Customs Will Merc pedals work in Lincoln
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Jul 6, 2024.
  1. Little Wing
    Little Wing
    from Northeast
    Grabbing a 1950 Lincoln want to convert it to stick. Will clutch pedal set up from 1950 Merc work for the conversion?
    Thanks
  2. Squablow
    Squablow
    First off, is the Lincoln a Cosmopolitan or a baby Lincoln? Because the baby Lincoln body at least is based on the Merc, where as the Cosmo is totally, completely different. The frames of the baby Lincoln are also different than the Merc, but if you got not just the pedals but that section of the X member from the Merc that the pedals bolt to, I think you could swap that into the baby Lincoln easy enough. But not into a Cosmo.
