfortable.
    lothiandon1940, ls1yj and Hombre like this.
  4. midnightrider78
    midnightrider78
    I guess I should also mention that I am a bit awkward/clumsy getting in and out of small spaces. For example, it was virtually impossible for me to get into a friend's stock Model A roadster with the top up. Didn't matter anyway though because once I was in the car it was physically impossible for me to drive it. Heck I couldn't even close the door all the way.
    banjeaux bob likes this.
  5. 64 DODGE 440
    64 DODGE 440
    from so cal
    Find a car that's done like you want and sit in it and find out if you like it before you buy one.:rolleyes:
    deadbeat, Hombre and Jugornot like this.
  6. X38
    X38
    I posted this in a thread a few days ago which asked a similar question.
    Some people fill a space with too much furniture and kill room. Some people cannot set up pedals and steering wheels etc. and kill room.
    34 coupes are roomy, yet some people have a real skill in making them cramped.
    So, how good are you at setting things up? And yes, try out other cars for size, but bear in mind what I said.
  7. Hombre
    Hombre
    I just traded for a 3 1/2" chopped 1934 Ford 3 window coupe. I am also 6'4" tall and I do out weigh you some, I also am just about 12 years older than dirt so getting into and out of stuff is not always easy. While this new to me car is a project and I havn't really started on it yet. I do have it setting in the shop and I am doing the pretend drive thing and making varoom noise's a lot. The interior room is absolutely no problem for me, plenty of head room and good leg room as well. Now I am used to a chopped car my Model A has a pretty severe chop and I do have to lean over to see out real well, the 34 is a much friendlier using car me thinks.
  8. rusty1
    rusty1
    ...suicide door cars are different getting in and out of,...it takes getting used to.
    good luck with your adventure.
  9. Ned Ludd
    Ned Ludd
    I think we need a general thread on hot rod ergonomics. I'll give it some thought.
    lewk, 31Vicky with a hemi and belair like this.
  10. brett4christ
    brett4christ
    The OP stated he always wanted a 5-window, but the photos all show 3-window coupes.
    A 5-window and a 3-window each have their own "issues" with getting into and out of. A 5W has smaller doors that open conventionally, where a 3W has larger doors but open in reverse (suicide). The easiest form would be a phantom 3-window where the large doors opened conventionally, but then everyone could see the "change" you made.
    Try a couple on for size! The fit may be just what the tailor ordered!
  11. bobss396
    bobss396
    I'm 6' and 240. My buddy has an OT Corvette that is hard to get in and out of, I've gotten better with practice. I'd like a small Ford coupe one day myself so I'm following this thread.
  12. 56don
    56don
    Brett, all 33/34 doors are suicide doors. You must be thinking of a 32 Ford.
    CJ 56 hemi and ls1yj like this.
  13. timwhit
    timwhit
    Yep, the 5 window doors are shorter, front to back, but are suicide style on 33/34 coupes. You might be thinking of a '32??
  14. brett4christ
    brett4christ
    You're correct @timwhit ! Thanks for the memory jog!!
  15. Bill Rinaldi
    Bill Rinaldi
    Rusty is right about the getting used to the suicide doors. But you'll catch on fast. Probably the biggest h***le (once you've got the seat/steering wheel/pedals comfortably arranged) is UPWARD vision through the windshield---as in overhead stoplights and signs. As for long range riding comfort---If it rides decent and you make it driver friendly---You can pretty much set your driving range where ever you want.
    Hombre likes this.
  16. blowby
    blowby
    from Nicasio Ca
    We need a weight watchers thread. ;)
    Me included.:(
  17. midnightrider78
    midnightrider78
    You got me there! I just posted that pic cause it was the closest I had to what I am after as far as style. Basically make the white car a 5 window and paint it black and that is exactly what I want.
  18. HOTRODPRIMER
    HOTRODPRIMER
    Getting in and out of a chopped 33/34 Ford 5 window coupe by a 6' 4" - 240 lb. Neanderthal will make for some interesting entertainment for the causal onlooker,believe me I know,you described me to a T.
    You can remove the package tray and gain some valuable leg room but that will not help with the height,you will need a seat that sits on the floor.
    Last thing is age,the older you are the more uncomfortable you will get when cramped up,having driven a Deuce pickup 600 miles in one day I can tell you you get out often.
    I'm just making a suggestion but why not find someone with a car that has a similar look and ask them can you try it on. HRP
  19. 5window
    5window
    You could always go with one of these traditional aids. Mine actually hangs down from the roof radio console in my Model A with the visor, but they work pretty well.
  20. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    els likes this.
  21. czuch
    czuch
    from vail az
    I fit better in my 61 Galaxie than I did in a '16 Impala.
    There was no room in that rental and I drove 600 miles really pissed.
    6.1' 240lbs. 40 too many.
  22. HOTRODPRIMER
    HOTRODPRIMER
    Remember the old adage - "Just because you can doesn't mean you should". :D HRP
  23. Jalopy Joker
    Jalopy Joker
    owning a Cool ride does not make you Cool - especially if you need someone to push you in and pull you out like on subway type trains in Japan. I had a 5 window '31 coupe with modified seat to help me fit better, 6'1"/180 lbs, and felt too cramped in it - traded it for a '34 Plymouth sedan (the roofline gives it a chopped look) and fit great, even with suicide doors - so maybe look at sedans instead of coupes
    redo32 and Donuts & Peelouts like this.
  24. 56don
    56don
    You guys make me glad I am 5'8"!!☺
    Haden59 likes this.
  25. 29FordMN
    29FordMN
    I have a 29 Ford, 3 inch chop. I'm 6'5 290lbs, former college lineman. I can get in and out once I learned how, lol. I'm also in my mid 30s tho. Once I get older it will be more difficult but not impossible. Seeing a stop light isn't easy, but do able. Driving isn't bad. You have to slouch a little. I have to much fun and to big of a smile on my face when I'm driving it, it doesn't really matter how I got in it.
  26. timwhit
    timwhit
    Promise you, if I had the chance to own either of those cars, I'd loose as much as necessary to fit.
  27. J'st Wandering
    J'st Wandering
    That is exactly what I was thinking. How bad do you want the car?
    You can not do much about your height but you control everything about your weight. Is that favorite car worth p***ing up that donut and 2nd Big Mac or maybe exercise a little more?
    Neal
    old crank likes this.
  28. HOTRODPRIMER
    HOTRODPRIMER
    A guy can loose weight but you can't loose height. HRP
  29. Blue One
    Blue One
    from Alberta
    Not true Danny, most people will get shorter as they age, some more drastically than others. :D
    By the way, it's lose not loose :D :p :D:D
    ls1yj likes this.
  30. blowby
    blowby
    from Nicasio Ca
    I'm at least an inch shorter than I used to be. If I make it anothet decade I can chop my Bantam. :)
    Runnin shine and lothiandon1940 like this.
